Old 03-24-2016, 11:02 AM   #29
ottawa (greely) , Ontario
Originally Posted by eksine View Post
I didn't attempt to insult anyone. As far as I know since I have almost the same controller is that the load is shown connected to the controller in the instructions. It should be the same for any controller. If you connect all of your loads directly to the battery what is to prevent you from going below 12 volts or whatever the voltage is when you're battery is damaged. Also fyi I attached a solar panel to the car roof. The sub wire as you said is 1/0 or 2/0, more than enough for 100 watts. This power wire comes directly from the battery fused with a 130 or 150 amp fuse. I also didn't claim to be an expert on anything, I read it from the manual u butthead
When you get into better inverters you can program them to shut down at specific voltages to prevent damaging your batteries ,they sometimes have built in battery chargers when there is a lack of solar ,they also can be programmed .the charge controller its main job is to charge the batteries as fast as possible without damaging them and maintenance charge for desulfication,the better charge controllers have many settings that can be changed for different types and brand of batteries , there are lots of info on Northern Arizona wind and Suns website, check it out!
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Solar Panel Question marvinr Generators & Solar Power 2 09-20-2011 04:06 PM
Seeking Feedback: solar solutions for full-time telecommers burnsdl Generators & Solar Power 7 08-19-2011 02:31 PM
I'm confused, where do I wire in solar controller bmklawt Generators & Solar Power 7 06-19-2011 11:22 PM
How much solar do I really need sgoetz Generators & Solar Power 12 05-19-2011 08:28 AM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
