Old 05-02-2011, 01:50 PM   #1
Benjo's Avatar
1949 18' Trailwind
Huntsville , Alabama
Honda EU2000i
Hi there-
Been reading and researching these honda generators for a couple years and finally pulled the trigger on the EU2000i. We recently got clobbered with tornados here in AL and our power was out for 4 days so I decided to go ahead and pick it up. Man, this thing worked AWESOME! Cranked the first time and kept our fridge going, fan, couple lights, charged cell phones, etc. Can't say enough about it other than it was everything we thought it would be and more. My neighbor dropped by and was checking it out and thinking about getting one himself for these kinds of situations. So, I was wondering how I should store this thing now and what what steps I should follow to keep it in good working order for the next time. I hear some folks drain the fuel while others put fuel conditioner in there and run it every couple months or so. Any suggestions would be appreciated. Thanks!
Benjo is offline   Reply With Quote
Old 05-02-2011, 02:44 PM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
When the power goes out, it is nice just to pull the rope and get power. In that context, I'd recommend using sta-bil all the time just so the gas is already in it and it will keep the gas from fouling your carb.
Be sure you evaluate your storage area, though. For example, if you have a gas water heater or your furnace in the garage, then I would not want to store the genny anywhere nearby.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-02-2011, 03:36 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I find that fuel stabilizers are pretty good. I've gotten spoiled enough to the stabilizer that I never got around to draining the fuel from my mower at the end of the growing season last year... about 3.5 months later, it started on the second pull (usually it starts on the first.) If you follow the "start monthly" exercise recommendation and let it run for a while, I think it'll do well with fuel stabilizer.
David
Old 05-02-2011, 03:54 PM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I have used StaBil In my fuel supply,that being 2 /5 gallon plastic containers. I treat 5 gallons of gas with 2 oz of StaBil. I have chainsaws that have not been used for several yrs but I am satified if I go an crank on them they will start. I own a small engine shop and clean and rebuild carbs all the time. Most are gummed up from leaving untreated fuel in them when storing. I,myself have not cleaned or overhauled a carb for myself in 25 yrs of using StaBIL. I know I sound like a STABIL Commerical but the stuff works. MIX it only in the supply,DO NOT TRY to ADD it to the fuel tank. GOOD LUCK
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 05-02-2011, 03:54 PM   #5
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
When I know I won't be using mine for a while, I just drain the tank then run the gas out. However, I'm not sure this is good enough. On my big 3500 watt (loud) generator I have at the house for hurricanes, I have to drain the pot under the carburetor to really get the gas out. Learned that the hard way from congealed fuel.
On the Honda 2000, READ YOUR MAINTENANCE MANUAL. They call for an oil change every 30 hours. You'll be surprised how fast you can rack up 30 hours while boondocking for a couple of weeks (if that includes TV in the evenings, and lots of computer time.)
Failure to change the oil results in the red oil light coming on, and when you drain it, you find sludge!
But, you're right... great generator!
Hey, its the only way to be sure!
Tin Diesel is offline   Reply With Quote
Old 05-02-2011, 04:35 PM   #6
Benjo's Avatar
1949 18' Trailwind
Thanks for the recommendations, yall. I just talked with a Honda dealer in town and he recommended to NOT drain the existing gas out of the unit. He did say stabil is a great product to use but in the end he said to use the generator frequently to keep the fuel lines clear.
The only thing that kinda bugs me about the unit is the inconvenient oil changing drain. I think I'm going to have to come up with some kind of pvc jack leg setup to drain the oil out. I think they could of come up with something a little more innovative than a angled slide. Really? A slide. That is my only complaint and I'll get over it.
I also want to get some information on running it on propane. That is my ultimate goal and then we're gonna be in boodocking heaven!!! Can you sense my enthusiasm?
Thanks again forum friends!
Old 05-02-2011, 04:52 PM   #7
1973 31' Excella 500
Marysville , Washington
I intend to convert mine to propane. A Tri-fuel conversion is also an possible (gasoline, natural gas, and LP).
Not Done is offline   Reply With Quote
Old 05-02-2011, 05:13 PM   #8
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
STABIL, and start it up a run for ten minutes every month or so.
Ahab is offline   Reply With Quote
Old 05-02-2011, 05:43 PM   #9
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Reading the EU2000i Owner's manual, maintenance schedule on page 42, it says to change after the first 20 hours, then every 6 months or 100 hours thereafter.
Old 05-02-2011, 06:10 PM   #10
Mexray's Avatar
1978 28' Ambassador
Morada , California
We've used our e2000 for years when camping...
1. after initial break in period, I have used synthetic oil with great success - non of those 'sludge' issues...
2. when returning home and storing the unit, I 'now' always drain the fuel from the carb bowl, using the small screw operated valve and drain line that's provided...I didn't always do this, resulting in the evaporated fuel in the bowl - mixed with who-knows-what clogging the jet - a quick removal and cleaning cured the problem - but it could have been avoided by draining the carb before storage...
3. it was suggested by others here that it's better to run 89 octane fuel instead of the minimum 87 grade in these small gas engines - I switched a couple of years ago and believe it helps with the 'start on the first pull' routine...
