Old 12-31-2006, 10:52 AM   #29
CanoeStream's Avatar
St. Cloud , Minnesota
Originally Posted by moosetags
Reading the responses on this string, I can see that two EU2000i's will be necessary to run my air conditioner (13,500 btu unit). What I am now concerned about is running them on LP (my plan). Will LP fueled units be sufficient to run my airconditioning and other stuff.?
A strong 'yes' in response to your question, then I'll mosey around ... I put up links with some useful information here. Though the energy content of LP is less and there is a small loss of power, you should have plenty with parallelled eu2000i's. The consequence of not using the combined amperage of two eu2000i's will be strain and burning out of the compressor. I looked at a very bad Overlander once where the PO just used a 30A-15A adapter and burned out two A/Cs without knowing why -- assured me I could have an RV tech fix it, but the A/C was new... The highest demand is at compressor startup, then draw drops off a bit -- others have posted with some authority on this and I don't have the exact #s. One of the threads in my link above seems to give definite time limits before you'll exhaust your LP tanks though.
5 meter Langford Nahanni
Old 12-31-2006, 05:23 PM   #30
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Actually It might power the AC if it can get past the startup current. I have a Kill-A-watt meter hooked up to my trailer cord. I am currently plugged into my sisters garage. Batteries fully charged backgroud current about 3 amps.
Current draw with the AC running. about 12.5-12.7 Amps, new airconditioner.
The unit should be able to put out 16+ amps of power. 2000/120=16.66666
Michelle TAC MT-0
Sarah, Snowball
Old 12-31-2006, 06:00 PM   #31
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It's just that 20+ amp startup surge that would be the problem. I have a 13K Coleman, and IF I turn off the eco-throttle, and IF absolutely nothing else is on in the trailer, then I can get the A/C to start on the generator. And it isn't happy doing it, either. I have a 3600 watt generator that powers the A/C, and everything else I can turn on, in the Airstream, but it is noisy, and a gas hog (Briggs & Stratton, not Honda). Fuel consumption is .5 gal/hour, with a 1.1 gal tank.
Old 01-23-2007, 06:21 PM   #32
2000 34' Limited S/O
Jamestown , North Carolina
Honda EU2000i
We need to purchase a generator this model seems very popular. Someone on here previously mentioned the Yamaha EF1000i which runs on propane. I would appreciate some guidance on how to make the decision of which one would be the better purchase as the cost is similar.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 07-18-2007, 07:57 PM   #33
hookedonclassic's Avatar
Fond du Lac , Wisconsin
Just purchased a Honda Eu2000i locally. They had them on sale for $900 plus tax as part a sale promotion during the EAA (Experimental Aircraft) show in Oshkosh which starts on Friday for 10 days.
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
Old 07-18-2007, 10:24 PM   #34
schwabsters's Avatar
2007 20' Safari SE
Fairview , North Carolina
Do any of you have ideas for using the Honda 2000's in bad weather?
I don't want to expose ours to rain etc., and figure it will happen sooner or later....Some sort of mini-tent/cover etc.?
Regarding purchase, last December we were going to buy (2) EU2000I units and the parallel kit online, and were surprised that Camping World beat the best pricing I could find at that time. The Hondas were on sale for $950 each, and they threw in the 30A parallel kit (with built in ampmeter) and a DC
battery charge cable for free (total of $1993 including tax).
schwabsters is offline   Reply With Quote
Old 06-01-2010, 09:27 AM   #35
San Diego , California
Honda EU2000i won't start NO Spark
Hi There, I'm fix Honda EU2000i for a friend. The story I was told the unit ran out of gas and never start up again. Had good fuel and carburetor is clean and new spark plug was replaced.
I have NO spark. Anyone have service manual share
Thank you in advance
Sommay
sommay is offline   Reply With Quote
Old 06-01-2010, 11:09 AM   #36
Gator113's Avatar
2007 25' Classic
Port Angeles , Washington
Sommay
Honda Generator EU2000i User Manual | Free eBook Download
Gator113 is offline   Reply With Quote
Honda Generator Mounting dmac Our Community 24 07-17-2016 09:46 PM
Honda EU2000i generator dhe9 Generators & Solar Power 4 04-12-2005 06:33 PM
Honda RV generator support mcneon Mechanics Corner - Engines, Transmission & More... 1 12-15-2003 07:20 PM
Honda 2000i generator wayner1239 Generators & Solar Power 22 02-28-2003 02:48 PM
