Old 08-12-2012, 11:22 AM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Honda EU2000i or a Yamaha EF2000iS
Looking at a Honda EU2000i or a Yamaha EF2000iS, the specs look the same and was wondering what is the best one to go with, also, what is the best way to store the gasoline to power the generator when trailing. My AC is a Frigidaire Model: FAK085R7V 8,000 btu, Amps (Cool): 7.2. planning a trip West next year.
toastie
toastie is offline   Reply With Quote
Old 08-12-2012, 12:20 PM   #2
2005 19' Safari
GLENDALE , AZ
Not sure, but owners seem to about evenly split between these two brands; and nearly all posts I have seen indicate both are quiet and reliable. Your decision may be just between whether you like red or blue.
There are a few other brands that also have good reputations, and I am sure their owners will identify them on this thread. However, I think most would not recommend any generator that is objectionably loud.
Old 08-12-2012, 12:53 PM   #3
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I have had my Honda's for about 9 months and they have worked very well. as the previous post stated either one will work fine it might just come down to price.
urnmor is offline   Reply With Quote
Old 08-12-2012, 12:58 PM   #4
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Check the Yamaha 2800 out. I am told by a local RV dealer (reputable) that it will handle the AC on our Airstream. Currently we have a Yamaha 1000, and other than leaving gas in it too long (clogged carb jets) it has been flawless for years. Keeps the batteries topped off very nicely.
Old 08-12-2012, 01:56 PM   #5
toastie's Avatar
1955 22' Safari
The other question that I had, what is the safest why to handle the gasoline when traveling, plastic or a metal container?
Old 08-12-2012, 02:22 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We carry our gasoline in plastic containers in the bed of the truck which has a tonneau cover... We use two...a 5 gal for longer trips + a 2.5 gal which is much easier to pour from, etc. We have a friend who carries her generator gas lashed to the tongue behind the propane tanks with bungees ...
TB & Greg and Abbey Schnauzer
#3954
Old 08-12-2012, 02:56 PM   #7
2005 19' Safari
GLENDALE , AZ
We carry extra fuel in a portable marine gas tank that is very heavy-duty plastic. It is a replacement tank for outboard motors that holds around 6-7 gallons.
We got ours at a local WalMart: Attwood 6-Gallon Fuel Tank - Walmart.com
Here is another link that looks like it is ready to use as an "extended run" tank. All you need is an extended-run gas cap and a fuel fitting: Amazon.com: 6 Gallon Boat Portable Fuel Tank Mercury Hose Assembly: Sports & Outdoors
If you intend to use the tank only for fuel storage, screw a brass plug (1/4NPT, I think; available in the plumbing section at Home Depot or similar store) into the fuel fitting, as a stopper.
Outboard tanks seal really well and do not leak or emit gas fumes. Plus, being for marine use, they are really tough and will take some abuse.
To fill the generator's internal fuel tank, we use the Flo N' Go "Maxflo" ($25-30?) that we also got at WalMart. However, these are not always in stock: Flo N' Go - Maxflo
Old 08-12-2012, 02:58 PM   #8
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
There are hundreds of posts on this question. I opted for the two Honda 2000's, as if I'm not going to need A/C I can get by with just one...and they are very light and dependable. Just be careful with the Ethanol additives, as they will gum up the carbs if you don't use the gens frequently, or add Stabil.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 08-12-2012, 03:10 PM   #9
toastie's Avatar
1955 22' Safari
Great info....thanks very much
Old 08-18-2012, 04:15 PM   #10
toastie's Avatar
1955 22' Safari
Has anybody have tried dometic LW3000, can be bought brand new
for $799.00
Old 08-18-2012, 09:00 PM   #11
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
for $799.00
Here's a short discussion on the Forest River Forum... interesting. Will be interesting to see how it holds up and serves users. Good price for 3000w (2800 max output).
And here's a PDF about them.
Still like our Hondas...but this might work well for some.
#3954
