Old 04-18-2013, 09:38 AM   #1
2010 30' Flying Cloud
Jefferson City , Missouri
Generator Problem
I recently purchased two 2000 watt Honda generators ,for running paralell,to power my 2010 Flying Cloud. After running for about 4 hours and after successfully testing my a/c etc. the camper power started to go off and on in about 2 second intervals without the gen indicator lights showing any malfunction. The only appliances on at the time were the lights, tv, fridge. After disconnecting the power cord and trying again the problem continued. When I reconnected to The 30amp campground power everything worked perfectly. I took the gens to the Honda service center and they said they could not find anything wrong. My RV tech says that if something was wrong with the camper electrical system the problem would occur when plugged into the land power as well. Does anyone have any ideas?
butchabb is offline   Reply With Quote
Old 04-18-2013, 10:55 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Could be that shore power is pure sine wave and generator power is modified sine wave. Shouldn't affect the lights, but the television might hiccup on modified sine wave. But that's just a guess, not a diagnosis.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-18-2013, 11:05 AM   #3
1974 Argosy 20
Kooskia , Idaho
The Honda inverter generators are all pure sine wave units.
Old 04-18-2013, 11:05 AM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Isolate for your testing as much as possible.
It sounds like you were running both of the Hondas in the parallel setup, even though you're not running the AC right now. Try running each of the Hondas individually to power the load you mentioned in the trailer (lights, TV, fridge) and see if you can duplicate the problem with one or both. It could be that the problem is in the parallel setup rather than either generator, and your Honda dealer may have tested each generator on its own and not trained up together in parallel.
— David
Old 04-18-2013, 12:38 PM   #5
Darn. Wrong twice in one day! Electrickery, that's what it is!
WBCCI #1105
TAC LA-4
Old 04-18-2013, 02:09 PM   #6
richinny's Avatar
2011 34' Classic
was the water heater on gas or electric? (1300-1400 watts)
the converter was also connected. (wattage varies by load)
Ricky
Old 04-18-2013, 02:14 PM   #7
DKB_SATX's Avatar
1976 Argosy 28
Even so, if the problem was overloading the generator set that should have been indicated at the generator, and I wouldn't expect the intermittent behavior that was described. Also, if he were running the 2 generators in parallel, he should have little difficulty running everything in the trailer that he could run on 30A shore power.
— David
Old 04-18-2013, 02:18 PM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
How were you plugged in?
Hi, it seems tha most all of the newer trailers have a generator inlet and a shore power inlet; These have have been known for a relay type problem. [transfer switch]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-18-2013, 03:17 PM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
That would be a personal best for me- as in wrong ONLY twice in one day.
Old 04-19-2013, 09:51 AM   #10
Thanks for the input. I was running the gens in paralell when intermittent problem occured. The hot water heater was on gas. I did not think to try to run the gens individually though the dealer said they tested both ways without any problems. I did plug the land power into both the gen and land receptacle but not the gen power. Did not have any problem with either receptacle. Any other suggestions? Thanks
Old 04-19-2013, 10:10 AM   #11
1974 Argosy 20
Kooskia , Idaho
Try contacting "Robert at Honda" who is a forum member who works for Honda and answers questions relative to Honda generators, but on a personal basis, not as a Honda representative.
I am not quite sure how to find him though. Maybe someone else can chime in here.
Old 04-19-2013, 10:11 AM   #12
dznf0g's Avatar
Oswego , Illinois
Is one a Companion model? Using the correct paralleling cable? If they are both non-Companion models, there is a special cable with a "magic box" in-line. The Companion has this magic circuitry in the unit itself.
-Rich-
Old 04-19-2013, 10:37 AM   #13
richinny's Avatar
2011 34' Classic
contact robert through his profile:
Airstream Forums - View Profile: robert@honda
Ricky
Old 04-19-2013, 12:58 PM   #14
Thanks for the lead with Robert, I'll give him a try.
