Old 05-02-2011, 08:26 PM   #15
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
I stabilize my gas and then run the EU2000i dry before storing. Makes for easy starting time and time again.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 05-02-2011, 08:30 PM   #16
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Yep, that's what I do too!
Not sure if it makes sense, it seems a bit like belt and suspenders, but my thinking is that if any gas should remain in the tiny drillings of the carb after the engine stops when run dry, then at least it will have stabil in it and should be less likely to gum up.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-02-2011, 08:44 PM   #17
Belt and suspenders make a lot of sense to me. Sometimes I even rock the genny back and forth once it starts to sputter, hoping that whatever gas is left will definitely make into the combustion chamber.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 05-02-2011, 09:26 PM   #18
Mexray's Avatar
1978 28' Ambassador
Morada , California
Benjo...
You can get to the carb drain by opening the large access hatch on the side of the genny - you'll see the carb drain hose coming from the bottom of the carb bowl - you'll need a small blade type screwdriver to open the valve...I always leave the valve 'open', and the large access hatch screw, 'loose' to remind me to close the valve before using the genny again...
You would normally leave the Honda in the 'eco' mode (I call it the purr mode)...it's output in the eco mode is sufficient for most needs...when you need it's higher output, it automatically increases it's speed to handle the higher demand, going into 'purr' mode again when the higher demand has been turned off...IE, if you running in 'eco' mode and turn on your microwave, the Honda revs up to handle the load...
If you need the Honda to provide it's maximum output for a continuing high load, you can switch out of the 'eco' mode so it doesn't have rev up and down all the time - IE: when running a compressor to power some air tools where the compressor cycles frequently...
Ray & Pat; Morada, CA
Old 05-03-2011, 08:48 PM   #19
pattimarty's Avatar
2011 25' FB Flying Cloud
Tenafly , New Jersey
Do you recommend getting an hour meter to track run time to know when to change oil etc.? If not, how to you keep track of when to do the maintenance specified in the manual?
Not sure this the right thread but if its OK .... Have any of you used an external fuel tank for more run time? Any experience or advice on that? We need to run A/C through the night and that seems like the only way (2000 i and companion).
Thanks.
Patti and Marty
www.RV4TheCause.org
WBCCI No. 1577, Watchung NJ Unit No. 068; TAC - NJ-4; Nova founding member No. 006
pattimarty is offline   Reply With Quote
Old 11-02-2011, 05:33 PM   #20
mefly2's Avatar
2015 25' FB Eddie Bauer
For me, the hour meter is cheap insurance. I put the meter on the EU2000i unit that I usually run alone (not the companion), but change the oil in both when it reaches 30 hr. We don't often need the output of two units running in parallel.
Old 02-08-2012, 04:57 AM   #21
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
Thought I'd bump this thread because my Honda generator dealer suggested Sea Foam Motor Treatment for gas as a stabilizer. I found it at Napa for $10. The Sea Foam website recommends one ounce per gallon as a stabilizer for four-stroke engines.
JBinKC is offline   Reply With Quote
Old 02-08-2012, 05:47 AM   #22
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
A worthwhile 'gizmo....
Name:	PROPANE CONVERSION, HONDA 2000 005.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-08-2012, 06:28 AM   #23
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have used Sea Foam for years. It's a little less expensive at Wal-Mart. I think it's around $8.50.
Brian
SuEllyn & Brian McCabe
Old 02-08-2012, 06:29 AM   #24
dznf0g's Avatar
Oswego , Illinois
I run hour meters on both and made up a 6 gallon dual feed extended run tank from an outboard boat tank, fittings and line. I installed a filter and purchased the aluminum caps for the Hondas with a boat motor fuel fitting on each.
-Rich-
Old 02-08-2012, 06:41 AM   #25
dznf0g's Avatar
Oswego , Illinois
This is how I mounted my meters....it's a shameless home made version of a way too expensive of a mount I found online. Works well.
Name:	Hour meter 1.jpg
Name:	hour meter 2.jpg
-Rich-
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 06:47 PM
Honda EU3000iS vs. Yamaha EF3000iSE/B pickerdd Generators & Solar Power 13 07-02-2017 09:47 AM
Best Prices on Honda Generators? gaylejoe Generators & Solar Power 51 09-05-2011 05:13 PM
Honda Generator Ramp Up henw Generators & Solar Power 7 04-17-2011 04:10 PM
Honda gen 2500H-Wont Idle Under Load marion macdo Generators & Solar Power 2 02-13-2011 08:21 AM
