Old 02-11-2015, 07:47 PM   #1
2015 25' FB Flying Cloud
Meadow Vista , California
Honda EU2000i Companion Generator
I just purchased a second Honda 2000 generator the companion model. In the instructions that came with the companion cables it says to distribute the loads equally between the two generators. In the 2000's owners manual it does not mention that. I assumed I could just hook the shore power to the 30 amp outlet on the companion generator. Can anyone offer advise on the proper way to use the two.
Thanks!
SilverSinbad is offline   Reply With Quote
Old 02-11-2015, 07:53 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Yes you can
Old 02-11-2015, 08:48 PM   #3
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
You connect the two together using the parallel cords and then connect the trailer shore power to the companion 30 amp socket.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 02-11-2015, 11:18 PM   #4
2005 19' Safari
GLENDALE , AZ
I was unable to find the directions you are asking about. Could you please post the entire paragraph that contains the text in question?
--Thanks!
Old 02-12-2015, 12:25 PM   #5
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Sailor...if you run your AC you need to hook them up in tandem...but for all non-AC uses your companion generator will do just fine. That's why I b ought the set...unless I think I'll need the AC I'll shed 47lbs and just take the companion and hook it directly into the 30 amp. outlet. Lumatic was correct. jon
B00merang is offline   Reply With Quote
Old 03-31-2015, 11:47 AM   #6
2016 30' International
Big Lake , Alaska
I am about to pull the trigger on a pair of 2000i gen sets. What is the advantage of getting a regular and a companion vs. two regular (and less expensive) 2000i and purchasing the wiring harness with the 30 amp plug?
akjam is offline   Reply With Quote
Old 03-31-2015, 11:58 AM   #7
acstokes's Avatar
2009 30' Classic
The Companion has a 30 amp outlet so a 30 amp shore power plug will fit it.
Fred Stokes
WBCCI #2810
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
Honda Generators, EU2000i and Companion 2000i(4,000 watts) Support Admin Airstream Classifieds 0 09-20-2013 01:07 PM
Selling Honda EU2000i and its companion... grimlock Our Community 0 09-11-2010 11:08 AM
Honda 2000i companion + 2000i or just 2 2000i's??? socdiva Generators & Solar Power 5 10-27-2009 02:53 PM
