Old 10-05-2003, 03:26 PM   #15
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Jerry's right. The converter will do a better job of charging than the DC output on the Honda. Just plug the trailer's power cord into the adapter cord that goes to the twist-lock connector on the generator, and start the generator up.
While it's charging, you can use the 120VAC things in the trailer.
The trailer has a converter in it that charges the batteries, as well as supplies the 12 volts for the lights, fans, etc in the trailer when you are plugged into 120VAC electrical powre (so that isn't coming out of the batteries).
Maurice
Old 10-05-2003, 03:50 PM   #16
Turtle's Avatar
2004 16' International CCD
Arcata , California
Jerry and Maurice, Thanks for the info. I get it now. Just wish I was brave enough to use the EU2000 on my air conditioner...Jamie
Turtle is offline   Reply With Quote
Old 10-05-2003, 04:11 PM   #17
Raptorrider2001's Avatar
Richardson , Texas
Images: 14
Jamie - You can run the ac on your Bambi with the 2000. I run the 11k on my 25' Safari. Just run the refrig on gas. It is marginal but it works for me. See my post above where i installed a quick start kit and it really made a difference.
'99 25' Safari
2 Honda 2000i generators
'08 Chevy Duramax
'01 Yamaha Raptor ATV
'07 Yamaha Rhino ATV
2 burgler alarms: Rotweiller and Shepherd
"If you step down to get in, you have to step up to get out"
Raptorrider2001 is offline   Reply With Quote
Old 10-05-2003, 04:57 PM   #18
2001 34' Limited
The State of , Ohio
"Brave" wouldn't be my choice of words, Jamie. You did the right thing for both your generator and air-conditioner by selecting the 3000.
Maurice
Honda Generator Mounting dmac Our Community 24 07-17-2016 09:46 PM
Honda EU2000i dmac Generators & Solar Power 35 06-01-2010 11:09 AM
Honda RV generator support mcneon Mechanics Corner - Engines, Transmission & More... 1 12-15-2003 07:20 PM
Installing a Honda 4010/6010 generator PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 11 03-06-2003 06:19 AM
Honda 2000i generator wayner1239 Generators & Solar Power 22 02-28-2003 02:48 PM
