Old 08-14-2009, 07:51 AM   #15
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Originally Posted by Doohickey View Post
Just one 13000 BTU unit.
You have a recent unit so a 2000i will probably run it but nothing else can be on line. Mine does fine.
Ahab is offline   Reply With Quote
Old 08-14-2009, 10:55 AM   #16
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
new honda 3000
honda is now touting a new version of their 3000, it is lighter, NOT electric start, has a smaller fuel tank and built in wheels. it is also more expensive. go figger. I mounted my 3000 on the tongue-see thread entitled "tongue mounted generator" put a 12 gallon fuel cell below it with an electric pump so I could refuel the 3000 as req'd. I believe the 6500 will also fit the same space once all the wheels, outriggers, etc are removed. I am trying to find one of those used. as stated, you cant have too big of a gen-you CAN, however have one that is too loud.
ol' bill the newbie (with a little gen/electrical experience prior to AS)
wmarsha is offline   Reply With Quote
Old 08-14-2009, 02:06 PM   #17
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
While we're on the topic of generators... as I was taking the factory tour at Jackson Center in late July, the guide pointed out the addition of a 30 amp Marinco type connector on the front of some of the trailers on the production line. He said it was specifically made for plugging in a generator that could, theoretically, sit in the back of a truck tow vehicle. If I recall, it was located on the street side, near the bottom of the window. Think of the possibilities.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 08-16-2009, 07:32 PM   #18
2000 34' Limited S/O
Jamestown , North Carolina
Propane Generators
Will a propane generator do the job? I was thinking that running a line to my propane tanks would be much simpler than having to carry a gas can with you.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 08-16-2009, 08:18 PM   #19
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
I believe the Honda and some other generators can be converted to propane.
Honda Generators Propane and Natural gas Kits.
2005 Bambi
1968 Trade Wind
WDCU
Old 08-16-2009, 08:21 PM   #20
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Propane Generators
It's not the fuel, it's just the wattage output ... I've got two multifuel generators that run on gasoline, LPG, and natural gas: one a 2400, one a 6600 watt. The big one is standby for the house - you wouldn't want it in a campground next to anyone you liked. The little one is much quieter and runs the a/c, etc. if I want, whether it's running on gasoline or LPG.
AirsDream is offline   Reply With Quote
Old 08-17-2009, 07:41 AM   #21
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
This conversion has worked very well for us, can still use gasoline if needed. Runs about 25-27 hrs on this tank.
The Honda has been trouble free.
Name:	PROPANE CONVERSION, HONDA 2000 001.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 08-17-2009, 02:49 PM   #22
2008 16' Safari
Destrehan , Louisiana
Actually, the fuel does make a differance. What is important is the calorie content of the fuel. Gasoline is the highest and natural gas is the lowest. For a given size of engine, it will produce more housepower on gasoline than on LP or natural gas. Thus, the rated wattage for a generator set will be different for each type of fuel you are using.
In normal opperation, we generally do not run an engine to 100% load. So a generator set may appear to have about the same output with what ever fuel you are using. There is also the service factor of the generator set. Most home units are rated at a 0.6 service factor. This means you can run at a 60% load all the time. You have a reserve that will allow you to get 100% load, but not for long. Commercial units are often rated at a 0.8 service factor and industrial units can be rated as high as 1.1 sevice factor.
For our selection of a generator to power a trailer, several different factors come into play.
Wattage; is the unit larger enough to meet our power demands?
Size; is it small enough to move around?
Fuel; will fuel be available and what is its cost?
Noise level; can you and your neighbors live with the noise level?
Reliability; can you count on it?
Maintenance; how often do you need to service the generator set?
Cost; how much are you willing to pay for the power?
Keep in mind that running a generator is the most expensive way to get power to your trailer. The only thing that cost more is to use solar power.
I have an LP gas generator but it's primary job is not to power my trailer. I live near New Orleans and having a generator to power up after a storm is a must if you don't evacuate. After Katrina, the only power we had for two weeks was from our generator. The pour thing died from the effort, but some power was better than none. I learned from that first gen set and now have a better built unit with the quiet kit on it. It cost about $2400.00 and is large enought to run the Airstream or one room AC and the fridge in the house (TV and two lights don't count for much).
One lesson I did learn from Katrina was just how much fuel you can run through trying to keep full time power on. Most of us had gen sets with 5 gallon tanks on them. We had to refill the tanks two or three times a day to keep the lights on. (Yes, that was about $40.00 a day for one small AC and the fridge) If you use a small generator just to run the trailer a few hours at a time, its not too bad. Go to full time power and the cost really goes up.
dlb435 is offline   Reply With Quote
Old 08-17-2009, 04:32 PM   #23
2007 25' Classic
Hydes
I ordered that option on my 25 Classic. Known as "generator prep" don't remember the cost.
craftsman is offline   Reply With Quote
Old 08-18-2009, 08:25 AM   #24
Thumbs up
This tank costs 5 bucks to re-fill, an hour or two every couple days keeps the batterys charged, LPG conversion is a very handy option to have.
PFC
"Tahawus"
RLC
John Prine
Old 08-18-2009, 10:22 AM   #25
1976 25' Tradewind
Erie , Pennsylvania
Has anyone had any luch with the coleman generator? It appears to be priced far lower than then the Honda. However usually you get what you pay for.
rollingbubel is offline   Reply With Quote
Old 08-18-2009, 10:32 AM   #26
richinny's Avatar
2011 34' Classic
i have one. you would not want to listen to it for very long.
Ricky
Old 08-18-2009, 10:42 AM   #27
knunut's Avatar
2007 20' Safari
2016 26' Flying Cloud
Chgo. N.W. Burb's , Illinois
Look's like "Cabelas"will have some Generator's on Sale starting the 20th.-the 26th."Champion" brand 3500watt $300 and 800watt for $120(50:1 fuel mix on 800w.) No info on Quality or noise level.
knunut is offline   Reply With Quote
Old 08-18-2009, 02:11 PM   #28
SteveH's Avatar
Common Sense , Texas
Don't know anything about Cabelas' generators, but if they are 2 cycle engines, you can bet they are noisey.
Looking at Generators Nightwind15 2005 and newer - Bambi all models 22 01-21-2013 08:51 PM
generators spikesss Generators & Solar Power 8 05-02-2009 10:27 AM
Generators Squid All Argosy Trailers 13 12-19-2008 04:57 PM
generators simzeez 1970 - 1973 Sovereign 3 04-30-2005 10:08 AM
Generators PeterH-Airstreamer Airstream Motorhome Forums 25 09-07-2004 09:46 AM
