Old 06-26-2008, 05:48 PM   #15
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Glad you found the problem. Our EU3000 runs our Penguin 15k just fine.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 06-26-2008, 05:50 PM   #16
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by kstampa View Post
GOOD NEWS, Those of you concerned about your generators need not worry any longer. DKDarrow's comments got me thinking more about the cord (thank you). Upon closer examination I discovered that one of the prongs on the 30 amp cord was a little loose and the rubber around it slightly melted. I cut the male end off and rewired it with a kit from camping world. Fired up the Honda and turned the AC on high and tstat maxed cold. Purred like a kitten! No more problems! Thanks everybody!
While I haven't noticed a problem with my Yamaha 3000SEB powering my 13,500 BTU Penguin, I have the same problem with slightly melted rubber around the prongs. I plan on going to the Marinco marine type of power cord sometime this summer.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-13-2008, 11:44 PM   #17
rbkhale's Avatar
2005 25' International CCD
dublin , California
Go Honda 3000
This is a great genset. Don't forget to check oil level with each tank of gas, and change oil (I use synthetic) after 50 hours of operation. Also, I turn the gas off whenever I stop my honda. This keeps the gas from sitting in the carb and going bad.
rbkhale is offline   Reply With Quote
Old 07-14-2008, 10:30 AM   #18
Yorktown , Virginia
We're former motorhomers who have finally seen the light and are planning to purchase an Airstream....we always enjoyed having the convenience of an onboard generator and want the same with a trailer. Am also about to buy a Honda 3000 for "hurricane" emergencies with an eye toward using it with the trailer. Two questions:
(1) Do any Airstreams today have on-board generators? (Think the answer is no but a propane powered set wouldn't be an impossibility)
(2) If no to the above where do most folks carry their generators? I'd love to have a pickup truck but don't relish having to buy a new vehicle just to safely transport the genset.
Thanks in advance....look forward to being an Airstream owner soon!
KL0S is offline   Reply With Quote
Old 07-14-2008, 10:44 AM   #19
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
Hi KLOS and welcome to the forums....
The answers are:
1) - No, but I have seen a few units (some vintage) put a small generator built under the goucho run on propane. Very slick but lots of custom fabrication work.
2) - Most carry in the back of a pickup. If you get a inverter 3K from Honda or Yamaha, they are heavy. Some use 2 Honda 2000s in parallel which weigh much less and easily transportable. I went with a Yamaha 3000 propane conversion and carried it with my Excursion using a front hitch. Nilesrob had this similar setup before me with his Excursion and Honda generator as well.
http://www.airforums.com/forums/566065-post3.html
http://www.airforums.com/forums/f448...vel-38912.html
Any way you go, your gonna love the Airstream you get....
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 07-14-2008, 10:53 AM   #20
Beneath the title
jnerges's Avatar
2005 28' International CCD
Mount Pleasant , South Carolina
Glad to hear a bad plug was the culprit. Seems to always be something small causing something big. We went with the 2 2K's from Honda and the bridge kit. Boondocked this weekend at an Airshow and it got really hot, we worried about the dog. Turned the AC on high, fridge running on electric, fired those puppies up and had a great time. The dog enjoyed herself too.
They are great gens because you can carry the 4K set up in stages, one at a time. Very happy with ours.
John
Aunt Gladys, 28FT, Intl'
"Man, it's hot here, is the heat on?"
jnerges is offline   Reply With Quote
Old 07-16-2008, 06:45 PM   #21
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
This thread anwered my questions about a generator. I thinking along the Honda line but someone suggested to me about linking 2 Honda 2000 units. I have a 25 foot Safari Sleep Six and next year when we go out on our 3 month trip I am going to have a generator.
gaylejoe is offline   Reply With Quote
Honda 3000is Just Purchased valvestem Generators & Solar Power 62 08-26-2011 12:11 PM
Wheels For Honda 3000is valvestem Electrical - Systems, Generators, Batteries & Solar 1 06-29-2007 08:16 AM
off-topic question: Honda 2004-5 Recall codybear Off Topic Forum 0 02-05-2007 06:35 PM
2004 International CCD andyfuson 2002 - 2005 International 31 11-15-2004 09:14 PM
