Old 03-23-2016, 06:15 AM   #15
lewster's Avatar
Naples, FL , Hood River, OR
Has anyone noticed the date of the original discussion??
Old 03-23-2016, 06:57 AM   #16
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I was wondering why someone dug up this ancient post.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 03-23-2016, 07:55 AM   #17
ottawa (greely) , Ontario
The snowball only gets bigger as you roll it in the fresh wet snow ! What a mess wiring and snowball! Thank Lewster or pointing out the date
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 03-23-2016, 09:29 AM   #18
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
New post was made by a new member starting out by insulting other members and apparently not reading the entire thread. Go figure.
MICHAEL
Old 03-23-2016, 10:37 AM   #19
Nomadic , USA
Thumbs down
He should fit right in then.
Also he used a cable from his "car's amp" which means he's a knowledgeable expert.
See, just keeping the snowball going here.
Old 03-23-2016, 10:47 AM   #20
lewster's Avatar
Not my place to comment on the OP's wiring job....... I leave that to you guys!! :-))
Lew Farber
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
Old 03-23-2016, 01:29 PM   #21
2015 30' Classic
Pleasanton , California
Next time I'll read the ENTIRE thread before contributing to the insanity!
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 03-23-2016, 05:16 PM   #22
1998 30' Excella 1000
Livingston , Texas
Originally Posted by switz View Post
The Blue Sky 3024iL is sufficient for the five 100 watt panels on the 23D. We sized the solar charge controller and associated wires to the output of the solar panels.
It's been quite some time since I sized the solar for my off the grid cabin, but I recall that code required that the controller had to be 125% of the panel rating to account for the potentially higher output during cold temps, snow reflectance, etc. Assuming your panels put out 5.5 -6.5 amps each at STC, have you cut it too close with a 30 amp controller?
Siegmann is offline   Reply With Quote
Old 03-23-2016, 05:43 PM   #23
lewster's Avatar
The Blue Sky 3024iL is 40 amps @12VDC, which is how his panels are connected. 30 amps at 24VDC.
Old 03-23-2016, 09:11 PM   #24
dznf0g's Avatar
Oswego , Illinois
Don't most modern controllers have the ability to clamp excess amperage?
-Rich-
Old 03-23-2016, 09:35 PM   #25
lewster's Avatar
They do have the ability to run over capacity (up to their stated limits) and then 'clip' the output to the designed maximum. Could possibly be a waste of watts left on the roof if the array is too large, but that was a discussion in another thread.
Old 03-23-2016, 09:45 PM   #26
Livingston , Texas
You know way more about this then I do. So I'm confused that I found this statement in Blue Sky's manual for that controller:
"Do not connect to a PV array capable of producing greater than 32A short circuit current for 12V nominal PV modules, or 24A short circuit for PV modules greater than 12V nominal. Limit input short circuit current to 12A if the 24V input 12V output mode is used".
It's on page 2:
http://www.blueskyenergyinc.com/uplo...E_SB3024iL.pdf
Old 03-24-2016, 08:09 AM   #27
Boardman, OR , Oregon
I didn't attempt to insult anyone. As far as I know since I have almost the same controller is that the load is shown connected to the controller in the instructions. It should be the same for any controller. If you connect all of your loads directly to the battery what is to prevent you from going below 12 volts or whatever the voltage is when you're battery is damaged. Also fyi I attached a solar panel to the car roof. The sub wire as you said is 1/0 or 2/0, more than enough for 100 watts. This power wire comes directly from the battery fused with a 130 or 150 amp fuse. I also didn't claim to be an expert on anything, I read it from the manual u butthead
eksine is offline   Reply With Quote
Old 03-24-2016, 09:57 AM   #28
timmaah's Avatar
1999 25' Safari
On , the road
Posts after a year with no activity should be auto-closed.
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Solar Panel Question marvinr Generators & Solar Power 2 09-20-2011 04:06 PM
Seeking Feedback: solar solutions for full-time telecommers burnsdl Generators & Solar Power 7 08-19-2011 02:31 PM
I'm confused, where do I wire in solar controller bmklawt Generators & Solar Power 7 06-19-2011 11:22 PM
How much solar do I really need sgoetz Generators & Solar Power 12 05-19-2011 08:28 AM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
