06-27-2011, 05:41 PM
Mini Rivet
1975 25' Tradewind
Holland
, Michigan
Help my solar controller caught on fire
Please help,
I recently installed a SunSaver 6 solar controller and this past weekend after having been set up for camping for a few hours all the 12 volt power went out. I leisurely moseyed on back to the fuse panel see what had happened, as soon as I opened the bathroom door I could smell burning rubber. I opened the closet door to get at the fuse panel and smoke billowed out, I opened the door to the fuse panel and all I could see through the smoke was bright electrical sparks and fire at the solar controller.
I had my brother go unplug the camper and I just starting yanking wires out of the solar controller, even after pulling wire, unplugging and removing fuses the solar controller just keep on burning. I had to leave after that, I couldn't hold my breath any longer and I could not breathe through the smoke.
When I finally go back in the camper to survey the damage there wasn’t much, the solar controller looked a little charged. I would have thought with that much nasty stinky smoke the controller would be completely melted.
Any way what the hell did I do wrong to make this thing have a melt down.
Below are photos of the box and a schematic of the wiring.
Would much appreciate your help on this
My first thread on this matter
06-27-2011, 06:33 PM
Mini Rivet
1975 25' Tradewind
Holland
, Michigan
By the way I didn't blow a single fuse
06-27-2011, 08:31 PM
1999 34' Excella
Joshua
Your charger maybe sized too small.....the better ones on the market are...
Morningstar Corporation » TriStar MPPT
History doesn't repeat itself, people do!
06-27-2011, 08:35 PM
2008 27' Classic FB
1959 22' Flying Cloud
fairview
, New Mexico
It looks like the load wire is the one burnt. Why would you have a load on a 6 amp system? I doubt that you would have much of an excess of power. That amount of solar is just enough for one battery and none to spare.
Avion C11
1959 Flying Cloud 1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
06-27-2011, 09:03 PM
steel/aluminum fabricator
2004 22' International CCD
Penticton
, British Columbia
I think something shorted out behind the sunsaver plate.
06-27-2011, 09:22 PM
More than one rivet loose
Los Alamos
, New Mexico
The Sunsaver 6 is only meant for 6 amps. You do not wire a load in the a trailer. The load comes off the battery. The way you have it wired your DC load runs through the Sunsaver. Hence the "fire"
Michelle TAC MT-0
Sarah, Snowball
06-27-2011, 09:30 PM
1974 27' Overlander
Sault ste Marie
, Ontario
Your running the entire 12V load through the charge controller, I don't really think that's the way to do it. T'was mine, I'd run the load for the fuse panel from the positive bus and just have the charge controller feed the bus. That way, heavy power demand will come directly from the batteries and not through the controller.............Phil.
06-27-2011, 10:07 PM
Mini Rivet
1975 25' Tradewind
Holland
, Michigan
Thanks everyone for the information, as you can see I know just enough to make me dangerous.
I think my controller , 6A, is of the right size, here are the specs to my solar panel.
Module Catalogue Number BP250/1 BP250/2
Typical Peak Power (Pmax) 50.00W
Voltage @ maximum power (V mp) 17.00V
Current @ maximum power (I mp) 2.94A
Short-circuit current (I sc) 3.22A
Open-circuit Voltage (V oc) 21.20V
Here is how I believe it should be wired, please correct me if I am wrong.
06-28-2011, 09:59 AM
Los Alamos
, New Mexico
That looks much better. You should have a fuse in the line from solar panel to the Sunsaver and a fuse from the Sunsaver to the main buss. The solar panel fuse should be near the solar panel.
If you plan to add more panels you should look at a much larger controller.
I have a Morningstar Tristar PWM 45A controller. I am running just under 20A at full sun. It runs nice and cool.
Michelle TAC MT-0
Sarah, Snowball
03-22-2016, 06:16 PM
Boardman, OR
, Oregon
Why would he put a load on a 6 amp system? why wouldn't you? how else does he use the low voltage disconnect if he didn't? the failure was from the charge controller, the OP did nothing wrong.
03-22-2016, 06:20 PM
Boardman, OR
, Oregon
I wouldn't listen to these guys, if you connect straight to the battery than you no longer have the low voltage disconnect to protect your battery bank from being destroyed. you are supposed to wire it to your charge controller which you did so you did nothing wrong. the fault is only through the controller and nothing else, 6A was just too low and the controller is a POS, I have the 10 A version used with a 100 watt mono panel connected to a 2/0 cable which used to be for my car's sub amp, it didn't fail for the few months I used it.
03-22-2016, 08:33 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We used the Morningstar TriStar 60 MPPT controller in the Classic with 800 watts of solar panels. We will add another 100 watt panel in May. The Blue Sky 3024iL is sufficient for the five 100 watt panels on the 23D. We sized the solar charge controller and associated wires to the output of the solar panels.
03-22-2016, 11:00 PM
2015 30' Classic
Pleasanton
thecatsandi is correct, you shouldn't connect the load to the battery. Doing so probably causes current to flow through your solar controller and not directly from the battery.
Another problem I see is that you do not have adequate clearance to allow proper air circulation as required in the manual. Either you should relocate your controller or open up the top of the enclosure to allow airflow.
The controller you selected should work fine once you get a replacement
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
03-23-2016, 12:14 AM
ottawa (greely)
, Ontario
Maximum load 6-10 amps ,you have how many 20 amp fuses +other fuses on the load side !no wonder it melted! Plus we need to know wire sizes, and were they come from ,I think we need the wiring schematic from the manufacture. As I think it can be wired different to work but all loads should come from the battery not the charge controller ,I think this controller has a feature ( load side ) to control a small load such as a ( one ) light or fan 6 amps or maximimum 10 depending on model, also you need to due a better job of wiring as I see you have a wire insulator part touching metal your just looking for it to rub through ,this is a trailer going down bumpy roads .also you have the jumper in for a sealed type battery this jumper must be removed if your charging a flooded lead acid battery as there is a different charging voltages for sealed versus flooded,this didn't cause your problem ,but could be another down the road.
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
03-23-2016, 06:15 AM
Naples
Has anyone noticed the date of the original discussion??
lewster
03-23-2016, 06:57 AM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
I was wondering why someone dug up this ancient post.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
03-23-2016, 07:55 AM
ottawa (greely)
, Ontario
The snowball only gets bigger as you roll it in the fresh wet snow ! What a mess wiring and snowball! Thank Lewster or pointing out the date
03-23-2016, 09:29 AM
Biloxi
, Mississippi
New post was made by a new member starting out by insulting other members and apparently not reading the entire thread. Go figure.
MICHAEL
03-23-2016, 10:37 AM
Nomadic
, USA
He should fit right in then.
Also he used a cable from his "car's amp" which means he's a knowledgeable expert.
See, just keeping the snowball going here.
03-23-2016, 10:47 AM
Naples
Not my place to comment on the OP's wiring job....... I leave that to you guys!! :-))
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
lewster
