Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 10-06-2004, 10:08 AM   #1
crazylev
LEV ZEPPELIN
crazylev's Avatar
Profile:  2004 19' International CCD
Chicago , Illinois
Honda 2000 @ 128-129volts....
Greetings.
While testing out my Honda 2000 a few weeks ago, I noticed that the voltage was running a little higher than when plugged in to shore power.
The little AC volt meter that I got from Camping world ussually reads around 115-120 on shore, but with the Honda, it's closer to 128-129.
Is this normal?
Thanks.
Jonathan
I'm out of my mind right now, but will be returning shortly......
crazylev is offline   Reply With Quote
Old 10-06-2004, 10:13 AM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Plug something into the generator - a desk lamp or whatever is handy. Then read the voltage. You need to see what the voltage reads when there is a load (it does not need to be a BIG load) on the generator.
Tom
Old 10-06-2004, 10:25 AM   #3
crazylev
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Hi Tom.
I had the trailer plugged into the honda, some lights and and fans running in the AS. I have the tester meter thing plugged into one of the 110 outlets in the trailer. So there was a load on the Honda.
Thanks.
Jonathan
Old 10-06-2004, 10:34 AM   #4
markdoane
Profile:  , Minnesota
Images: 59
The extra 12V is from the battery?
Ha ha - made you think about it, tho.
Non-contributing deadbeat.
Old 10-06-2004, 10:35 AM   #5
TomW
TomW's Avatar
Normal , Alabama
Images: 77
Originally Posted by crazylev
I had the trailer plugged into the honda, some lights and and fans running ...
I personally would rather see closer to 120 vac, but I think most ac devices are rated for 130 vac.
Check your owner's manual for the generator. It should list the output voltage. If it is supposed to be less than 130 vac, borrow another, better voltmeter & check it before visiting the service department.
Tom
Old 10-06-2004, 12:36 PM   #6
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
More voltage means less current.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 10-06-2004, 06:42 PM   #7
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
I just fired up my EU2000i, and it's putting out 127V, no load, eco throttle on. Eco throttle off, rpm's rise, and the voltage went to 127.9V
I use a wavetek DM-series meter. It's not a precision instrument, but fairly accurate.
I do not think that you've got anything to worry about.
Uwe
Old 10-07-2004, 08:48 AM   #8
crazylev
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Agian, thanks for your posts.
Uwe, thaank you for running your generator. I feel more comfortable knowing that this is common with at least two generators, yours and mine.
We are excited about our trip.
Jonathan
Honda EU 3000 vs 2x Honda EU 2000 vajeep Generators & Solar Power 93 07-23-2008 11:02 AM
Honda 2000 polarity screwy??? crazylev Generators & Solar Power 4 09-19-2004 12:29 PM
Time for that second Honda 2000 Raptorrider2001 Our Community 2 06-17-2003 05:57 PM
Honda 2000 smoking on start up Raptorrider2001 Our Community 3 04-05-2003 01:17 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
