Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 09-25-2006, 05:20 AM   #1
Profile:  2007 25' International CCD
Arlington , Virginia
Question Honda EU3000i Generator Users
Was just wondering about a few things:
1) The 30 AMP plug on the AS I am about to buy (96 25' Excella) I believe is a "flat pinned" plug whereas the receiver/receptacle on the EU3000 is a "twist-lock" plug type. I think I read in another thread that there is an adapter to let the two mate successfully?
2) Even if 1) is correct, I believe the EU3000 puts out 23.3 AMPS from its biggest outlet. Is that "no big deal" for a 30AMP circuit cause its LESS versus MORE (i.e. Overload)? In other words, things in the trailer will still operate as long as the demand is less than the amps supplied?
3) Since I have yet to venture to a campground yet, are most of the power receptacles of the flat pinned variety or of the twist-lock type?
Streamer1 is offline   Reply With Quote
Old 09-25-2006, 05:49 AM   #2
Profile:  1993 30' Excella
Apache Junction, AZ
1 Yes, there is an adapter. I got mine at Walmart.
2 not a problem. The contacts and wiring are rated for more than the generator puts out.
3 Flat
We have used our 3000 to run everything in our 30', including the the A/C. You probably have a switch in your A/S which allows use of either the A/C or the microwave, but not both at the same time.
n7bdl is offline   Reply With Quote
Old 09-25-2006, 06:30 AM   #3
Thanks Terry!
Onboard generator bhsl8 Generators & Solar Power 39 07-29-2003 05:31 PM
Honda Generator Mounting dmac Our Community 11 05-20-2003 09:55 AM
Honda 2000i generator wayner1239 Generators & Solar Power 22 02-28-2003 02:48 PM
towing and the Banks Power Pack kooblekidz Airstream Motorhome Forums 11 10-31-2002 12:09 AM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 01:03 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
