Old 01-11-2008, 01:51 PM   #15
gowyn's Avatar
2007 27' Safari FB SE
London , ontario
Originally Posted by arodriguez60
I boughr the champion 3500 and it has been a very good buy. I havent had any problems except that the fuel gauge is not very accurate. I just open the fuel cap and take a look for the amount of fuel. I've been pleased with it.
how do you find the noise level on the Champ?
gowyn is offline   Reply With Quote
Old 01-11-2008, 01:52 PM   #16
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have a Champion 4500 and a Honda eu20001. The Champion served it's purpose for a year until I found a used eu2000 for $600. The Champion is a little quieter that some other generators that size but not much. It's still loud and obnoxious. I have seen prople through a thick blanket or put a baffle around a generator with some success. Mechanically there were 2 minor problems with the Champion: the circuit breakers were to small in amperage and the starter recoil mechanism self destructed after a year but the whole recoil assembly was only $18. I had good tech support with the Champion. You know, I assume, the Champion is Chinese.
The Champion will run the AC the Honda not.
Old 01-11-2008, 01:55 PM   #17
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Google - Champion 3500 generator db
It's 68 db @ 7 meters and $500
Champion 3500 Watt Generator w/ RV Receptacle C46540 @ Electric Generators Direct.com - Your Online Portable Power and Home Standby Generator Superstore
Fyrzowt is offline   Reply With Quote
Old 01-11-2008, 01:57 PM   #18
gowyn's Avatar
London , ontario
what I think I'll do is pick up the Champ and try it out. Costco here have an awesome return policy so if it doesn't work out I'll just take it back.
I've read a lot of great things about Champion and especially their service. The nice thing about the Champ is it also comes with the rv adapter, wheels and handle, plus if the power does go out I can use it at home. If it dies within a year it's warranty, if it lasts longer bonus.
Old 01-11-2008, 02:02 PM   #19
gowyn's Avatar
London , ontario
Different model here in Canada.
CSA40015. CSA approved for the Great White North eh!..hehe also $299CAD at Costco right now.
Old 01-11-2008, 02:52 PM   #20
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Well... The price is right. If it doesn't work out for you, you aren't out that much money. I had a 4.5Kw generator, it would run everything in the airstream, but you couldn't sleep because of the noise.
At the earliest opportunity I got a lightly used Honda eu2000i for $250, ditched the contractor genny, and have been happy.
Old 01-11-2008, 03:05 PM   #21
joe3957's Avatar
1967 26' Overlander
albuquerque , New Mexico
db definition
The db level is 68 db for the champion. Each 10 db is roughly twice the amount of noise. 53 vs 68 is about 3 times as loud.
Have you ever camped near someone with a loud generator[/quote]
Actually I think its worse than that unfortunately. From Wikipedia...and back in the cobwebs of my brain "
The decibel (dB) is a logarithmic unit of measurement that expresses the magnitude of a physical quantity (usually power or intensity) relative to a specified or implied reference level. Specifically, an increase of 3 dB corresponds to an approximate doubling of power. (In exact terms, the factor is 103/10, or 1.9953, about 0.24% different from exactly 2.) Since in many electrical applications power is proportional to the square of voltage, an increase of 3 dB implies an increase in voltage by a factor of approximately √2, or about 1.41. Similarly, an increase of 6 dB corresponds to approximately four times the power and twice the voltage, and so on. (In exact terms the power factor is 106/10, or about 3.9811, a relative error of about 0.5%.)
I too have struggled with this question. And plan to purchase an inverter based generator while building up my solar capacity. Has any had any experience with the Magna or other "lower cost" inverter generators?
joe3957 is offline   Reply With Quote
Old 01-11-2008, 03:15 PM   #22
joe3957's Avatar
1967 26' Overlander
check online or campingworld
d'oh!!!
Just called the dealer here, eu3000 $2200 ouch.
I have seen the 2000 for about 1/2 that price new
Old 01-11-2008, 04:46 PM   #23
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
gowyn
Check SMALL ENGINE WAREHOUSE They have a web site, they are in Indiana so the shipping wouldn't break U up. Or U can go by there and pick it up.
I do business with them. Have had no problems.
Just a thought.
Good Luck!
Roger
Mikethefixit is offline   Reply With Quote
Old 01-13-2008, 08:51 PM   #24
DFord79's Avatar
Yakima , Washington
champion 4000 is 299 dollars at Shucks auto....LOUD....and in camp grounds when used they have a tendency to fail due to spark plug ejection. Small engine people won't work on them either.
You can get a Honda eu3000i NEW for $1700. My local dealer has em for that price and Trailer life magazine has em for that price in the classifiied sections.
Again....If you want to remain friends in camp it will be hard to do with a cheapo genny. And like I said...their spark plugs and Other important parts tend to dissapear without warning.
DFord79 is offline   Reply With Quote
Old 01-13-2008, 10:55 PM   #25
Fyrzowt's Avatar
2000 25' Safari
Images: 8
From what I understand, a single tap on the side of one of those spark plugs with a hammer will render the generator very quiet.
For unknown reasons this phenom occurs more often after about 10PM.
That's what I've been told.....
Old 01-14-2008, 10:24 AM   #26
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
IMHO, you should olny use a contractor generator when you are by yourself. Otherwise you are a nuisance to everyone within shouting distance.
And I don't have words to describe the folks who use them and then retreat into their rigs to enjoy their AC and TV while leaving the rest of us to listen to their noise.
Pat
pmclemore is online now   Reply With Quote
Old 01-14-2008, 10:35 AM   #27
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Users of loud gensets need this done to them
Buy a good quality unit, even if it is used.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 01-14-2008, 11:32 AM   #28
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
It mostly boils down to what you need it to do.
In my case, I have the 15k BTU A/C unit. Outside of 2 3000 watts units or one larger one, it's pretty much out of the question.
So in my case, I bought a 1000 watt based on these needs:
Battery charging
Running fantastic vents most of the day
Cutting wood with a small electric chain saw
Propane fuel so I didn't have to lug extra gas or carry it in the TV or Safari
I bought the Yamaha 1000. Honda makes one too, but you have to have it converted to LP. Noise is very modest at full load and it sips the LP. I have had many hours of runtime on it at 3/4 to full load and have yet to empty a 20lb tank.
Cheap Sunglasses camperski Rock Guards, Segment & Window Protectors 25 01-22-2009 04:33 PM
Cheap sunglasses Dan S All Argosy Trailers 3 03-30-2007 12:28 PM
As Insurance... Why So Cheap TIMETOGO Insurance & Claims 24 12-01-2006 08:15 PM
Polishing done cheap! (well....) muddy_hollow Cleaning, Stripping & Polishing 23 06-04-2005 11:16 AM
