Old 06-27-2003, 01:09 PM   #1
2003 25' Safari
Eden Prairie , Minnesota
Honda EU2000i
I finally got off the fence and took everyone's advice and ordered a Honda EU2000i today - Mayberry's was out so I bought from Hicklin Power Systems in Iowa. The price has gone up from $859 to $899 delivered.
I'm in last-minute preparations for a trip - so Hicklin's availability, and the close proximity of Iowa to Minnesota for quick delivery, were factors. I hope it arrives by Wednesday!
Dan
dmac is offline   Reply With Quote
Old 06-27-2003, 06:18 PM   #2
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Congratulations, Dan. You're gonna love it. Just don't forget to fill it with oil when you unpack it. It comes with a dry crankcase.
Maurice
Old 06-28-2003, 12:09 AM   #3
Images: 53
Well, I WAS going to point any other folks to a place we got our EU2000i for $850 delivered last month(May), but upon reinspection I see that they also have increased to $895. Nonetheless, we did get a very smooth transaction from Alamia.com out of Colorado; quick ship and no problems.
Oil? What oil?
ps. I really DO try to spend my $$$ locally, but $1179? Three local dealers got an offer to pricematch (despite the tax issue) but none stepped up. Oh well.
KingPing is offline   Reply With Quote
Old 07-01-2003, 08:02 AM   #4
2003 25' Safari
My Honda arrived yesterday (wow - I just ordered it on Friday, UPS was fast). I added oil and gas and started it up. Initial observations:
- physically larger than it looks in pictures
- not as quiet as I expected, not terribly noisy either but the hoopla on the board about it's silence had my expectations set too high
- vibrates more than I expected, at least when not under a load
My next task is to see if I can find a Rubbermaid bin large enought to carry it in - so my Explorer doesn't get greasy or too smelly.
Dan
Old 07-15-2003, 12:39 PM   #5
Honda 2000
I am thinking of purchasing new 2004 AS 25' and would like to know just what to expect from the 2000 honda as far as what all will it power in this model?
desertone61 is offline   Reply With Quote
Old 07-15-2003, 12:43 PM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I will power most reasonable stuff, but you can't or shouldn't expect the Air Conditioning to really work and even if it did, you could damage it from what I understand if you don't have the correct amps going to it. I think it takes 2 2000s to be able to power the A/C unit.
Eric
Old 07-15-2003, 01:05 PM   #7
HURST's Avatar
I tried just one eu2000i to run my microwave, did not work! Had too go with two if we wanted to run the microwave or the AC.
One will charge batteries, run TV's and hair dryer but that about it.
I plan on putting them in Heavy Duty Contractor Plastic Bags. "HUSKY" 2mil, 32-35 gallon. This should help keep the smell down.
Capt. Charlie
1998, 34' Classic Excella 1000. WBCCI # 1901
'04 Chevy 2500HD CC,LT 4X4 SB,D/A. 45 gal fuel tank. Hensley Arrow, Guided by Garmin 2610 GPS. Twin eu2000i's
HURST is offline   Reply With Quote
Old 07-15-2003, 01:36 PM   #8
montanaandy's Avatar
Honda EU200i
The EU 2000 has a 1600 watt continuous rating which should be plenty to run the average microwave. What wattage is your microwave? I have a 600 watt microwave that I run without any problem but I make certain to not run too many other things simultaneously.
Does anyone know what the running wattage requirements are for an Armstrong AC unit (79' AS). Thanks,
Montanaandy
montanaandy is offline   Reply With Quote
Old 07-16-2003, 07:20 AM   #9
HURST's Avatar
With my set up I can measure the ampere of each appliance as I turn them on individuality. Here are my results.
Converter only------------------------ 2ampere
AC fan ONLY--------------------------- 3ampere
Refrigerator only---------------------- 3ampere
AC with fan on high only------------- 10ampere
Microwave only------------------------ 17ampere
When I tested the one eu2000i, I ran the first three items listed with no problem. But when I turned on the microwave it overloaded the generator, and the overload indicator light came on and all appliances shut down. I tried the microwave only and had the same results.
The Honda has a 13.3 ampere rating
So this is why I now own the twins
Capt. Charlie
Old 07-16-2003, 07:55 AM   #10
Vroom
Richard Vroom's Avatar
Mahone Bay
Images: 14
Honda EU2000
I have no trouble running the air conditioner on low setting as well at the TV and lights. Fine also for the coffee maker and even my wife's hairdryer. We love the generator as it does all I need it to do.
Sincerely,
Richard
Richard Vroom is offline   Reply With Quote
Old 07-16-2003, 12:27 PM   #11
Rubbermaid bins :
We were JUST talking about that!!
How big is the generator?
Are there any other good ideas for 'smell control'? The Rubbermaid bin idea was our top choice.
just starting to search!
darkStar is offline   Reply With Quote
Old 07-16-2003, 12:49 PM   #12
2003 25' Safari
I bought a Rubbermaid bin of around 40 gallons and the genreator fits inside. It works well at keeping the gas smell under control, and keeping things clean.
Dan
Old 07-16-2003, 01:01 PM   #13
Honda EU200i
Hurst:
I now see why you went with the dual approach based on your useage needs (yout are correct that the unit is rated @ 13.3 amps continuous and that you would need a second unit to run all of the things you listed simultaneously). This is the route that I plan to take once I am able to purchase a second EU2000i.
Richard: I would be careful running the AC on a single unit. You might be able to do it but it will shorten the life of the generator. I am surprised that you are able to get the AC to even kick in without overloading the generator. You have a newer AS and probably a more energy efficient AC unit than the power hungry Armstrong that I have on my AS.
Montanaandy
Old 12-25-2006, 08:08 PM   #14
Past Prez.NEU/Membership
AirHog's Avatar
2005 34' Classic
2015 Interstate Ext. Coach
N Smithfield , Rhode Island
Images: 21
Trouble starting
Merry Christmas and Happy Holidays to all!
Help........ we have a Honda EU 2000i with approx. 40 hours. It was purchased on 5/03 and looks brand new. I always put fuel saver in it and run the unit at least once a month for 15 minutes with some load on it. It started with no problem yesterday, but refuses to run more than a minute or so and then stalls. I made sure the fuel cap is on the ‘on’ position and the fuel tank is approx. 50% full. I have tried playing with the choke and it will start only in the closed position (to the right), but the moment I move the choke a wee bit to the left, it stalls. If the choke is in the closed position, it will stall in 60 seconds or so. I am baffled. The owners manual is NO help.
I hope this does not mean a trip to the local Honda dealer, because the carburetor or some other part has gone bad.
Any advice as to what to do will be greatly appreciated.
Regards,
Titu
T & Gail
2015 Airstream Interstate Ext
2005 34'Classic- Mercury (Goddess of Travel)
2016 GMC Sierra Denali 2500HD Diesel
WBCCI #2905-NEU
AirHog is offline   Reply With Quote
Honda Generator Mounting dmac Our Community 24 07-17-2016 09:46 PM
Honda EU2000i generator dhe9 Generators & Solar Power 4 04-12-2005 06:33 PM
Honda RV generator support mcneon Mechanics Corner - Engines, Transmission & More... 1 12-15-2003 07:20 PM
Honda 2000i generator wayner1239 Generators & Solar Power 22 02-28-2003 02:48 PM
