Old 11-27-2002, 09:29 AM   #1
Les Gilliam's Avatar
Help on solar panel installation
I finally found a solar panel that will mount on the roof and attach at the roof support ribs. My question relates to the proper sealer to use between the roof and the support brackets. The panel came with "Mastic Sealer Compound" and is supposed to be good for all types of RV's. I know most people recommend Vulcum (sp?) or par bond for most Airstream repair jobs, but I don't know about a sealer for solar panel installation. Also, how should the screws be sealed? The instructions imply that the Mastic Sealer Compound will seal the screws also.
Finally, how deep into the Airstream roof should the screws penetrate? I have to modify (or make new) mounting brackets since the ones that came with the panel are not long enough to allow for the curvature of the roof.
Any help would be appreciated. HAPPY THANKSGIVING TO YOU AND YOUR'S.
Les
Les Gilliam is offline   Reply With Quote
Old 11-27-2002, 09:51 AM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Screws
Even at a rib. there is no more than 1/8" of aluminum. Any longer screw is just going to penetrate air. As long as the maximum diameter of the screw threads fully engage the roof, there is no need for longer screws. I would probably choose 3/8" or 1/2" screws depending on the bracket thickness.
I'm a belt and suspender guy and would probably put a dab of sealer on the screw heads. On the roof of my trailer, that's what the factory did.
John W. Irwin
WBCCI #9632
Old 11-27-2002, 08:21 PM   #3
SilverStreaker's Avatar
Thanks for the info, John. The screws that came with the panels are quite long. I will get shorter ones and will probbly go with stainles steel.
SilverStreaker is offline   Reply With Quote
Old 11-27-2002, 08:28 PM   #4
It just dawned on me that I used my wife's computer to answer your post so I probably confused you. I had better sign this one.
Thanks again,
Les
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
Best Solar Panel recommendations please! westeagle Generators & Solar Power 2 11-16-2003 11:31 AM
Solar Panel Mounting JaceBeck 1999 Safari 2 02-26-2003 03:55 PM
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 10:22 AM
