Old 02-26-2003, 01:42 PM   #1
Honda 2000i generator
I am looking for the smallest generator available that will run a 11,500 btu duotherm air conditioner. The honda eu2000i looks good to me and I am hoping that someone has tried it on a 11,500 btu unit. (I have read that it will not run the 13,500 btu unit). I pull a 21' sovereign with a Ford Expedition and have very limited space for a generator. If the honda will work I plan to put it inside a plastic box and store it in the expedition to use only when electricity is not otherwise available.
Wayne
wayner1239 is offline   Reply With Quote
Old 02-26-2003, 02:09 PM   #2
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Dunno about the AC, but keep in mind these are air-cooled engines. Make sure that plastic box is louvered or otherwise well ventilated.
Maurice
Old 02-26-2003, 02:13 PM   #3
Obsessed with Moonunit
COArgosy78's Avatar
1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 55
I don't know the answer either, but this company keeps coming up as best for sale of the EU2000i in price. Maybe they can answer the ????
http://Mayberry sales & service, Inc. Leigh
COArgosy78 is offline   Reply With Quote
Old 02-26-2003, 03:48 PM   #4
Thanks. I sent an email to Mayberry but I am not optimistic that they will know for sure. I plan to use the plastic box just for storing the unit in the Expedition. I will take it out when it is running.
Still hoping someone has tried the honda on the smaller, 11,500 btu, a/c.
Wayne
Old 02-26-2003, 04:44 PM   #5
2001 34' Limited
The State of , Ohio
Check this out.
Maurice
Old 02-26-2003, 07:18 PM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I've tried my 13,500
In the low 80's with the fan on low. But to know the whole story, you need one of these:
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-26-2003, 07:24 PM   #7
That link was just what I was looking for. Thanks. I figured someone had tried the 2000i on a smaller a/c. Appears that it may run my a/c for a while under certain conditions but should not be relied on for that purpose. I have never been to an airstream rally but hope to in the future. From from what I read there is not enough electricity to power air conditioners at some of those rally locations. I wonder if most people just suffer through the heat or if they have generators that will power their air conditioners.
Wayne
Old 02-26-2003, 07:37 PM   #8
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
Wayne, "Rally Power" as it is known is only 3.25 amps! A 15 amp quad outlet is split between 4 Airstreams. Folks with generators have to go to a seperate areas, I am told.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-26-2003, 07:50 PM   #9
2001 34' Limited
The State of , Ohio
Something to keep in mind. The motor in the compressor is wound with very thin wire with ultra-thin insulation coating on it.
During startup, there's a LOT of current going through it, and it's heating up rapidly. The more it heats, the more that insulation breaks down. Slow startups, due to inadequate power, extend the time that high current is heating the windings, so it gets hotter, for longer. Slow starts can lead to premature death of a compressor.
Maurice
Old 02-26-2003, 10:43 PM   #10
APB
APB's Avatar
Escondido , California
AC current
According to my '78 service manual the current varies with temperature, fan speed and voltage. The TRH 25-12 (12k btu?) shows compressor amps @13.6A for 115degrees F ambient and total watts of 1945 @ 115v. This is running power and it dosen't discuss starting current. Same conditions but 105v results in 14.6 compressor amps.
There are not figures for low cooling range or indications of starting current. Starting current can be 3-4x the operating load.
APB
Bluegrass is flat picking good!
APB is offline   Reply With Quote
Old 02-27-2003, 09:31 AM   #11
Well, what you all say makes sense. It stands to reason that low current will cause heat build up that could destroy the a/c.
Pick, I like the picture of the honda with some sort of device showing the "whole story" but don't know what it is. Can you explain? You can tell I'm green.
APB, I like your "bluegrass" signature. Have you heard the U.S. Navy Band (Country Current) play? I heard them at Ocean Lakes Campground at Myrtle Beach last fall and they are great!
Wayne
Old 02-27-2003, 10:34 AM   #12
APB
APB's Avatar
Yeah Wayne I have heard of them. They are playing at Parker next weekend but I won't be able to see them. Too bad I hear they are very good.
APB
Old 02-27-2003, 12:12 PM   #13
cljackson's Avatar
Send a message via AIM to cljackson Send a message via Yahoo to cljackson
Generator
We live in Texas, and it gets ,really hot here, so we're thinking a generator may be a necessity, not an option, during the summer.
We're also considering having Fantastic Fans installed. How much good will these do? Should we go ahead and start shopping for a generator now?
Cheryl
Montgomery, TX
cljackson is offline   Reply With Quote
Old 02-27-2003, 12:40 PM   #14
We sell music at Bluegrass festivals, and have been seeing them for a long time, several times a year. They do not charge promoters anything to play, only their traveling expences. So I guess, the taxpayers are paying for that. For years, they were not allowed to have a recording for sale to defray their expenses. (they were telling the audience to borrow it from the library and tape it. Really smart move from who ever was in charge of this Budjet !!!).
They now (in 2001 I think) have a recording available under the name Country Current called "Navy Blue Bluegrass" (they had an older recording under the name: "Appaloosa"). You should hear them when you have a chance. Very clean sound, a lot of original songs well liked by their audience.
I guess this had not much to do with generators. To make up for it: we have the Honda 3000i & the 1000i too. Really great machines. The 3000i weighs 135Lbs though (5 times the weight of the 1000i). You can link a 1000 and a 2000 Honda, quite costly but that would work.
Chantal
femuse is offline   Reply With Quote
Honda Generator Mounting dmac Our Community 24 07-17-2016 10:46 PM
Honda EU2000i generator dhe9 Generators & Solar Power 4 04-12-2005 07:33 PM
Honda RV generator support mcneon Mechanics Corner - Engines, Transmission & More... 1 12-15-2003 08:20 PM
Honda 2000i generator Testimonial Raptorrider2001 Generators & Solar Power 17 10-05-2003 05:57 PM
Installing a Honda 4010/6010 generator PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 11 03-06-2003 07:19 AM
