Old 10-11-2008, 04:51 PM   #1
Cambridge , None U.S.
Honda EU30is - does it need running in? (Breaking in).
Hello there. I'm new to this forum and, as is so often the case, feel very ill-informed - I've been having a bit of a browse. There seem to be a lot of knowledgable and helpful people here so I reckon this might be a good place to be.
I have just bought a Honda EU30is generator and I was hoping that someone could help me out on a couple of points.
First - should it be "run in". (I hope I've got the terminology right - British English and American English sometimes differs on these things, I find. What I mean is - should I be treating the engine differently for the first few hours of use).
There's nothing in the manual about a running-in period but I'd be interested to hear the opinions of people who are familiar with these machines or with the more general concepts involved. If I should be running it in, what exactly should I be doing - varying the load? Keeping it low with an occasional burst of "full throttle"? What?
Also - on the subject of oil:- the manual says that 10w-30 oil should be used. Actually, having had a bit of a look, I found plenty of 10w-30 oil made by people I'd never heard of. Then I found plenty of other grades made by people I HAD heard of. But not a lot of 10-30 made by anyone whose name I recognised. So now I'm confused. Would I be alright with a 10w-40 made by Castrol or Mobil? I think I'd prefer that to buying 10w-30 made by "Cheap Oil Products inc." of Shanghai, you know. Or perhaps a 5w-30? (As you may have gathered I live in temperate England, where the temperatures are usually somewhere between minus five and twenty five degrees farenheit).
And also - should I use a synthetic oil? So far as I can tell it's not recommended in the running-in period but if there is no running in period then that would be irrelevant, no?
So - please help. I don't want to void the warranty by doing something stupid but Honda are pretty uncommunicative really.
Hope someone can give me a bit of help.
Thanks a lot
Cape Wrath is offline   Reply With Quote
Old 10-11-2008, 07:29 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Hello, and welcome to the forum.
First, the oil that came with the generator should be used for the break-in. It is usually found inside the box with the generator. Honda only recommends 10w-30 non-synthetic oil for the generators, both while breaking-in and during use. I seem to remember the first oil change is due at 30 hours' running, then on the order of several hundred hours thereafter (I don't have the owner's manual for ours in front of me, so can't be more specific). I use Mobil 1 synthetic in ours, and have had no problems at all, oil related or otherwise. If you want to follow Honda's recommendations, you should be able to find Castrol 10W30 (currently owned by British Petroleum).
Old 10-12-2008, 07:54 AM   #3
Hello Terry, et al.
Thanks a lot for that. I think this is probably a pretty stupid question but what should I be doing to run it in? I just want some really simple instructions, like "run it at a quarter load for twenty hours going up to full load for five minutes in every hour" - something like that.
I should know what to do but I don't, and Honda don't seem like too much help. The actual dealer is pleasant enough but doesn't strike me as all that well-informed really so I'm out on my own here!
So if you could give me some instructions along those lines it really would be very helpful.
Thanks a lot.
Old 10-12-2008, 08:17 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
At the Albuquerque Balloon Fiesta the Honda dealer on site was setting up units for new buyers. They would fill it with oil and gas, plug it into the trailer and start the unit.
Richard
Old 10-12-2008, 08:34 AM   #5
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Do what the manual say's. If that's nothing then don't worry about it. Our 2000i is doing just fine on 10w30 and I certainly wouldn't use a 10w40.
Ahab is offline   Reply With Quote
Old 10-12-2008, 08:36 AM   #6
Central , Mississippi
I also was surprised at no mention of a break-in period in the Honda manual. I filled mine with Vavoline 10w-30 the ran it for an hour with 1/2 load (1000 watts of heat lamps on my 2000i genset). About every 15 minutes I'd unplug the load for a few seconds then replug it.
I did an oil change at 10 hours of normal use and figure I'm good to go.
Right or wrong, that's what I did and it's running like a champ!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 10-12-2008, 09:45 AM   #7
Well Preserved
1993 21' Sovereign
What's probably the most important thing is to shut it down and change the oil after a few hours' run-time. This will purge most of the fine metal shavings and grit that will get into the oil from the manufacturing process. Something I didn't mention in my previous post, it is important to not use synthetic oil until after the generator has run a while. It is so slippery the moving parts will have no chance to "seat". If that happens, you will find it may use more oil, and have less compression than it should.
Old 10-12-2008, 09:53 AM   #8
Hello again - thanks for the replies.
It would be nice if Honda could have made some mention of running in - even if it was just to say that it wasn't needed. I take the point about not doing it if it isn't specifically mentioned but the manual is terse and not overly helpful and I find it quite easy to imagine that it might leave something important out. I may be maligning Honda there but it's the impression I get.
