Old 06-25-2007, 11:17 AM   #1
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Honda 3000 DIY wheels - Save $$
There are probably others who have done something similar, I wanted to post photos and info for others to use if so desired.
I bought 2 castor wheels, less than $10
I bought a length of 2"X2" aluminum tubing and cut to length with a bevel on each end - see photo. Using self tapping hex screws I attached it all to existing brackets, re-attached two rubber feet to the aluminum tubing and I was done. Total cost less than $40.
The hardest part was making sure the generator was secure while I worked under it. I didn't want to win the annual Darwin award.
Dave
ID:	39865   Click image for larger version
Fyrzowt is offline   Reply With Quote
Old 06-25-2007, 02:58 PM   #2
Turtle's Avatar
2004 16' International CCD
Arcata , California
I like it! I'm off to my friendly Ace Hardware store for supplies. Now I need someone to come up with the cheap and easy hoist for getting the darn thing into the back of the truck. Jamie
Turtle is offline   Reply With Quote
Old 06-25-2007, 03:06 PM   #3
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
Dave,
Thanks for posting this. I don't have a Honda generator, but a contractor model I keep at the house for power outages in the winter.
I cut a peice of 3/4" plywood for a platform and mounted some castor wheels to it to roll it in and out of the garage but the plywood is developing a nice bow and doesn't roll all that well anymore. Your idea may work for me.
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 06-25-2007, 04:19 PM   #4
Fyrzowt's Avatar
2000 25' Safari
Images: 8
That's my next project/purchase. A ramp to get it into the truck.
Old 06-25-2007, 05:10 PM   #5
2003 25' Safari
spokane , Washington
honda on wheels
I went the "off road" route, makes it very easy to load, just heft it up, get one wheel on the bed and it rolls in from there. Also amkes it very easy to roll around once on terra firma. Ran the lock through the tunnel the "axle" (a length of allthread) is in.
Jack
wasafari is offline   Reply With Quote
Old 06-25-2007, 05:13 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by wasafari
I went the "off road" route, makes it very easy to load, just heft it up, get one wheel on the bed and it rolls in from there. Also makes it very easy to roll around once on terra firma. Ran the lock through the tunnel the "axle" (a length of allthread) is in.
Jack
What speed rating are the tires? Are they load range C or D? Are the axles torsion allthread axles?
Old 06-25-2007, 05:23 PM   #7
Fyrzowt's Avatar
2000 25' Safari
Images: 8
Terry you just opened a can of worms. Now I'm wondering if the ones I installed need to be balanced.
I like the off road tire idea, the ones I installed won't roll in soft dirt if boondocking. One of the things I was concerned about is getting the center of gravity too high. Wasafari, any problems or tendencies with that?
Dave
Old 06-25-2007, 06:33 PM   #8
2003 25' Safari
high polar moment
nope, doesn't want to tip at all, it's also very easy to "turn", just a little up pressure in the rear, a slight drag in the opposite direction and it turns on a dime.
Old 06-25-2007, 10:32 PM   #9
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Good ideas guys.
I like the gig tires for boondocking but I also like the way Dave has a "dead axle" to keep it from rolling away. I'll probably do a kinda combo of both.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 06-26-2007, 06:42 AM   #10
lewster's Avatar
Naples, FL , Hood River, OR
Winch
If you want to use a ramp and winch combo to pull that 300 lb. beast up into your pick-up bed, Northern Tool has a neat little 12 VDC winch with a rated 1700 lb. of pulling power.
I just installed one in my van to pull my 500 lb.motorcycle in as you can't ride it or walk it in due to space limitations. It would work great with a generator. I would post a shot of it but it is currently burried under a bunch of stuff in the van. I'll get a shot of it next week when I unpack.
It is a Warn winch and IIRC, was $79. So far it works great! Couple it with a couple of cheap fold-up ramps and you're done!!! BTW, it also has reverse to lower the gen DOWN the ramp!!!
Old 06-26-2007, 10:38 AM   #11
Fyrzowt's Avatar
2000 25' Safari
Images: 8
One further consideration if you put large wheels on - You will need to remove the wheel on one side to open the side panel for access to the air cleaner. Make sure you mount the wheel on that side with a cotter or other removable pin.
Lewster, I like the small winch idea, especially for those with physical limitations.
I know your tongue was firmly in your cheek, but for the un-initiated, the Honda 3000 weighs about 145#, not 300#.
Dave
Old 07-16-2007, 07:07 AM   #12
B25guy's Avatar
2003 25' Safari
Yakima , Washington
Images: 20
My wheels on Honda eu3000is
This was relatively easy to fab, just about 8" of 2"x2" angle and some scrap 3/16" plate and a couple of $8 wheels from Northern Tools. Used all existing bolt/holes and didn't add weight after removing the original feet bracket (seen in photo). Access door opens a fully.
Marc
Name:	Gen wheels 1.jpg
ID:	41266   Click image for larger version
Name:	Gen wheels 2a.jpg
Name:	Gen wheels 3a.jpg
B25guy is offline   Reply With Quote
Old 07-13-2013, 12:56 PM   #13
1994 30' Excella
Canyon , Texas
Nice, I like the wheel set up you fabricated, I think I'll try that. What size are the wheels you used?
Tyler
tyler is offline   Reply With Quote
Airstream Wheels JAG Wheels, Hubs & Bearings 10 06-01-2006 08:54 PM
Airstream steel wheels davidz71 Our Community 5 05-23-2002 07:50 AM
Airstream steel wheels davidz71 Wheels, Hubs & Bearings 0 05-21-2002 05:18 PM
Best wheels & Tires... Andy R Wheels, Hubs & Bearings 4 04-15-2002 10:41 AM
