Old 09-10-2012, 06:43 AM   #1
2011 Interstate Coach
ISTANBUL , USKUDAR
Generator won't start
Hi,
I have just bought Airstream Interstate 2011 (Mercedes 3500).
My problem is; The generator tries to start/run (as i keep pushing the start button from the control panel inside the motorhome) but it does not keep running and it immediately stops when I stop pushing the start button.
Why this could be happening?
Also , where can I download a user manual for the Onan Generator?
arifarda is offline   Reply With Quote
Old 09-10-2012, 06:57 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by arifarda View Post
Hi,
For the benefit of those who don't see my response to the same question on the "Onan 2.5 KW Generator" thread (Post #21) on the "Sprinter and B-Van Forum," here it is again…
Manual is located at http://www.cumminsonan.com/www/html/...s/981-0153.pdf
Troubleshooting:
1 - Is the propane solenoid turned on behind the curb-side rear wheelwell?
2 - Is there propane in the tank?
3 - Is the battery disconnect switched on?
4 - Do you have enough voltage on the house batteries? If battery voltage is too low, the starter will turn, but not fast enough.
5 - Is the inverter switched to "charge only"? If batteries are providing power to the inverter because it's set to "auto/invert", you don't have the full charge available for starting.
6 - Have you "primed" the generator by pushing the switch to "Stop/Prime" before trying to start it? You may have to hold it on "stop/prime" for several seconds first before starting.
7 - Are all appliances that use AC power switched off? Generator will not start under a load, and needs to be running for about a minute before starting any AC appliances.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-11-2012, 12:53 AM   #3
ISTANBUL , USKUDAR
Dear Protagonist, thank you for your help.
Old 09-14-2012, 12:38 AM   #4
ISTANBUL , USKUDAR
The problem is solved.
It was because of the propane solenoid. I turned it on and the generator run.
Thank you all for your support.
