Originally Posted by azflycaster
I was thinking of going to Mobile 1 in my EU1000. I have about 40 hours on it now, do you think that is too soon to switch. I have been waiting for 5,000 miles on my new truck to do the same.
You might be surpirsed to learn that your New Truck probably has synthetic in it from day one. MOST new vehicles come from the factory with synthetic in the crank case. Corvetts specify it. Ford motor company puts synthetic from day one. So does Honda and many others including Farrari (just in case you might own one of them
). I have no idea where this got started but you DO NOT need to break in an engine before you put synthetic in it. That goes for your Honda genny. Use synthetic anytime its the best way to go. You might be surprised to learn that many oils that are NOT classicfied as synthetic use synthetic additives just not enough percent to be called synthetic and to keep priceing low. Oil classifications changed several times over the last few years and synthetic added to or in place of Dino oil is the cheapest way for oil companys to get their oils up to standards.
Champion gennys are made in china. But then so are some of the contractor gennys with Honda power plants. But they are all noisy. I understand money is a big factor and Honda's are exspensive. But well worth the investment. Honda has gone to great research and development to make their gennys the quietest on the planet. Yammys are close but not as quiet.
Our local Honda dealer is very exsperience with gennys and WILL NOT WORK ON CHANPIONS OR MANY OTHER gennys. He also sells Yamahas......but says the Hondas are the best from a mechanical standpoint. He has been in the small engine business for over 40 years.
Yamaha has a new 4500 out. Very quiet (rated at 59db). The Honda 3000i is the quietest of them all. If a person can afford it and needs it Honda has a 6500i inverter that is 60 dbl. full throttle and 52 dbl at idle and very very impressive if you run two A/C units. I heard one run next to the 3000i and there was a noticable difference but not much. And it would run one A/C at idle so it would be quieter than a much small unit when not under full load.
