Old 12-30-2015, 11:54 AM   #1
PSU1981
2015 27' Flying Cloud
Spring , Texas
Generators, AC & 50 amp
What size generator will I need to run 2 AC's on a 2015 27FB FC in the heat of summer in TX? Do generators come with a 50 amp receptical? What brand is recommended & why?
Glenn
PSU1981 is offline   Reply With Quote
Old 12-30-2015, 12:16 PM   #2
1986 31' Sovereign
Miami , Florida
50 amps @ 120VAC is 6000 watts.
Basically big, heavy power but if you need to run both air conditioners...
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 12-30-2015, 01:18 PM   #3
2005 19' Safari
GLENDALE , AZ
If you need 50 amps to run two air conditioners simultaneously, you probably are not a good candidate for boondocking. From a practical standpoint, I would concentrate on campgrounds with 50 amp hookups.
Alternately, you might consider camping where it's cooler (due to climate, season or altitude), where no air conditioning is needed. Or, if you can get by with the cooling power of only one unit, the usual generator setups will suffice.
Personally, I don't ever recall an AirForums discussion thread on 50 amp generators...
International Rally & Generators Air Apparent WBCCI Forum 7 11-17-2008 03:28 PM
Generators . . . again? dinoburb Generators & Solar Power 6 03-18-2008 07:36 PM
Generators PeterH-Airstreamer Airstream Motorhome Forums 25 09-07-2004 09:46 AM
Solar and Generators Melvin P. Thorpe Generators & Solar Power 43 05-11-2003 08:51 AM
Generators...one more time! APB Electrical - Systems, Generators, Batteries & Solar 0 03-09-2003 08:52 PM
