03-14-2016, 11:22 AM
#41
Alamo Heights
Originally Posted by Zybane
Ya, but I wasn't talking about voltage. Just simple cabling. Your Airstream with the basic Honda cable is only plugged into one generator and one outlet. So basically its one cable (RV) connecting to one generator, then one cable connecting one generator to another generator. Series.
Apparently there is a true parallel kit out there that splices in-between the two generators that actually pulls power directly from both generators in parallel. This way you can pull the entire power capability from both generators which doesn't happen to the single socket amperage limited connection you get with the basic advertised parallel (series) connection. That one's purpose is almost fully negated by the outlet limitation of a single generator.
There are 2 ways to get the full combined output of the 2 Honda 2k generators. If your 2nd generator is the "Companion" model, it has a 30A outlet on it and will deliver the full continuous output of the pair (around 27A if you're near sea level.)
If you have 2 of the standard Honda 2ks you'd need the parallel kit that includes a 30A outlet and costs a bit more than the cable that combines the 2 generators, and is like the competitive brands use for paralleling their 2k units.
However, in BOTH cases described above, the generators are operating in parallel, providing more current than either one can on its own and outputting 120v (nominal). In the scenario you described, your max output on any one outlet is limited by the capability of the outlets and/or circuit breaker, which would be about 20A (they're 20A sockets on the Honda 2k, with a 20A breaker.) It's labeled 13.3A at 120v because that's the continuous output of one of the Hondas, but if you are running in parallel with just the basic cables between 2 standard units you'd have the full 20A available.
— David
04-21-2016, 12:37 PM
#42
2012 22' FB Sport
2003 19' Bambi
Port Townsend
Originally Posted by Kellycanoe
<snip>
I'd like to do a quick battery recharge once a day. I like the lower weight of the Honda 1000i, but will it take much longer to do the job than the 2000i? Thanks!
How 'bout it math and electron wizards? Run the numbers for us!
I don't have a generator or solar at the moment. I upgraded to two LifeLine 6 volts, 220 amps. First time out, I spent four days/three nights and I'm at 12.7 volts. I think that's about 75%, so I used about 50 or 60 amps.
With the PD9260C, how long would the 1000i and/or the 2000i have to run to fully recharge the batteries?
04-21-2016, 12:47 PM
#43
2012 22' FB Sport
2003 19' Bambi
Port Townsend
Originally Posted by NWGetaways
... I'm at 12.7 volts. I think that's about 75%, so I used about 50 or 60 amps.
Correction: 12.5 volts
04-21-2016, 12:52 PM
#44
2008 25' Classic
Full Time
I know when my batteries are run down that low, my PD4655 on shore power stays at 13.7-13.8v for a long time before switching to float at 13.2V. I don't think you can fully recharge batteries with a generator unless its run for a long time. The last 20% charge of a battery takes the longest time of the charge cycle.
Kelvin
04-21-2016, 10:24 PM
#45
1974 Argosy 26
Morrill
, Nebraska
Honda 1000i or 2000i?
You converter is a 65 amp at 12 volt unit. That is the max output. 780 watts. Figure it to be about 85% efficient.
The 1000 watt or any generator are not designed to run at full load continuously. They are rated somewhere around 800 watts continuous for the 1000 watt unit.
If you require 780 watts of power to recharge the batteries the 1000 watt generator will not do the trick at least on paper. The converter will require around 950 watts of power at full capacity when you figure in the losses.
I doubt you will ever require the full 780 watts of power to charge the batteries. But the additional power required for items like the water pump, general lighting, furnace etc. could tax the ability of the generator.
With careful power management during the charging period the 1000 watt unit may work.
If you want to just start the generator and not be concerned about the load then go with the 2000 watt unit.
04-22-2016, 12:03 AM
#46
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
The 1000 watt model puts out half the power of the 2000 watt model. It took our 2000 watt Honda over three hours to recharge the OEM lead acid batteries in our 2013 25FB International Serenity after the furnace ran intermittently all night. The batteries were down to about 50% despite the low power draw LED lights.
The factory single rate converter can cook the battery fluid after many hours of high rate charge, so checking the electrolyte level in the afternoon would be wise.
The dealer installed 155 watt solar panel on our unit was a sad joke. But that is another story.
04-22-2016, 07:01 AM
#47
1974 Argosy 26
Morrill
, Nebraska
Doubling the size of the generator does not mean the battery(s) will charge in half the time. It's a matter of chemistry and physics.
One should note when you connect a battery to a portable charger the current (amps) is relatively high when first connected. As the battery charges the amount of current decreases due to the internal resistance of the battery changing as it charges.
