Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 01-25-2008, 07:31 PM   #43
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
Originally Posted by NevadaGeo
Slighty different stroke here. I bought a generator i could afford, that would run the a/c in the heat. Found out it is TOO LOUD for me or even patient neighbors. Anybody had any (successful) luck in boxing the things with foam or something to quiet it down, without overheating the unit? I'm thinking a couple increasing sizes of plywood boxes but haven't thought out the ventilation yet. Maybe tall, open topped boxes might work.
I have seen it done and it makes a noticable difference. I have also seen throwing a sleeping bag or heavy blanket over the generator makes a difference.
I have wondered if a larger muffler could be rigged up anybody try?
Like a couple of Balboas we headed into the wild pavement of yonder with a monstous piece of aluminum hooked to our rear end. "The Long, Long Trailer".
Lumatic is online now   Reply With Quote
Old 01-25-2008, 08:41 PM   #44
Kajtek1
Kajtek1's Avatar
Profile:  1965 22' Safari
Orinda , California
"Quiet" is combination of everything. I own build-in Generac, that has good muffler, but the engine itself make high-whining noise I can't stand.
Somebody on another forum took Honda EU2000 apart. Even the air intake had fancy shape of several small tubes leading to filter box.
You can take construction generator and start improving it. Good muffler from Harley (they always replace them with straight pipes, so actual mufflers can be free) , better engine shrouds, better crankshaft and balancing. By the time you get satisfy you spend more money than new Honda cost and end up with one ugly generator.
Kajtek1 is offline   Reply With Quote
Old 01-28-2008, 02:51 PM   #45
gowyn
gowyn's Avatar
Profile:  2007 27' Safari FB SE
London , ontario
update to update
So today I went out and bought a Champion 3500w genny. Thought I'd save a few bucks.
I managed to pick up a used Honda eu1000 cheap and love it. putt putt putt. So I just wanted a bit more umphf for ac etc with the Champ.
Well noisy! I'm going to take it back and keep my eyes open for a used eu2000, then I'll parallel the 1000 and 2000 together.
So that's the latest...
gowyn is offline   Reply With Quote
Old 01-28-2008, 03:20 PM   #46
2airishuman
2airishuman's Avatar
Profile:
Originally Posted by gowyn
...keep my eyes open for a used eu2000, then I'll parallel the 1000 and 2000 together...
no can do.
IF you eventually wanna use a parallel kit,
both gensets must be the same size...
http://www.airforums.com/forums/f448...00i-18554.html
http://www.airforums.com/forums/f448...0is-23976.html
so for ac potential that means 2x eu2000i...
there are perhaps a DOZEN good threads here on this issue...
Honda EU 3000 vs 2x Honda EU 2000
portable generators
http://www.airforums.com/forums/f448...0-a-19725.html
http://www.airforums.com/forums/f448...00i-35433.html
but self discovery is another option...
cheers
2air'
there is also someone here with 2x2000 mounted on the tongue behind lp tanks...
but you'll have to find that thread on ur own...
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 01-28-2008, 04:27 PM   #47
gowyn
gowyn's Avatar
London , ontario
well there are lot's of folks over on rv.net who do it routinely.
Only one way to find out.
Old 01-28-2008, 06:46 PM   #48
Lumatic
Lumatic's Avatar
1962 28' Ambassador
When I asked the same question I was told NO. Let us know if you can.
Old 01-28-2008, 08:08 PM   #49
Kajtek1
Kajtek1's Avatar
Orinda , California
This forum is occupy by "paper experts".
Read the reply #47 one more time
Old 01-29-2008, 11:23 AM   #50
pmclemore
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
Kajtek, I read the link you provided (at least the posts that immediately appeared) and agree that some folks are linking them with some success. I wonder whether it is a good idea to do this routinely. For example, in order to get his AC to work, he linked them, then set the thermo way down so that it would not cycle on and off (the way a normal, comfortable setting would be). Then at night, he'd let some of the cold air out so he could sleep. I guess.
Would the manufacturers support this? Or could it be a plot for them to sell more 2000s and fewer 1000s? Inquiring minds want to know.
I think you'd agree that you should not mix battery sizes or types on a multi-battery rig. But perhaps not. But just on paper, that sounds reasonable to me (not to mix them).
I can also find plenty of folks who will do lots of stuff, and make it work - however I am not convinced of safety or long-terrm efficacy.
Thank goodness for paper experts so I don't have to go out and find out everything for myself.
Pat
pmclemore is offline   Reply With Quote
Old 01-30-2008, 11:32 AM   #51
pmclemore
pmclemore's Avatar
Place me in the "uneducated" camp.
Dumb and ashamed. But I'll get over it.
Pat
Old 01-30-2008, 01:16 PM   #52
TROPHYJIM2
Profile:  2008 31' Classic
Sweet Valley , Pennsylvania
Eu2000
I have to look mre closely but it seems that would be a tight fit. Ive had my 2000's for a couple years for my vendor unit and love them. You can use one or two.......very flexable. I remember my dealer talking me into this option....much more portable and carry them anywhere. Mounting these easily moved units would make me nervous...unless secured well. I chain mine...... (which can also be cut, I suppose) hehe also I have little plastic signs attached warning folks of an embedded tracking device.....
TROPHYJIM2 is offline   Reply With Quote
Old 01-30-2008, 01:18 PM   #53
TROPHYJIM2
By the way, I don't mean to "Shout" with my name in all caps...been looking for a way to change this...but doesn't seem to be an option now that I am committed.
Old 01-30-2008, 01:47 PM   #54
2airishuman
Profile:
HEY JIM, WE'RE FINE WITH ALL CAPS!!!!
but if you wanna change this a mod/admin can do it for ya...
maybe.
Originally Posted by TROPHYJIM2
...I have to look mre closely but it seems that would be a tight fit...
i'm not suggesting we should mount them on the tongue, only that it has been done.
and the tanks/jacks may need to be moved slightly for this, there is the weight issue and turning radius may b reduced...
mswartz has a 3000 on his...
external
and grizzy did the 2x2000 on his with a neat'o rack and locks and shields...
http://www.airforums.com/forums/f198...mbi-13142.html
the more camping, the less i use the genset, but do like having one in the truck...
cheers
2air'
Old 01-30-2008, 02:38 PM   #55
millvalleyca
millvalleyca's Avatar
Profile:  2008 27' International CCD FB
Mill Valley , California
on a side note
Hey TrophyJim2...are you in the trophy business? That's what I do over here on the westcoast! We also have a 27' FB
millvalleyca is offline   Reply With Quote
Old 01-30-2008, 03:07 PM   #56
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
You can ask a moderator or admin to have your name surgically altered. It's relatively painless...
Cheap Sunglasses camperski Rock Guards, Segment & Window Protectors 13 09-08-2008 08:26 PM
Cheap sunglasses Dan S All Argosy Trailers 3 03-30-2007 01:28 PM
As Insurance... Why So Cheap TIMETOGO Insurance & Claims 24 12-01-2006 09:15 PM
Polishing done cheap! (well....) muddy_hollow Cleaning, Stripping & Polishing 23 06-04-2005 12:16 PM
1982 Airstream 310 For Sale - Cheap-cheap! CHRIS CANNON For Sale & Wanted 5 04-01-2004 12:47 PM
