Old 03-11-2016, 01:07 PM   #1
1973 31' Sovereign
van nuys , California
Generators
I am sure the question has been discussed before but does anybody have experience with generators powered by propane? I do not like the idea of a can of gas sloshing around or aging if I do not use it regularly.
Anybody?
THANKS,
Didier
starboard is offline   Reply With Quote
Old 03-11-2016, 01:43 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Make a point of using it regularly. Even with a propane generator you should still "exercise" it at least once a month for about half an hour. If you don't run it that often, moving parts do not stay lubricated properly, and you will experienced increased wear and harder starting when you do eventually run it. Generators can suffer from neglect even if they don't have "stale" gasoline in them.
So if you don't have a reason to use your generator— any generator— at least that often, you should make up excuse to use it. Use it to run an air compressor to air up your tires, whatever, as long as you don't just let it sit for months on end.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-11-2016, 02:46 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
YEP...... the ? has been asked MANY times.....
I converted our Honda 2000 in 2007.....no regrets at all.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 03-11-2016, 02:54 PM   #4
r carl's Avatar
Lin , Ne
This is what happens when you get a propane leak.
Old 03-11-2016, 03:05 PM   #5
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
search "propane generator airforums" on your favorite search engine (not on this site's search function), and you should find lots and lots of threads to read . . . people are generally very "pleased" after making the switch to propane
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 03-12-2016, 11:48 AM   #6
1973 31' Sovereign
Thank you everybody, even R CARL for trying to scare me a bit but I have a propane sensor with a solenoid valve, works like a charm. I used to have a sail boat and now I have a Land Yacht! Treat them the same.
Didier
Old 03-12-2016, 02:46 PM   #7
2015 28' International
Ofallon , Missouri
I'm about to buy a Yamaha and plan to get the tri fuel option but mostly run from LP on the AS.
mpsgolf is offline   Reply With Quote
Generators . . . again? dinoburb Generators & Solar Power 6 03-18-2008 07:36 PM
Generators PeterH-Airstreamer Airstream Motorhome Forums 25 09-07-2004 09:46 AM
Generators csimingt 1999 Safari 11 07-26-2004 08:38 PM
Solar and Generators Melvin P. Thorpe Generators & Solar Power 43 05-11-2003 08:51 AM
Generators...one more time! APB Electrical - Systems, Generators, Batteries & Solar 0 03-09-2003 08:52 PM
