Old 01-27-2014, 06:25 AM   #15
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
While doing the looking, I would suggest determining the maximum solar panel space you have on the trailer roof and determine the maximum current watts that could be installed.
Then do the research to determine the proper wire size. Increase the wire size two sizes (i.e. #10 would work but install #6). Over time, the solar panels will become more powerful per square unit of measurement. Having the larger wire size would allow replacements of the greater capacity panels without redoing the wiring, plus you would have had very minimal voltage drop for the existing system getting the max bang for the bucks spent.
switz is online now   Reply With Quote
Old 01-27-2014, 06:59 AM   #16
Huntsville , Alabama
Wow, great information everyone, thanks! A lot of it is all new to me, and a bit technical, but I need to educate myself on it. I'm sure this thread will also help others, as I think it's very well explained.
Having said that, due to time constraints (and in an effort to keep my spending down right now), I will get the dealer to install the second 95 watt solar panel, using the existing wiring and controller. Then later, perhaps when I'm somewhere in the south west where solar power is even more popular - and probably cheaper - I'll go in to a place and get the wiring and controller upgraded, and add to or upgrade my solar panels. I just need something to get me started, and I'm guessing that RV dealers may not be the most economical places to get solar accessories. Once I get the basics, and I have more time once I'm in the south west, I can shop around, using the excellent information from here.
JustSomeGuy is offline   Reply With Quote
Old 01-27-2014, 07:41 AM   #17
Belchertown , Massachusetts
This is sort of counterintuitive, but it's my understanding that more solar panels will not necessarily require or even benefit from larger wire - the wire running from the panels to the charge controller, that is. If the additional panels are wired in series, resulting in higher voltage output from the panels, the same wire may be just fine. You'd just definitely need an MPPT controller then to deal with high panel voltage.
This assumes that it's quality wire and sufficient for the initial smaller panel not to lose any power on the way to the controller. The problem with many dealer or 'pro' installs that don't work well is cheap flimsy wire from the panels to the controller, inverters and controllers located too far from the batteries, and insufficient gauge wire for the inverter to give its full output or the controller to deliver all amps to the batteries. But the path from panels to controller to batteries is really critical to get your money's worth out of your panels to charge those batteries.
You might also save some money by going with quality deep cycle lead acids over AGM batteries, not sure what your install looks like. The AGM's are lower maintenance, can often take a very high charge rate from shore power, and can be mounted in awkward locations. Lead acids are still great batteries but must be upright and you must check the water levels regularly.
workerdrone is offline   Reply With Quote
Old 01-27-2014, 08:05 AM   #18
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Put as many panels on as space and budget will allow. I added solar last Spring via AM Solar's great DIY site/product mix. I calculated I had room for 3 panels, but managed to add a 4th. Lewster was very helpful in this mod as well. (Heavier wire = less loss of current going to my batteries). also, "do NOT screw the panels to the roof...use the double sided sticky tape AM Solar sends you!" Glad I waited to do my own rather than the expensive and puny factory upgrade. Not a cheap add-on though, especially after buying two Lifeline AGM batteries at around $300 each. But the solar sure works well, and I feel really good about the investment.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 01-27-2014, 08:15 AM   #19
TinCan
graysailor's Avatar
2016 30' Classic
Labor would be about the same to do 2 panels now instead of adding one later. Go for it and be done with it. As in other posts be certain to check/upgrade your charging system and if changing batteries go with the AGM's.
TinCan
graysailor is offline   Reply With Quote
Old 01-27-2014, 08:15 AM   #20
I'll ask the Airstream dealer how they attach the panels. I'm sure (and hope) they do it in in a way that will not cause damage or potential leaks. They said the panels will be slightly elevated, so there must be some small mounting legs, rather than 100% contact around the entire perimeter of the panels.
For the batteries, I don't think they are AGM. There's already one 12V RV battery and they're adding a second one of the same type, from what I understand. Hopefully they last a while, but when the time comes to replace, I will probably go with AGM batteries.
