Old 07-23-2019, 06:01 AM   #1
1981 31' Excella II
New Market , Alabama
Good Home Power Hookup Solution
We recently bought 44 acres in TN and we have an SOB and the 31 ft Excella II up there. I have 50A going to the SOB which only has one AC so it can easily run off half of that 50A from 220V 50A coming in. The PO had rigged the power pretty bad and instead of jury rigging something that was already unsafe I decided to find a solution that would allow me to connect both trailers. I ended up with this distribution box which can handle the power I need. It comes with 3 recepticles, 220V 50A, 120V 30A, and 120V 20A. It has position for 4 more breakers for expansion. I think it is rated at around 100A so you could potentially run even more stuff off it.
I plan on turning everything on in the SOB that one might need and check each leg of the 220V coming in to see which leg has the least load on it. I would then connect the 30A plug to the Airstream to the leg with the least load on it. I will also measure voltages to see where I am at there.
Perry
perryg114 is online now   Reply With Quote
Old 07-23-2019, 06:33 AM   #2
Mollysdad's Avatar
That box looks to be a good plan.
I'd try to stop thinking in terms of 220v. 50 amps.
Although that's how the box is wired, the trailers never see that.
Instead, the trailers see (2) 50 amp 120 v circuits.
220v. is derived by taking the two "hots" as a circuit along with a neutral and ground. Nothing in an Airstream is used that way.
Old 07-23-2019, 08:54 AM   #3
1981 31' Excella II
I am aware. I have not seen anything run off 220V but maybe some of the big bus chassis RV's or those monster 5th wheels might actually use the 220V. I think two 50A circuits is more than enough for these two trailers.
Perry
Old 07-23-2019, 09:11 AM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Do you know any engineers who might be willing to review your plan?
Just kidding - it looks robust.
Tom
Old 07-23-2019, 09:28 AM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I think the proper terminology (to eliminate any confusion for an electrician wiring it all up) for the 50A circuit is 120/240V 50A. 220V 50A could imply no neutral. 120/240 clearly requires a neutral. If it is 120V line to neutral it is 240V line to line.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-23-2019, 12:00 PM   #6
1981 31' Excella II
Just you and me.
Perry
Tom
Old 07-23-2019, 12:02 PM   #7
1981 31' Excella II
The supply line is 6/3 Romex with a ground.
Perry
Al
Old 07-23-2019, 12:07 PM   #8
Long Island , New York
. . . for how long a run?
Home power hookup phughes Electrical - Systems, Generators, Batteries & Solar 22 06-23-2013 09:16 AM
Best home electrical hookup? mico75 Electrical - Systems, Generators, Batteries & Solar 7 06-07-2009 07:46 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
30Amp Hookup @Home Chuck Electrical - Systems, Generators, Batteries & Solar 55 07-08-2007 04:29 PM
