Our choice of an EU3000 has worked out really well for us for several reasons, including:
* Easy connection to our 27 FB power point by a short 10' (for low ohmic loss) quick-disconnect 125/30A cable.
* Easy rigging of the EU3000 in the back of our truck, for safe operation
And it is really quiet in eco-mode. Even though our heads in the FB are just a few feet from the generator, the sound of the AC Fan on low is more noticeable than the generator, even when the compressor is running. ... I'm all about it being quiet - and the best time is when the generator is off all together. But if you ask me, the noise pig in the trailer is the AC unit itself when operating on low. My 2 cents!
If you look at 2air's post #12...the sound level may be something to consider as a down side with the "Handi"...also, looking further at the spec's, one thing that I wonder about is the AC Output rating of 2600...or is that a problem with a 13.5k AC? I'm still waffling on what is the best thing to do.
__________________ TB & Greg...and Cockers Annie & Sadie
AirForums #21900 . WBCCI Four Corners Unit #3954 Décor Site: AZBambi Décors
Hi, for the Honda people having either one or two 2000's is still the best bang for the buck. The new Handi 3000 is quite a bit louder and costs almost twice as much as my Yamaha 2400. If you are going to pay that much, you should buy the regular Honda 3000 and get a larger engine, larger gas tank, electric starter, quieter operation, [more for less] and keep the much heavier generator in your truck. Or if you want one generator that's quiet, fairly light, will run your A/C, and is blue, buy the Yamaha 2400. [my opinion]
Thanks for your input, Bob...I'm learning that the Yamaha 2800 is a viable option as well...a friend of ours swears by it... We're getting closer to making a decision ... all of your various inputs/opinions have been quite useful...thanks!
Just as a prior poster noted, the new Honda is rated at up to 65 DB, and this is 7 DB louder than the Yamaha 2400. The 2800 Yamaha is also in the mid 60 Db range. The new Honda will run for 7 hours at 1/4 throttle....so that means when it is 100+ in AZ, you will have to fill it up every two hours?
I analyzed all the data a couple years ago...went with the Yamaha 2400 with the tri fuel option from US Carberation. Runs so smooth (on propane), so quiet, and it will run my AC (13.5k) all night on a tank of gas and a whole lot longer than that on a tank of propane!
__________________ Hi Yo Silver, Away 2005 28' International CCD
2007 Chevy Silverado Classic 2500HD Duramax
Equal-i-zer/Prodigy
I think I will consider propane operation. Its been my experience with tow-motors that propane fired engines last longer. Oil changes are less frequent because propane leaves no ash behind to dirty the oil. DO I understand that Honda does NOT offer a propane capability.???
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER KA8LMQ AIR # 22336
My your roads be straight and smooth and may you always have a tailwind!