4. a fuel stabilizer seems like a good choice if you store your unit for extended time periods - I've never used it, and it may have prevented my clogged jet problem, but I also think that draining the carb is an acceptable alternative...
I've nicked named our Honda the 'Red Lion' - it 'roars' when it's called upon to run the microwave, and 'purrs' like a kitten the rest of the time, charging our batteries!
Some products are just plain better than others - this is one of em', IMHO...
Ray & Pat; Morada, CA
Old 05-02-2011, 07:29 PM   #11
Benjo's Avatar
1949 18' Trailwind
I may give this a try too. Sounds like a good thing to know how to do. PErhaps there is a youtube instructional out there. I'm a visual person.
Thanks!
"2. when returning home and storing the unit, I 'now' always drain the fuel from the carb bowl, using the small screw operated valve and drain line that's provided...I didn't always do this, resulting in the evaporated fuel in the bowl - mixed with who-knows-what clogging the jet - a quick removal and cleaning cured the problem - but it could have been avoided by draining the carb before storage..."
Old 05-02-2011, 07:41 PM   #12
1993 21' Sovereign
Thanks!
The Mobil1 suggestion is a good one, too. I use it in ours.
Old 05-02-2011, 08:51 PM   #13
2019 27' Globetrotter
Missouri Valley , Iowa
Benjo,
My mechanic put us onto a product called Seafoam. We use it on the farm in our seed tender Honda power units, JD lawn mowers,and the ATVs. I have an '88 Yamaha 350 4-wheeler that was difficult to start, especially after sitting 4-5 months in winter. I began using Seafoam in the gas and if the battery is up, it fires immediately now. It is as good as Stabil for us.
Dan
Farmer Dan is offline   Reply With Quote
Old 05-02-2011, 09:00 PM   #14
Benjo's Avatar
1949 18' Trailwind
Okay, got some good suggestions there. Now I'm onto understanding the eco setting and what that is actually for? Can someone explain this simply?
Old 05-02-2011, 09:26 PM   #15
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
I stabilize my gas and then run the EU2000i dry before storing. Makes for easy starting time and time again.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 05-02-2011, 09:30 PM   #16
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Yep, that's what I do too!
Not sure if it makes sense, it seems a bit like belt and suspenders, but my thinking is that if any gas should remain in the tiny drillings of the carb after the engine stops when run dry, then at least it will have stabil in it and should be less likely to gum up.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-02-2011, 09:44 PM   #17
Belt and suspenders make a lot of sense to me. Sometimes I even rock the genny back and forth once it starts to sputter, hoping that whatever gas is left will definitely make into the combustion chamber.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 05-02-2011, 10:26 PM   #18
Mexray's Avatar
1978 28' Ambassador
Morada , California
Benjo...
You can get to the carb drain by opening the large access hatch on the side of the genny - you'll see the carb drain hose coming from the bottom of the carb bowl - you'll need a small blade type screwdriver to open the valve...I always leave the valve 'open', and the large access hatch screw, 'loose' to remind me to close the valve before using the genny again...
You would normally leave the Honda in the 'eco' mode (I call it the purr mode)...it's output in the eco mode is sufficient for most needs...when you need it's higher output, it automatically increases it's speed to handle the higher demand, going into 'purr' mode again when the higher demand has been turned off...IE, if you running in 'eco' mode and turn on your microwave, the Honda revs up to handle the load...
If you need the Honda to provide it's maximum output for a continuing high load, you can switch out of the 'eco' mode so it doesn't have rev up and down all the time - IE: when running a compressor to power some air tools where the compressor cycles frequently...
Old 05-03-2011, 09:48 PM   #19
pattimarty's Avatar
2011 25' FB Flying Cloud
Tenafly , New Jersey
Do you recommend getting an hour meter to track run time to know when to change oil etc.? If not, how to you keep track of when to do the maintenance specified in the manual?
Not sure this the right thread but if its OK .... Have any of you used an external fuel tank for more run time? Any experience or advice on that? We need to run A/C through the night and that seems like the only way (2000 i and companion).
Thanks.
Patti and Marty
www.RV4TheCause.org
WBCCI No. 1577, Watchung NJ Unit No. 068; TAC - NJ-4; Nova founding member No. 006
pattimarty is offline   Reply With Quote
Old 11-02-2011, 06:33 PM   #20
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
For me, the hour meter is cheap insurance. I put the meter on the EU2000i unit that I usually run alone (not the companion), but change the oil in both when it reaches 30 hr. We don't often need the output of two units running in parallel.
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 07:47 PM
Honda EU3000iS vs. Yamaha EF3000iSE/B pickerdd Generators & Solar Power 13 07-02-2017 10:47 AM
Best Prices on Honda Generators? gaylejoe Generators & Solar Power 51 09-05-2011 06:13 PM
Honda Generator Ramp Up henw Generators & Solar Power 7 04-17-2011 05:10 PM
Honda gen 2500H-Wont Idle Under Load marion macdo Generators & Solar Power 2 02-13-2011 09:21 AM