This is not a process you can rush. You can however damage a battery by overcharging it with a single stage charger or converter.
04-22-2016, 07:34 AM
#48
2012 22' FB Sport
2003 19' Bambi
Port Townsend
Thanks for the insights everybody.
I thought it was a fairly straightforward calculation - e.g. My 25 gallon fresh water tank would take 25 minutes to fill at a rate of one gallon per minute.
If a 1000 watt generator can't recharge my batteries, why would 100 watts of solar be a good idea?
04-22-2016, 08:32 AM
#49
2002 30' Classic S/O
Fleming Island
100 watts of solar is not a good idea, imo. A solar system should be sized to replace all the energy you use on a daily basis with some margin added for cloudy days. In my case that worked out to around 300 watts.
But you can't just go by watts or amps, you have to factor in the time. 300 watts of solar for 6 hours is 1800 watt hours which is roughly equivalent to the Honda 2000 run for an hour. To some extent the solar system is actually supplying the power you use during the day, and at the same time recharging the batteries for what you used at night.
Al
04-22-2016, 08:50 AM
#50
2016 30' Flying Cloud
Oviedo
Kelvin
The Progressive Dynamics converters run at 13.7 VDC after a power cycle based on time, not battery charge level. In fact, I suspect that ell of the transitions between output level states are time based.
I wouldn't assume it takes that long to charge your battery just because the converter doesn't ramp down to float.
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
04-22-2016, 11:26 AM
#51
2012 22' FB Sport
2003 19' Bambi
Port Townsend
No wonder I'm confused. This all is beginning to sound like a black art.
Let's say I've been drawing 8 amps for four hours. I'm now down 32 amps from a full charge. If the generator/solar panels/rat on a wheel feeds 8 amps into the system it will take <Your Answer Here> hours to charge, no?
04-26-2016, 09:24 PM
#52
Central
, Mississippi
No wonder I'm confused... If the generator/solar panels/rat on a wheel feeds 8 amps into the system...
There is the error, the battery typically won't "take" a consistent charge, it drops off as it gets closer to full. My 40A charger slacks off to under 5 amps pretty quick, then takes hours to reach 100%. The rat gets tired and slows down the closer he gets to the finish line.
My generator will take 3 hours to recharge batteries that have seen a 1 amp pull, all day, from various phantom loads including the fridge. A small solar panel that feeds a few amps all day will offset that load and keep me from 3 hours of Hondahumm.
Just last week I dry camped 6 days, ran loads at night and awoke to 88-90% batteries in the morning (20AH used). With 200W of solar it would seem I could recharge in a couple hours of sun. Because the system couldn't accept all 200W, it was 5-6 hours before I was at 100%
But it was a quiet 5-6 hours...
Back to the OP's question...my camp neighbor had a1000W Honda and due to some goofy wiring in his trailer, we had to unplug his fridge to keep it off of AC but allow the charger to work. He ran it ALL NIGHT ( thus my all night use of a 12volt fan)
04-27-2016, 03:29 AM
#53
2014 31' Classic
Apache Junction
The other truth is that the advertised wattage for a solar panel is derived in a laboratory under non-existent real world conditions. Thus the real output is about 75% of the rating. I have eight 100 watt solar panels on the roof of the Classic now (plan on one more and if space is available two more 100 watt panels) and on a bright day see 575 watts. We are charging a 600 amp-hour lithium battery.
A top quality 100 watt panel may put out about 5.5 amps of power. So over four hours of sunshine, there would be a total of 22 amps provided per 100 watt panel. Two panels could generate 44 amps in the same time period. If 60 amps were used over night by the furnace and other equipment, the same panels could provide 66 amps with six hour of bright sunshine, but because the charge rate tapers off for non-lithium batteries, so they might not become fully charged is six hours. Also, the usual 12Vdc power will continue to be drawn so not all power is going into the battery charge process with examples being the control circuitry for the water heater and refrigerator along with the ever present propane leak detector.
We have five 100 watt panels on the roof of our 2015 23D (no space left for another panel) and they are charging a 300 amp-hour lithium battery.
The advantages for a lithium battery is the ability to safely provide 85 to 90% of the power rating and charge at the full capacity of the power source. Our 300 amp-hour battery is about 14" x 16" and weighs 84 pounds, which is less weight then the two stock Interstate battles we removed. While the 600 amp-hour battery weighs 168 pounds, it replaced four Lifeline model 6ct (6Vdc @ 300 amp-hours) batteries that weighed 92 pounds each plus a the weight of a custom stainless steel enclosure on the tongue of the Classic. The four Lifelines could safely provide only 300 amp hours (i.e. 50%) out of the 12Vdc and 600 amp-hour wiring configuration.
