11-19-2014, 01:31 PM
#41
1981 31' Excella II
New Market
, Alabama
My Briggs and Stratton powered generator will wake the dead.
Perry
11-19-2014, 01:41 PM
#42
2014 30' FB FC Bunk
Hoover
, Alabama
My neighbors generator when there is an outage is some kinda contractor grade 7500 watt generator - I can hear it loud and clear anywhere in my house
My eu700 running from bed of truck camping - with my fan from AC running it cannot be heard over that noise maker
11-19-2014, 05:34 PM
#43
2015 30' International
Springdale
, Arkansas
PharmGeek,
Do you know where you got the adapter that goes from the 50amp (4 pole male with screw connector) on your AirStream to the 220v 4 pole receptacle twist and lock connector on the right of the generator?
BlueMesa
11-19-2014, 05:50 PM
#44
2014 30' FB FC Bunk
Hoover
, Alabama
11-19-2014, 07:23 PM
#45
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Congrats, PG. We will be anxious to hear how it all works out ... envious!
11-24-2014, 07:19 PM
#46
Springdale
, Arkansas
PharmGeek,
Got the EU7000is. Wow is it nice.
Looking for a hard cover to put over the top so one can't see it in the back of my truck. Plan to then slide next to tailgate, then pull roll top up to tight against the hard cover.
Any ideas on what to use for a cover (for travel only)?
tnx
BlueMesa
11-24-2014, 07:37 PM
#47
2014 30' FB FC Bunk
Hoover
, Alabama
I thought of that but have not came up with a cover myself....for now I use simply the honda soft cover for it (sold separately)
11-24-2014, 08:00 PM
#48
2014 30' FB FC Bunk
Hoover
, Alabama
Something g perhaps like a cheap doghouse could convince....
11-27-2014, 08:44 AM
#49
2006 25' Safari
St. Augustine
good choice and smart move to plan for multi-tasking.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
12-13-2014, 10:29 AM
#50
Springdale
, Arkansas
Might want to get a set of these pads from Yakima to keep from bouncing off of tailgate etc... Fit perfectly.
12-13-2014, 10:56 AM
#51
Austin
BlueMesa,
Can you provide a link to the Yakama pads?
Thanks!
12-14-2014, 05:39 AM
#52
Springdale
, Arkansas
12-14-2014, 09:59 AM
#53
Small Town
Originally Posted by Ted S.
Hey I joined this Forum thinking you guys were hardcore living unplugged while boondocking in areas not frequented by humans, now you are dragging home standby generators with you?
Just kidding.
I don't even have my Airstream yet, all I got is a stinking VIN #.
Is there any other way ...went from one to two EU 2000i units to just one EU3000iS ... much quieter and we love the electric start!
12-14-2014, 11:08 AM
#54
Springdale
, Arkansas
Just ran my intl 30 with two AC/heat pumps. With both on it draws about 4300 watts. Assume this is like the air conditioning draw of both of them. That's why I got the EU7000. Also very quiet with eco throttle. With one air conditioner wouldn't need it.
12-15-2014, 12:44 PM
#55
2014 30' FB FC Bunk
Hoover
, Alabama
BlueMesa - I had similar numbers as I recall
The spike when a AC unit kicks on is fast - I'm doubting the Honda unit's readout will display the max it demands for that spike
10-30-2016, 10:31 PM
#56
2021 27' Globetrotter
Fort Lauderdale
Originally Posted by TavnAsh
I love the 3000, but not enough juice for our application.... If I had the $$. I would be installing a permanent diesel 6000 in the bed of the truck.... Need a min of 4500 watts or preferably 6000 when I upgrade to 50 amp
Hi, did you find the 6KW diesel you wanted? Which one you have in mind? I am after the same
11-05-2016, 09:01 PM
#57
Leavingtherut.com
2005 30' Safari
Key Largo
Not yet. The damn Hondas won't die!!! I still plan on the diesel cummins onan, probably used, mounted in a fabricated cage on my flatbed, or under a topper....
More to come when the EU2000's die. Currently they are semi permanently mounted and tied into a 12 gallon aux tank. They run day and night non stop and probably have thousands of hours on them....
11-29-2016, 07:56 AM
#58
2016 28' Flying Cloud
Tullahoma
, Tennessee
What cable are you running from the AS to the Honda? Where did you get it? I'm confused about which receptacle on Honda to use. Also bought the EU7000is.
11-30-2016, 05:46 AM
#59
Fort Lauderdale
I got two Honda 3,000 Handi (already got one, the other should arrive and be re-jetted for 8,000 feet altitude today) as they fit under the tonneau. Also a toolbox/gas tank stores 46 gallons of gas on them, got the parallel cable, chain and lock. Onan diesel 6 or 8KW (same dimensions) was my original choice, but they have to be serviced from underneath, so had to the mounted on a frame and will exceed the height limit on my truck's bed while still be covered by the tonneau. In retrospect, I think the Honda 7,000 is quieter and cheaper than the 2 3,000 Handi minus the cables, etc. And while taller than the tonneau, maybe there is a topper in the market that, lower than the cabin, will still cover it. Did not research that.
GT 27 2021, F250 2022 Platinum- 2022 Tesla X - 2021 Ford Mustang Mach E - 2022 Tesla 3 - PP3 hitch
GSD Sigrid - Fort Lauderdale, FL; Denver and Summit County, CO.
11-30-2016, 06:27 AM
#60
Alpharetta
, Georgia
Here's Honda's official receptacle guide to the EU7000is:
Finally, the large twist-lock receptacles on larger Honda generators are NEMA-standard designs. Dozens of manufacturers offer adapters of various shapes and sizes to convert / connect to an RV-industry standard 'flat blade' design, including Honda...a few example are:
Google any Honda part number to find a Honda Dealer selling it online, or use this link to find a Honda Dealer in your area: Find A Honda Dealer
Robert@Honda
Social Media Consigliere
Caveat: I work for Honda, but the preceding is my opinion alone.
