Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 01-29-2017, 05:46 PM   #1
Journeyman
2016 25' International
Amherst , Massachusetts
Honda Gen... but which Propane Kit!
I'm planning a purchase of the Honda eu2000i generator and want to do a propane conversion....
Any opinions on Genconnex vs. Hutch Mountain kit?
The hutch mountain kit is cheaper and allows you to still run on gas, but it's got some extra pieces.
Thoughts?
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 01-29-2017, 08:56 PM   #2
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
I like the genconnex, as it doesn't increase footprint and space is a premium. Haven't bought it yet, but might. Also check out motorsnorkel, I have one of theirs for my house generator and it works well.
Link below
http://www.motorsnorkel.com/
Troutboy
Troutboy is offline   Reply With Quote
Old 01-29-2017, 09:24 PM   #3
FishByFly's Avatar
2017 25' Flying Cloud
Fayetteville , Arkansas
What about a recommendation for a tri fuel conversion for a EU3000is?
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn
2023 F150 XLT
FishByFly is offline   Reply With Quote
Old 01-29-2017, 09:56 PM   #4
Troutboy's Avatar
Parker , Colorado
Same places make them.
Troutboy
Old 01-30-2017, 11:20 AM   #5
2001 30' Excella
Full-time traveling , Hmmmm. what day of the week is it?
USCarb
I strongly recommend the US Carburetor brand for a Honda generator conversion to a tri-fuel. I installed it in less than an hour and it works fantastic
JBBeaubeaux is offline   Reply With Quote
Old 01-30-2017, 11:25 AM   #6
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
We got our Honda Propane from GenConneX and works great plus they give a great warranty and give you some hoses to go with it.
The warranty from them is worth the money, by the time you price out going thru someone else with a limited warranty, GenConnex is the deal.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 01-30-2017, 11:50 AM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Ditto, for tri-fuel conversion.
http://www.uscarburetion.com
Easy stable mounting on the end vice the side using their mounting bracket.
MICHAEL
Old 01-30-2017, 11:51 AM   #8
Troutboy's Avatar
Parker , Colorado
Again, make sure you check out the mods and are okay with having a large regulator attached to your generator. If so, the trifuels. If you want to maintain the original footprint go with the genconnex, it's awesome.
Troutboy
Old 01-30-2017, 12:19 PM   #9
Michael Wild
1978 31' Sovereign
1984 31' Airstream310
Edmonton , Alberta
Are there any issues using the Honda EU 2000 twinning generators with a propane conversion?
Michael_Wild is offline   Reply With Quote
Old 01-30-2017, 12:40 PM   #10
1955 22' Safari
Laredo , Texas
I used this tri-fuel conversion kit from Century Fuel Products:
https://centuryfuelproducts.com/gene...tural-gas-kits
Highly recommended.
55AS is offline   Reply With Quote
Old 01-30-2017, 02:05 PM   #11
2016 16' Sport
Miami , Florida
If by twiinning you mean in parallel then no trouble at all.
Shiny16 is offline   Reply With Quote
Old 01-30-2017, 02:43 PM   #12
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
My impression from reading and contributing to lots of posts in Airforums about Honda generators running on propane is that the options are all pretty good.
I bought an EU2000 and a matching companion two years ago. I used the Propane Carbs kit (https://www.propanecarbs.com/honda-e...onversion.html) and have been pleased. I chose that because of the reviews plus it is tri fuel (gasoline, LP or natural gas), includes a high pressure regulator (many kits do not... having one lets me run the generator directly off a dedicated LP cylinder. other kits must run off the low pressure port of the trailer or you can add the cost of an aftermarket high pressure regulator to their price) and it requires a minimum of alterations to the generator (the original carbs are unmodified by the conversion and the case does not need to be drilled to mount the demand regulator).
There are pics in my gallery if you are interested. I've also run and posted in AirForums info on LP consumption of these kits and the hardware I use to run both off the low pressure LP port (full disclosure: running both exceeds the Airstream recommended load on that port).
They also have kits for other generators including the Honda EU3000.
GammaDog is offline   Reply With Quote
Old 01-30-2017, 03:05 PM   #13
PKI
PKI's Avatar
Walnut Creek , California
Originally Posted by Troutboy View Post
-- snip -- Also check out motorsnorkel, I have one of theirs for my house generator and it works well. -- snip --
Anyone else got experience with the LPG Yamaha that Motor Snorkel sells? Or with purchases from them?
Old 01-30-2017, 04:22 PM   #14
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Take a look at a previous threat on this subject, very good info:
http://www.airforums.com/forums/f37/...or-161733.html
Crabpot is offline   Reply With Quote
Old 01-30-2017, 04:39 PM   #15
2016 16' Sport
Miami , Florida
If your not allready using 30 gallon tanks you could try one. Bigger tanks work better at colder temperatures.
Old 01-30-2017, 07:12 PM   #16
2016 16' Sport
Miami , Florida
Ops ..the previous post was meant for a different thread.
Old 01-30-2017, 08:35 PM   #17
dasams's Avatar
Palm Desert , California
What's your TV? I tow with an SUV and have no way to carry a gas can. So it was an easy decision to go propane only. That GenConnex has great support on this forum made for an easy decision. As always, YMMV, Dave
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 01-30-2017, 09:24 PM   #18
Journeyman
I have a pickup, but I am a big fan of simplicity (genconnex). Unfortunately, I'm also a fan of utility (dual/tri fuel...). Hence my dilemma.
Which Parallel Kit for Honda 2000i AldeanFan Generators & Solar Power 3 12-14-2012 03:16 PM
Honda gen to charge batteries Roamin Cat Generators & Solar Power 7 05-30-2008 09:29 AM
Honda Gen question - after search Tom Randall Generators & Solar Power 16 06-24-2007 09:33 AM
honda gen. ? ticki2 Generators & Solar Power 0 09-15-2006 07:30 PM
Storing (storage) of Honda Gen. winter months... crazylev On The Road... 5 11-08-2004 11:30 AM