Old 01-27-2014, 09:02 AM   #21
1976 27' Overlander
Hartford , Alabama
Tom and Phyllis,
V=IR (amperage times resistance equals voltage), the reason using higher voltages can use a smaller wire is there is less amperage to flow through them for the same amount of "power" or wattage (power equals amperage times voltage).
The problem with that on an RV is when 2 or more panes are in series, if one gets any shade on it at all, it reduces the output of ALL the panels drastically. A parallel hookup is much more efficient on RVs as they are often times partially shaded.
If you want to run higher voltages, get panels that put out that voltage and connect them in parallel, but you still have to calculate the proper wire size for the AMPERAGE, as Lewster pointed out.
What I can't believe is no one has mentioned doing a usage analysis on his estimated wattage per day and then sized the system to that. Without that it is like picking out a tow vehicle based on color.
I'll also bet that the RV dealer won't put protection fuses on each panel on a multi-panel system, a very essential requirement.
Another rough guide is for every amp hour the battery bank is rated at, figure the same amount of panel wattage. Thus a 200 amp hour battery pack needs around 200 watts of solar panels to keep it charged and give enough headroom to equalize regularly.
Make sure the batteries the dealer installs are true deep cycle and not boat type starter-trolling motor batteries. They have a much shorter life span when used as deep cycle, and don't last at all if ran down further than the recommended 50% SOC a few times.
Tom J
Valacidor is offline   Reply With Quote
Old 01-27-2014, 09:14 AM   #22
lewster's Avatar
Naples, FL , Hood River, OR
A few comments if I may.
I happen to be one of those 'professionals' that install solar charging systems PROPERLY! Series connections for solar panels will reduce the required wire size by increasing the voltage being sent to the controller, but as with any series connection, a small shadow on just one of the panels will drastically reduce the charge voltage coming from the series connection. This is why we use larger cabling and parallel connections exclusively.
I certainly would not consider the 6AWG thru 2AWG class K welding cable that we use in our installations to be 'cheap or flimsy'. I do consider it necessary and rather expensive as well.
Also, we will install systems with existing liquid lead acid batteries, but prefer and strongly recommend Lifeline AGM batteries for a number of reasons. Start with their super low internal resistance, which allows for the full utilization of all of the charging amperage to be sent to the batteries to be utilized for charging and not overcoming the 10-12% internal resistance of a liquid cell before the actual charging begins.
Add to this the total lack of maintenance, versatility of placement of Lifelines, their 5 year warranty and their great track record for extended longevity and they make a lot of sense. Expensive on the initial installation....yes. Worth the investment.....DEFINITELY!
The bottom line...............buy components from a trusted company and/or have your system installed by professionals that know what they are doing, follow NEC and component manufacturer guidelines and have a track record of great work.
Old 01-27-2014, 10:00 AM   #23
Lewster, sounds great! Looking at your location, I'm not sure if you work out of Florida or Oregon, but either way, I'm sure I'll be in both of those state sometime in the next year. Maybe we can meet up and I'll hire you to look over my solar power system and improve it by adding and/or replacing some components. For now, I need something to get started, and it's a bit overwhelming taking it all in at once. I'll do my best to explain what I want to the Airstream dealer and hopefully it will be done the best way. If not, I'm sure it will work in the interim, and can be improved later.
Old 01-28-2014, 03:48 PM   #24
Lewster, you sound like a knowledgeable fellow - my comments about 'pros' were in no way directed towards ya, I've just heard a few horror stories about high dollar installations at dealers and such that didn't work worth a darn.
Old 01-28-2014, 08:22 PM   #25
lewster's Avatar
No worries! NO offense taken………..
Generator, 2 smaller? Also, solar panel size? zlee Generators & Solar Power 19 12-11-2011 07:38 PM
Solar Panel Question marvinr Generators & Solar Power 2 09-20-2011 04:06 PM
Roof mount Brackets for Solar Panel Bo2020 Generators & Solar Power 2 04-11-2011 01:20 PM
Solar Panel Prices Dropping tbro Generators & Solar Power 11 03-30-2011 08:21 PM
