Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 02-15-2006, 05:46 PM   #15
2airishuman's Avatar
Profile:
jim
there are several excellent threads on generators....and lots of posts from folks with the hondas that show customized installs , boxes and so on.
someone here has a shelf extending from each side of the tongue, with 2 hondas. another shows moving the lp tanks forward with space for the honda over the center.
you should search some for these threads....lots of great pictures too and you can explore your idea by reading what others reports works...or doesn't.
i would not want 30 gallons of gasoline attached to my trailer....anywhere.
besides the obvious safety issues this will add alot to the tongue weight and with 2 gen sets....your nose will be very heavy. also want to check the ncc for your trailer....it's not large.....and this install will eat some of it.
a cleaner approach i've seen reported here is to mount the gens in the bed of the truck with an wiring link to the trailer....still the issue of gasoline in the bed...
just how much generator power is needed....?
i don't run the a/c so 1 honda 2000 is enough. using it for morning & evening ac current needs and to recharge the batteries....only amounts to 2-3 hours per day max....and one gallon of gas will last many days....
cheers
2air'
Old 02-15-2006, 06:53 PM   #16
Wardinbb's Avatar
Profile:  1964 24' Tradewind
Big Bear Lake , California
Plenty Good Stuff
Jim,
First off I'd really consider the propane model. And please note that the spec for the Honda calls for 89 octane, which may be different than your TV.
Also the Yamaha's will adapt to LP/nat gas and retain the ability to use gasoline. My reservation about the Honda is once adapted to LP, that's it, can't go back to gas by turning a valve. And I agree with 2air above, the load and nature of the cargo on the tongue may not be the optimum configuration.
2air, thanks very much for the acoustic refresher. With your two finger typing skill, we all appreciate your effort. The fest I was at is helpful to bring a lot of things home. The Honda 2000 was very quiet and I will just guess here that to double up the sound, the Yamaha 2800 is still gonna be quiet with a capital Q. Like the article said, it's louder but well within campsite limits. And my anticipated use is similar to your actual experience. The other thing that I find appealing about the Yamaha 2800 is the 30amp outlet. As I've just installed this convention, it makes sense to me to have that direct connection without an additional electrical pigtail adapter. Those puppies can get pricey!
So ain't it the truth, I've got all the logical conclusions and still sittin' on the fence! I should shop at Camping World more often, where they don't list specs or details and ya just buy the darn thing and go see if works for you later!
Ed
Wardinbb is offline   Reply With Quote
Old 02-16-2006, 08:14 AM   #17
JimGolden's Avatar
Profile:  1977 31' Excella 500
Some good points guys. What about an Onan diesel powered one then? I know diesel isn't volatile like gasoline and so would be safer. Another question might be how long can you run 4000 watts (two ofthe Hondas) on a 40lb propane bottle?
I was just thinking that gasoline or diesel is much less pain to get than filling the LP bottles. And if I had a 30 gallon tank, I'd fill it once and be good for all season most likely. I really didn't think it'd be dangerous as it'd be far away from the stove.
2Air, showing my lack of knowledge here, but what is the NCC? Is that a gross weight rating? If I proceed with this, I will be going to a heavier frame with a higher gross weight rating than the original. I want to be able to carry my KLR650 a rear carrier. I know that's verbotten with the 4" flexi-frame, but with the one I've designed, it'd be no problem at all. No monococuqe stresses on the shell anymore. That would take some weight off the tongue, though it would be less than the 330lbs that the bike weighs. The gen sets and a spare tire would regain that while still being less than what my truck could handle. I'd have to work the weight and balance, but if it was too heavy without the bike on back, I could probably put the spare on the back.
- Jim
JimGolden is offline   Reply With Quote
Old 02-16-2006, 08:51 AM   #18
vajeep's Avatar
Profile:  1976 27' Overlander
Richmond , Virginia
Images: 49
Jim,
We have the 2x EU2000 Honda's. I don't think that we used over 10 gallons of gas for the summer. We had one trip to Bristol NASCAR race in August were we had to run both for most of the weekend. We try to go to cooler places where we do not have to run both. With out the A/C we only run the one for about an hour or two for the battery. Or if we need the toaster or if Mama needs to blow dry her hair...