So one must do some serious research on the power requirements to properly size the battery capacity and then the solar and generator power to recharge the battery system in daylight hours since most RV parks want no noise after dinner and before breakfast. In the middle of nowhere, the noise could be all night if there is adequate fuel for the generators.
04-27-2016, 07:25 AM
#54
2012 22' FB Sport
2003 19' Bambi
Port Townsend
This is great info!
Let me ask another: for non-lithiums the conventional wisdom is to keep the batteries above 50% charge. Is there any harm in only charging up to the point where they are taking the full (relatively rapid) charge? If that's 90%, then operate the batteries in the 90% down to 50% range?
Or is it necessary for battery health to always bring them back to 100%?
(Switz, it sounds like you have enough power to run a tanning salon. )
04-27-2016, 08:26 AM
#55
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
This is great info!
Non-lithiums need a full recharge. Otherwise the cells inside the sealed battery get out of sync (SOC changes). This happens naturally over time, which is one of the reasons we equalize a battery once a month too with better battery charging systems.
Otherwise, you are going to significantly shorten the life span of the battery.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
04-27-2016, 09:06 AM
#56
Tavares
Thanks to the OP for starting the thread. Great info.
My wife and I were discussing the whole 'buy a gennie or go solar' issue this week when we suddenly found ourselves boondocking in an RV park that lost power.
We have a '16 27' FC with two Interstate wet cell batteries. Sorry if I missed the answers to these questions:
Is there a good link somewhere to the charging specifics (current required over time to go from 50% to 100%) to get the batteries charged?
Secondly, where might I find a good reference for power consumption of common appliances (furnace, lights) etc.?
Lastly, just to make sure, can I convert Watts to Amps based on W = I * V i.e. a 1,200 W hair dryer in a 120V outlet will consume 10A of current?
Thanks!
Rich
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
04-27-2016, 01:28 PM
#57
2012 22' FB Sport
2003 19' Bambi
Port Townsend
Rich,
Here's the stages that Progressive Dynamics chargers use:
BOOST Mode 14.4 Volts - Rapidly brings the RV battery
up to 90% of full charge.
NORMAL Mode 13.6 Volts - Safely completes the charge.
STORAGE Mode 13.2 Volts - Maintains charge
with minimal gassing or water loss.
EQUALIZATION Mode 14.4 Volts - Every 21 hours
for a period of 15 minutes prevents battery stratification
& sulfation - the leading cause of battery failure.
This thread has some good info on power draw:
http://www.airforums.com/forums/f37/...ch-147944.html
04-27-2016, 04:46 PM
#58
Naples
Voltage provided by a charging source is only half of the equation. The other half that has not been mentioned is the AMPERAGE that your charging source is capable of sending to your batteries.
Different battery chemistries accept and require different amounts of amperage for full and complete recharging.
Lifeline AGMs can easily handle 1C (1 times the battery bank capacity) or more but they really like a slower, consistent charge of C/5 or 20% of their capacity.
Lithiums can handle a much greater input amperage for charging and never need to be at 100%, as they will not show 'sulfation', or sulfur crystal growth in the plates like lead batteries will if they are not completely recharged to 100% soon after discharge since there is no surfer in a LiPo battery.
ANY standard 'smart' converter will almost never place 100% ( or close to It) of it's charging capacity into your batteries during re-charging. This means that a converter rated at 55 amps will almost never apply all of that amount into your battery bank, requiring extended charging times.
Inverter/ chargers like Magnum have an easily programmable charge rate setting where you CAN apply up to 100% of the charger's rated output to your batteries. It even shows the charge level and charge rate on the ME-RC remote.
Something to think about...........
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
lewster
04-27-2016, 05:03 PM
#59
2012 22' FB Sport
2003 19' Bambi
Port Townsend
Thanks Lew.
So - if I had a Magnum, what *would* you set it to for two LifeLine GPL-4CTs?
04-27-2016, 06:23 PM
#60
Naples
Thanks Lew.
Depends on the model. I would set the ME-RC for 'AGM1' which is the Lifeline-specific charge profile.
Then if you want to follow the C/5 regimen, you would have 220 amp/hour capacity so C/5 = 44. I would set the charge rate for the MMS-1012 @ 90%. MS-2012…….50%, MS-2812 & MSH3012-M…….40%.
All of the above charge rate settings will give your chosen battery bank a 45- 50 amp charge at the pre-set voltages recommended by Lifeline and adjusted for temperature compensation IF you have the included temperature sensor properly attached to the battery bank.
lewster
