Old 07-23-2008, 11:19 AM   #1
1999 25' Safari
Edina , Minnesota
Honda EU200i Fuel-Will white gas work?
I have an extended boondocking trip coming up and, though I do not use my generator all that much, I may have a need. I don't want to carry a jerry can of gas in the car, so was wondering if "Coleman white gas" will work in a pinch until I can get to a regular filling station. What is the consensus?
1999 Safari 25C
2009 Yukon Denali
WBCCI #2369
JaceBeck is offline   Reply With Quote
Old 07-23-2008, 11:23 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
My personal opinion is the white gas doesn't have enough octane in it to run the generator properly. If it was all I had, and it was 100 miles to town, I might try it.
Old 08-04-2008, 07:46 PM   #3
Vagabond
TheBigRedTruck's Avatar
1973 31' Sovereign
Fort Meade Md. RV park slot 8!! , Motorsports Photographer
Images: 36
Send a message via AIM to TheBigRedTruck
It will go BOOOOM!!!!!!!!!!! Dont try it!!!
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
TheBigRedTruck is offline   Reply With Quote
Old 08-04-2008, 08:01 PM   #4
tpi
Trabuco Canyon , California
No the octane rating of the Coleman fuel is too low. The generator has a sufficient compression ratio to risk damaging knock or ping.
tpi is offline   Reply With Quote
Old 08-04-2008, 10:57 PM   #5
Motoman's Avatar
2005 25' International CCD
1960 18' "Footer"
Riverside , California
My reply is a little off thread, but we used to have an old Class C motorhome with a Ford 460 engine. On one trip I was trying to get to a small town where the gas was typically cheaper, except we ran out about 3 miles from town on an uphill section of the heavily crowned 60 Freeway in California. I had one liter of Coleman Fuel for our lantern. I put the Coleman Fuel in the tank and was able to drive get the motorhome started drive a short distance to the top of the hill where the freeway wasn't as heavily crowned and then into to town.
Certainly the tank wasn't completely empty but the hill and the crown kept the fuel away from the fuel pickup in the tank., so I was actually driving on a mixture of Coleman Fuel and gasoline.
Who knows if it would have run on Coleman Fuel alone. However, I echo the comments of others though. This was an emergency; I wouldn't try to run either of my Honda Generators on Coleman Fuel under any circumstances. Besides I find that having 260 watts of solar on the roof of the Airstream and a Honda generator let me use which ever can best deal with my situation at the moment.
You might try putting a jerry can mount on the back of the Yukon, check with the 4X4 shops for different mounts to see if you can find something that won't interfere with with the trailer when you turn.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Old 08-06-2008, 07:25 AM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I have run Coleman fuel in a Honda GX160 (5.5 HP) powered water pump, with no problems. Can't say it would or would not hurt a Honda generator engine, though.
White gas will evaporate a lot faster than gasoline in a vented tank.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 08-06-2008, 08:28 AM   #7
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Call Honda's Power Equipment Division @ (770) 497-6400 and get your question answered by the folks that made your generator rather than taking a chance to ruin a $1000 generator.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 08-06-2008, 09:43 AM   #8
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Even with gas at around or over $4.00US a gallon, it is still less money than a gallon of white gas, not to mention the above warnings.
We bought a little 2 1/2 gallon plastic gas can thing. We fill that up when we know we are close to our destination, or during a trip if we think the Honda tank will run dry. We only run the gen for two hours each day, and I think think one tank runs for eight hours on eco throttle, so if my reform skool math is correct, that's four days of use.
When we leave, I simply pour the remaining gas in the tow vehicles gas tank.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 08-06-2008, 10:05 AM   #9
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
From the Coleman website:
Coleman® Fuel is basically petroleum naphtha with a bit of rust inhibitor. It has an octane rating of 50 to 55 and none of the additives found in gasoline. It has a lighter molecular weight than gasoline, kerosene and diesel fuel and cannot be used as a substitute for any of those fuels.
The flammability of Coleman® Fuel is comparable to gasoline but it cannot be used in gasoline engines. It will burn out the valves.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 08-06-2008, 10:10 AM   #10
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Sounds to me like a good excuse to convert to a propane dual fuel carb.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Pictures of my fuel can and EU2000 Honda Raptorrider2001 Generators & Solar Power 34 05-23-2012 02:05 PM
White Gas? doorgunner Stoves, Ovens & Microwaves 31 04-14-2008 02:15 PM
Why diesel fuel cost more than gas Tin Diesel Tow Vehicles 88 03-06-2008 03:05 PM
Fuel leak in the gas filler hose mrgump Airstream Motorhome Forums 5 04-04-2007 02:51 PM
Dual Fuel Gas regulator thenewkid64 LP Gas, Piping, Tanks & Regulators 5 03-12-2003 02:26 PM
