Old 12-13-2008, 07:50 PM   #1
1989 34' Limited
southern , ontario
Generators kills RV owner
this week an RV'er died from CO POISONING caused from the gen. exhaust leaking into his RV.
Discussions in other posts have stated how carefull they are in sealing gen. boxes in the RV.
It is the moving RV that breaks the seal that allows CO contamination emitted by the generator.
BE CAREFUL
letsgo is offline   Reply With Quote
Old 12-13-2008, 07:54 PM   #2
Kevin245's Avatar
A $20.00 CO detector may have saved his life....
Eleanor Roosevelt
Old 12-13-2008, 08:40 PM   #3
JimGolden's Avatar
1977 31' Excella 500
LP can get you too
My best buddy's dad just died a few weeks ago from a similar thing:
His LP stove in his cabin had a leaking valve. He had cooked and ate dinner and went to bed. He shut the valve off, but it was leaking slowly. As he slept, it filled the cabin full of LP and asphyxiated both he and his dog. Very tragic.
Now this was in a small hunting cabin, but it could just have easily happened in an RV.
I should know the answer to this...but I've never seen an LP detector. I guess they make them? I have a CO detector in my house, but not in the RV. I'd like to get both for it now.
I'm probably paranoid about LP, but I'm uneasy just lighting the oven pilot to bake a pizza (get out the gas welding face shield...) Kind of like with your dad when you're a kid or with the sarge in boot camp; a little healthy fear is a good thing!
- Jim
JimGolden is offline   Reply With Quote
Old 12-13-2008, 09:11 PM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Yes, they have LP and CO detectors, I have both in my vintage trailer. The LP detector I have is 12v and mounted low because LP sinks, while the CO detector is mounted high because CO rises.
I was very paranoid about the LP when I first got my trailer. Now I just maintain a healthy respect for it.
Stephanie
Old 12-14-2008, 07:32 AM   #5
Central , Mississippi
I always wondered about CO rising or falling-
He's an article that discusses
Carbon Monoxide and Density
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-14-2008, 10:30 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Most RV's and all built after a certain date are required to have LP detectors, they are mounted fairly low because LP is heavier than air. CO and Smoke detectors will usually do better mounted up higher as pointed out in the article. FWIW I use all three in my home and in my trailers. Also might want to make sure that you use an RV rated detector in your trailer, they apparently are better suited for vibration and temperature extremes.
Aaron
WBCCI #XXXX AIR #2495
Old 12-15-2008, 03:02 PM   #7
1989 34' Limited
southern , ontario
I thought all airstreams came with LP DETECTORS as you say mounted at the lowest point (close to the floor) our CO DETECTOR is mounted at bed hight, and of course the SMOKE DETECTOR is on the ceiling.
safe rving
Old 12-15-2008, 03:40 PM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
safe rving
Not the older ones. I have a 1975 that does not have a factory installed one on it. Don't recall if the '80 has one or not. All new ones HAVE to have them.
Aaron
Old 12-15-2008, 05:23 PM   #9
Obsessed with Moonunit
COArgosy78's Avatar
1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 55
Hello -wondered if there is any particular brand on the CO and/or LP detectors that are installed or that any here have added to their older model units? I have heard of Safe T Alert (avail. at CampWorld) but wondered if there are others or better?
Leigh (IB Aluminated)
"When a great ship is in harbour and moored, it is safe, there can be no doubt. But that is not what great ships are built for." by Clarissa Pinkola-Estes, author of ‘Women Who Run With the Wolves’
COArgosy78 is offline   Reply With Quote
Old 12-15-2008, 05:51 PM   #10
78GussyTX's Avatar
1978 Argosy 30
Alvin , Texas
Images: 8
Folks, my understanding is that the CO mixes "well" with air, meaning height is not as critical for detector placement. But LP must be low.
For those of you like us who own vintage units, here's a good model detector for CO and LP that we bought for both home and RV:
Multi Gas Detector - Natural Gas, Propane Gas & Carbon Monoxide Gas from First Alert.
We got ours at Walmart online.
78GussyTX is offline   Reply With Quote
Old 12-16-2008, 03:19 PM   #11
COArgosy78's Avatar
Images: 55
Has anyone bought or used the Safe-t-Alert made by MTI? or one made by CCI Controls? There seem to be 2 different models of the Safe-t-Alert. I'm trying to get more ideas on these. Thanks.
Old 12-16-2008, 04:51 PM   #12
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
It's indeed sad to read stories about RV CO2 deaths.
On a trip this Spring we had both Hondas up and running with the trailer buttoned up and the AC running when I heard the chirp of the CO detector. It took a minute to realize what I was hearing and what the problem was. We immediately aired out and moved the Hondas. Be careful out there Airstreamers.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 12-16-2008, 05:16 PM   #13
TIMEMACHINE's Avatar
Huntington Beach , California
good point
Even your neighbor in the campground can get you..we once had the RV'r next to use run his truck to keep his trailer's batteries charged, ALL NIGHT LONG, or at least that is what he thought before I had a quick talk with him. His exhaust was only 10 feet from our bedroom window, could have been a real problem.
Yes be careful.
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
TIMEMACHINE is offline   Reply With Quote
Old 12-16-2008, 07:26 PM   #14
1989 34' Limited
southern , ontario
remember carbon monoxide is CO (a product of combustion), CO will enter the blood stream paralyze then kill.
carbon dioxide CO2 displaces oxygen then kills (dry ice as a solid)
Any Generators? Boytoysoh Electrical - Systems, Generators, Batteries & Solar 8 09-22-2008 09:35 PM
Generators . . . again? dinoburb Generators & Solar Power 6 03-18-2008 07:36 PM
Generators.... rmanalang Generators & Solar Power 7 01-23-2006 10:27 AM
Generators PeterH-Airstreamer Airstream Motorhome Forums 25 09-07-2004 09:46 AM
Generators csimingt 1999 Safari 11 07-26-2004 08:38 PM
