Old 02-27-2003, 12:14 PM   #15
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
wayner1239
The device in the pictures is a clamp on ammeter, available at any electrical supply house, HD, Lowes, etc. To operate it has to be clamped around ONE of the conductors. It will NOT work clamped around the ENTIRE CORD or CABLE. This device will tell you exactly how much current you are pulling, be it from a generator or grid power. AC current will vary depending on how hard the compressor is working. The hotter the outside temperature, the harder the compressor works to keep the inside of the AS cool.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-27-2003, 05:15 PM   #16
Les Gilliam's Avatar
Hi Pick
Do they make a clamp on ammeter for DC as well?
Les
Les Gilliam is offline   Reply With Quote
Old 02-28-2003, 06:17 AM   #17
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
There is no such thing as a clamp on ammeter for DC. You have to use something inline, or with a shunt.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-28-2003, 06:27 AM   #18
I was afraid of that. Thanks for the info.
Les
Old 02-28-2003, 06:42 AM   #19
LOST , Hawaii
Hall effect sensor clamp meters will measure dc current. The ones that measure ac only use transformer input.
John
74Argosy24MH is offline   Reply With Quote
Old 02-28-2003, 08:25 AM   #20
my experience
I ran the 2001i all last summer on my 1979 Excella 31. It did fine as house power when the A/C is not running; when it is, it cannot keep up with the load.
They make a cable so that two can be run in tandem, and that is attractive. The unit is easily manage by my petite spouse, is very easy to start, quiet, and miserly on fuel. I'd rather have two of these in tandem than one big unit. Mayberry's price has terrific, and I'm planning to get the second one from them this summer.
Bill & Jeanne Miller
78 Excella 31 CB
St. Louis
wvmiller is offline   Reply With Quote
Old 02-28-2003, 11:45 AM   #21
Bill, thanks for your comments about your experience with the 2000i. It would be hard for me to handle a big heavy unit so 2 in tandem would be better. I did notice somewhere that the cable to connect them was over $200 plus I believe there was another device required. I wonder why those cables are so expensive.
Chantal, you said that the 2000i and the 1000i could be run parallel but that it was costly to connect them. Does anyone know if they connect the same way and with the same cables as two 2000i units? The 1000i unit would probably give me all the power I need without the a/c.
Wayne
wayner1239 is offline   Reply With Quote
Old 02-28-2003, 12:46 PM   #22
Rickk48's Avatar
Bigfork , Montana
Don't know about connecting 1000i and 2000i but if you do a bit of searching for the cable to connect two 2000i you should be able to find it under $150.00 including the 30 AMP receptacle plug
Rick Klein
Seeking another Bambi
'08 Honda Ridgeline
Rickk48 is offline   Reply With Quote
Old 02-28-2003, 02:48 PM   #23
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
The Honda manual says that only two generators of the same size can be connected together. Mayberrys has experimented with this and come up with the suggestion to do unlike sizes together. For the time being, I'd stick with the Honda recommendation.
The paralleling cable is just a Y of the hots and a Y of the commons and a Y of the grounds all to a 30A receptacle. Some have done this with the male ends of extension cords joined together in a junction box, but if one plug comes out of a generator, the prongs will be hot from the other generator.
The Honda setup use shrouded banana plugs, but as someone else on the net discovered, there's no polarity on these and you can plug them in out of phase. The inverters in the generators are smart enough to compensate for this, but it results in you being able to be shocked on the neutral line. The Honda cable also terminates in a 30A twistlock receptacle, so you also need a dogbone to plug into it and give you a 30A RV female receptacle.
Probably the best solution is to make up your own paralleling cable with a junction box RV 30A receptacle and some 10 gauge wiring using these plugs with red for the hot leads and black for the neutral.
WRT to EU1000 vs EU2000. If you want your generator to have a long life, you really shouldn't run it at more than 75-80% load. If you want your generator to run at lower rpms and be quiet, you want your usual load to be a fraction of its maximum. An EU2000 doesn't cost much more, or weigh that much more than an EU1000, and will be working much less hard, and at lower rpms, with the same load that would have an EU1000 working near maximum. Given the same load, the 1.0 gallon tank of the EU2000 would also outlast the 0.6 gallon tank of the EU1000.
[on edit] Keep in mind an 80% efficient converter charging two batteries at 20A each will be drawing about 5A at 120V... and if lights, etc are on with a 55-60A converter, this could max out the EU1000.
Finally, an EU2000 owner has scanned his manual and put it on line here.
Hope all this helps,
Maurice
Honda Generator Mounting dmac Our Community 24 07-17-2016 09:46 PM
Honda EU2000i generator dhe9 Generators & Solar Power 4 04-12-2005 06:33 PM
Honda RV generator support mcneon Mechanics Corner - Engines, Transmission & More... 1 12-15-2003 07:20 PM
Honda 2000i generator Testimonial Raptorrider2001 Generators & Solar Power 17 10-05-2003 04:57 PM
Installing a Honda 4010/6010 generator PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 11 03-06-2003 06:19 AM
