Old 09-01-2011, 02:08 PM   #15
Annandale , New Jersey
thank you.
joeru is offline   Reply With Quote
Old 09-01-2011, 07:07 PM   #16
2011 30' Flying Cloud
Arvada , Colorado
The external tank works with the 3000 Handi. I've used it. But, it should not be set too high above the genny - somewhere within the plane of the genny's top.
Jack46 is offline   Reply With Quote
Old 09-02-2011, 07:57 AM   #17
I have a EU3000i HANDI but not an EU1000i or EU2000i. Is the gas cap the same for these models?
Old 09-02-2011, 09:23 PM   #18
MrAgent007's Avatar
2006 22' International CCD
Hershey , Pennsylvania
Images: 21
Handi 3000
Originally Posted by BAB BMRZ View Post
UAPachyderm & MrAgent007
Were you able to find resolution for this problem. Although I've never had to get up in the middle of the night, I would like a longer run time.
Tnx Lyle & Margie
Hello, the only configuration of external tank that will work with the Handi is when the external tank is elevated above the Handi so the fuel is fed by gravity. The Handi does not contain a fuel pump therefore the external tank unless it is elevated will not work. Academically speaking, the Handi was a great concept generator except for an important feature that was left out, an extended run time. Perhaps the next generation Handi inverter generator from Honda will contain greater fuel capacity.
Alex
MrAgent007 is offline   Reply With Quote
Old 01-08-2014, 11:02 PM   #19
T Reno's Avatar
1991 29' Excella
Colorado , Colorado
I scored a used HONDA EU3000I HANDI generator today of Craigslist for an awesome price! Need an update on what people are using for the EXTENDED FUEL SOLUTION on these generators? Not worried about warranty as I bought it used, more like a demo unit in awesome shape but want to have the extended run time with bigger fuel solution...
I have the Honda EU3000I but its a beast to load by myself.....
T Reno is offline   Reply With Quote
Old 01-09-2014, 01:56 AM   #20
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Seems a major on line Generator seller sells the extended run tanks for the Honda 2,000 watt pair with never a mention of a warranty issue. That sounds like bovine byproducts to me.
I empty the generator on board fuel under heavy load. Refill in a minute and restart. No cool down time. The warranty is now void?
In a power outage situation with adequate gasoline on hand, the unit could be running 24 x 7.
Old 01-09-2014, 06:01 AM   #21
Arvada , Colorado
At one time I owned a 3000i Handi, but sold it for a couple of reasons - weight and limited storage capability while traveling. I had purchased a six gallon external fuel tank from Honda Portable Generator, EZ Flow Extended Fuel System, Dallas, Fort Worth. As others have mentioned, it worked with the 3000i as long as the external tank is set more or less on the same plane as the genny.
As an aside, I ended up with two 2000i's which is the best solution for me. Good luck and congrats on your purchase.
Old 08-17-2014, 06:20 PM   #22
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Just checking in to see if this is still the best option for extending the fuel supply for a EU3000I (Handi). The 80 lL unit with wheels and extendable handle.
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 08-18-2014, 07:20 AM   #23
robert@honda's Avatar
Alpharetta , Georgia
Originally Posted by MrAgent007 View Post
The Honda 3000 handi apparently does not have the built in diaphram fuel pump in the carb and therefore no vacuum is created to draw in fuel from a tank located lower than the generator.
The Honda EU3000i Handi is a gravity-feed fuel system, and does NOT have a fuel pump.
A couple of other Honda models (EU2000i, EU1000i) do indeed have diaphragm/vacuum type fuel pump. I'm not aware of any aftermarket external tank systems that do work on generators without a fuel pump.
Robert@Honda
Social Media Consigliere
Caveat: I work for Honda, but the preceding is my opinion alone.
robert@honda is offline   Reply With Quote
Old 08-18-2014, 07:22 AM   #24
dznf0g's Avatar
Oswego , Illinois
I have read that the extended run tanks work without a fuel pump if you elevate the external tank above the level of the internal fuel tank.
-Rich-
Old 08-18-2014, 07:40 AM   #25
Tincampers's Avatar
Sneedville , Tennessee
There are several videos on youtube about making an external tank work with a generator with no fuel pump.
Tincampers is offline   Reply With Quote
Old 08-18-2014, 08:21 AM   #26
Arcticfox's Avatar
Central , Canada
Looking on the net, it seems like a simple enough system as long as you set it up and use gravity to feed the tank. Gosh I might even have a spare outboard motor tank kicking around. The trick will be to find a gas tank top that will fit the generator. anyone got any ideas?
TKS
Doug
Old 08-18-2014, 08:41 AM   #27
dznf0g's Avatar
Oswego , Illinois
Although my Hondas have fuel pumps, I made my extended run tanks by using an outboard tank I had, a new outboard fuel line with primer bulb, a line tee, additional fuel line, a fuel filter, outboard connectors and the aluminum caps sold for this purpose. Less than half the cost of the commercial system, as I recall.
-Rich-
Old 08-18-2014, 08:49 AM   #28
Arcticfox's Avatar
Central , Canada
Hi Rich:
you don't happen to has a photo of the rig you built do you? also would you remember where you got the alum gas cap?
TKS
Doug
Honda EU3000i Handi jsvetrano Electrical - Systems, Generators, Batteries & Solar 26 08-29-2015 09:50 PM
Honda Handi EU 3000i 63air Generators & Solar Power 35 02-28-2010 01:32 PM
Honda EU2000 x 2 vs Honda EU3000 and Yamaha 3000 IntegrityAir Generators & Solar Power 43 07-01-2009 11:19 AM
Honda EU3000i Handi Wayne&Sam Generators & Solar Power 0 05-20-2009 09:21 AM
