Old 08-09-2016, 04:02 PM   #1
2012 25' FB Eddie Bauer
FORT WORTH , Texas
Honda EU3000iS Overloading
Have air conditioner running but nothing else. Not in Eco mode. Only 10 hours or so on the unit. Good oil and stabilizer have been used.
So, any ideas why it's overloading? Is there a shot clock on how long it can run the AC? Thanks!
wildestream is offline   Reply With Quote
Old 08-09-2016, 04:18 PM   #2
2015 25' FB Flying Cloud
Sandy , Utah
It could be a lot of things. When the AC compressor starts up it draws a lot power. Once running it takes less. I followed the advice on many threads in this forum and bought two 2000's. You can turn the circuit breaker off for the converter and make sure the water heater is on propane to cut down on the amount of power needed.
rocco52 is offline   Reply With Quote
Old 08-09-2016, 04:42 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Switch the fridge over to LP, as well. The heating element is another 300 watts.
Old 08-09-2016, 05:19 PM   #4
Gainesville , Florida
If your ac is an 15000 that could be a problem.
Old 08-09-2016, 05:42 PM   #5
2016 30' Classic
Erie , Colorado
EU3000 is something like 2800 with a burst to 3000. (run specs with a perfect unit is 23.3amps) If all you are running is a 15K AC it should start and run fine.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 08-09-2016, 07:48 PM   #6
FORT WORTH , Texas
How do you turn the breaker off for the converter?
Old 08-09-2016, 07:55 PM   #7
FCStreamer's Avatar
2014 30' Flying Cloud
This is correct. Which means there's either other draws on the generator, or the generator is defective and not producing rated wattage.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 08-09-2016, 08:05 PM   #8
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I run my 15K AC on a Honda EU300iHandi with no problems. I am very careful, though, about not starting it if I've got any other major electrical consumers on line. For sure I wouldn't use elec HW or microwave. Something is definitely amiss with your setup...
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is online now   Reply With Quote
Old 08-10-2016, 06:26 AM   #9
Interesting, the spec sheet for my 13500 ac recommends at least a 3500 generator. Anyone else read their spec sheet for their ac unit?
Old 08-10-2016, 08:54 AM   #10
Sandy , Utah
Wildestream, on my 25FB there is an electrical panel on the box supporting the bed. I can't remember exactly which one of the circuit breakers is for the converter but there is a diagram on the box itself and also in the owners manual. Switching the refer to propane is done on the controls behind the freezer door. It cycles through Auto, which will use either power or propane whichever is available, or just propane. There is a little green light above the display that shows which. When AC is not needed, early morning or later at night make sure to switch the converter back on to charge the batteries.
Old 08-10-2016, 09:53 AM   #11
2013 25' FB Flying Cloud
Tallahassee , Florida
Try a hard start kit on the AC, I think there less the 100.00 dollars. years ago had some other brand and had to use a hard start kit with the same generator.
Eu 3000 works fine on my 25 FB.
Omega Man is offline   Reply With Quote
Old 08-10-2016, 01:25 PM   #12
robert@honda's Avatar
Alpharetta , Georgia
How old is the generator? It has a 36 month warranty, and a properly-equipped Honda dealer can hook up a load bank to it and confirm the output is correct / within spec. If you're not sure of the age (maybe you bought it used?) drop me a PM with the serial number and I can look up some details for you:
The serial number will be in the format "EZGF-1234567"
Robert@Honda
Social Media Consigliere
Caveat: I work for Honda, but the preceding is my opinion alone.
robert@honda is offline   Reply With Quote
Old 08-10-2016, 03:10 PM   #13
2016 25' Flying Cloud
Holly Springs , Mississippi
Originally Posted by robert@honda View Post
...drop me a PM...
Robert, while we've got you stopped...
I want to parallel two EU 2000i's rather than use one "regular" and one Companion. What's the suggested parallel cabling I should use to do this? I'd like to not have to have an adapter to get to the 30A RV plug.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 08-12-2016, 07:37 AM   #14
Honda still offers an external 30A parallel kit for doing that exact job. It mounts to the front of one EU2000i, then cable plug into both. The full, 4,000 watts are now ready @ the RV receptacle on the front of the enclosure:
Honda Part Number 08E90-HPK2001, list price $199. Click here for a Google search to show Honda dealers selling it online, or use this link to find a Honda Dealer in your area: Find A Honda Dealer
Robert@Honda
Honda EU3000iS vs. Yamaha EF3000iSE/B pickerdd Generators & Solar Power 13 07-02-2017 09:47 AM
Sir... "Tire Failure due to Overloading Trailer" Ray Eklund Tires 23 03-14-2016 09:50 PM
Honda EU3000is conversion to propane pickerdd Generators & Solar Power 2 10-02-2011 03:41 PM
Converting Honda EU3000is to Propane FordTruck Generators & Solar Power 9 10-10-2009 02:31 PM
Good deal on Honda eu3000is generator Xstream Generators & Solar Power 3 07-14-2009 12:19 PM