HiHoAgRV - can I ask what sort of use your 2000 normally gets- is it frequently run at, or close to, it's maximum capacity or well below, or what? Is that Valvoline a synthetic oil, by the way?
As I got the generator already filled with oil and tested I never got to see the box or any oil contained in it. I'll give the supplier a call but I'm not too confident that my specific contact there will remember! So it would be nice if I didn't have to rely on him. Honda U.K. are pretty useless - more interested in flogging their latest pastel blue car than providing useful information about oil - and they tend to just refer you back to the supplier.
Anyway - it's all interesting and useful stuff. Please keep those replies coming - I need all the help I can get.
Thanks again.
Old 10-12-2008, 10:05 AM   #9
Well Preserved
1993 21' Sovereign
I'm not Vernon, but...
When our 2000 is run, it gets used at anywhere between 10% and 95% rated capacity. Most of the time it is at about 25%, with occasional spikes. We've run it overnight in that load range, and it has run about 8-10 hours on a tank of gas (a bit over 1 US gallon).
Old 10-12-2008, 10:19 AM   #10
Thanks Terry- it's those vital first few hours that particularly intrigue / worry me. Do you think I should be giving it a few hours on , say, quarter load before going up to occasional higher loads? Something like that? I'm just worried that I'm going to do something wrong in the first week of use which is going to mess me up for ever.
I'll certainly change the oil early and frequently, and stay away from the synthetics for a while, but I'm still a bit confused as to whether I should be treating it like a gentle little baby for a while (low revs all the time) or giving it a good hard run, in the hope that it gets used to the idea. Or a combination of the two.
Any suggestions on that one?
Thanks a lot.
Old 10-12-2008, 10:39 AM   #11
Originally Posted by Cape Wrath View Post
...HiHoAgRV - can I ask what sort of use your 2000 normally gets- is it frequently run at, or close to, it's maximum capacity or well below, or what? Is that Valvoline a synthetic oil, by the way?
Thanks again.
The Vavoline was normal Dead Dino grade - non synthetic and like Terry said, the first oil change was mainly to flush the leftover materials from manufacturing.
The load on my unit is 95% very low, just charging the batteries and the 2000 is basically at idle. The remaining 5% is when it powers hand tools like a saw - the startup amps hit the Honda with a pretty good load.
Old 10-15-2008, 11:25 AM   #12
Hello, it's me again.
I went to get some oil from the oil emporium in our local town today. 10w-40 as far as the eye can see but not so much as a pint of 10w30.
I went to a few other places and I did, I seem to remember, see some 10w30 at one of them but it was the store's "own brand" and I wasn't too sure about that.
A few messages up, Ahab says "... I certainly wouldn't use a 10w40...". Now I'm curious as to why that is. Obviously I don't want to do anything stupid but I could easily get 10w-40 with a brand name I trust.
I can understand that 10w30 might not be a good substitute for 10w40 as it might not operate properly at the high extremes of an engine's temperature - I'm not so clear about the other way round. Would a 10w40 really be unacceptable as a substitute for 10w30? And why?
Thank very much.
Old 10-15-2008, 01:18 PM   #13
1975 25' Trade Wind
NorthrnNMguy's Avatar
1975 25' Tradewind
Los Luceros , New Mexico
Sorry folks I had to jump real quick. My 2000 specs said to use a specific which I found to be for a 4 stroke engine, similar to ATV type oil. It comes in a small bottle like the size you would use for chain saws, weedeaters and the such. Is this wrong?
somedays chickens, somedays feathers.
NorthrnNMguy is offline   Reply With Quote
Old 10-15-2008, 02:54 PM   #14
WK57ABF's Avatar
2007 25' Classic
kendal , cumbria, UK
Hi Cape Wrath,
My Honda manual for 2Kva says 15w-40 for our climate. We use l5w-40 in our Fat Boy, recommended by Harley, and l5w-40 in our F350 Super Duty, recommended by Ford. Haven't used any other viscosity oil for 30 years or more. Even got l5w-40 in oil can!!!
John Stephenson
WK57ABF is offline   Reply With Quote
Honda EU2000 x 2 vs Honda EU3000 and Yamaha 3000 IntegrityAir Generators & Solar Power 43 07-01-2009 11:19 AM
Honda EU 3000 vs 2x Honda EU 2000 vajeep Generators & Solar Power 93 07-23-2008 11:02 AM
Honda 2000s Running the A/C moosetags Generators & Solar Power 15 06-26-2008 08:07 AM
Breaking Away jcferguson Brakes & Brake Controllers 19 03-28-2006 07:06 PM
Running Honda Generators in Parallel Cracker Generators & Solar Power 16 05-16-2004 06:49 PM