I don't like storing gas for long. Not sure if this has any merit, but we always empty our gas can back into the Burb before we leave.
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
WBCCI# 7627 / VAC
Air #2798
vajeep is offline   Reply With Quote
Old 02-16-2006, 10:53 AM   #19
Profile:  2003 25' Safari
Eden Prairie , Minnesota
NCC is Net Carrying Capacity.
If you are thinking of placing a 330 lb motorcycle on the back of an Airstream trailer... the moment arm to the axle is huge (say 330 lbs * 10 feet = 3,300 ft lbs!) You must be planning on a monster frame substitution! Even so, I wouldn't do it! Placing two Hondas (~100 lbs) on the front would help balance this, but the stress on the trailer is immense.
Dan
dmac is offline   Reply With Quote
Old 02-16-2006, 12:18 PM   #20
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
JimGolden, there is about 9.5 gallons of propane in a 40 Lb bottle. I find the propane to be less of a pain then gasoline. No spillage, or leak problems. Don't have to worry about gas can falling over and spilling. I have a 34 gallon propane tank in the bed of my truck, gives me lots of EU2000i runtime!!
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 02-16-2006, 01:15 PM   #21
JimGolden's Avatar
I was planning to put dual 40's on the front, so maybe the LP powered job is the way to go.
Looking at 8" deep I-Beam frame, 1/8" wall section with 2" flanges. Full depth angle cross members. I calculate it will add about 200lbs to the weight of the trailer, but the frame is then about seven times stronger than the original one. It'd be good for a 15,000 lb gross weight easily. Realistically it'll probably never see 10,000lbs on it, but it'd be plenty strong for anything I want to do.
Hey, do I get three rivets now?
- Jim
Old 02-16-2006, 01:57 PM   #22
Profile:
hi jim and others.....
bham, bham, bham.....there are your rivets!
reads like you are gonna build a siMON STERn GARAGE trailer....go for it!
might want to start a thread to document this trailer...like many of the rehabers do...these are some of the most viewed on the site....a great learning tools.
ncc is basically how many lbs of stuff can be carried in the trailer....after fluids/lpg are added.
in addition to the frame you're suggesting, you'll need newer torsen axles, with a higher load rating...they make a 5000lb-5500lb axle......not sure about higher....also higher rated wheels, tires and brake to stop it....
that stuff, along with the frame and genset gear...will cost at least as much at the original purchase... right guys? anyone?
except for the rear bath and front kitchen models, usually a/ss have been built with most of the mass over or near the axles.... your plans will add significant mass to the 2 ends...which will effect handling, ride and so on...even with a reinforced frame.
if you are going to the degree descirbed......might as well opt for larger fresh and holding tanks....at least that will bring some mass back to center....and really by time you need a genset....the 3 fuel models/lpg options will be more established....
and don't forget the class V hitch and the top kick to pull it......
i can see the thread now....
"the adventures of the jim's mon'stream"
don't forget the pictures...
cheers
2air'
Old 02-20-2006, 02:09 PM   #23
Shepstream's Avatar
Profile:  2008 27' Safari FB SE
Auburn , New Hampshire
I've had my EU3000 for 2 summers now. Flawless, quiet, uses less fuel than you think, esp when it spools down at low load. The factory AC atop my Safari makes more apparent (perceptual) noise than the generator. Only gripe is it is a bit of a grunt to place and remove from the pickup truck. On the plus side, fits nicely under the tailgate, and the tailgate make a good rain shield.
Now if someone could tell me how I can make the sound of the air conditioner fan inside much less apparent, I'll be in sonic Airstream heaven!
Shepstream is offline   Reply With Quote
Old 04-02-2008, 08:51 PM   #24
Cincinnati , Ohio
Suggestions For 1st Generator
What would you suggest? Starting out with one Honda eu2000 and seeing if it will do the job or going to 2 Hondas running parallel
jhohe is offline   Reply With Quote
Pingbacks are On
Honda EU 3000 vs 2x Honda EU 2000 vajeep Generators & Solar Power 78 06-30-2008 07:30 AM
SEO by vBSEO 3.1.0
