Old 01-11-2012, 09:47 PM   #1
Dean&Dawn's Avatar
2007 23' Safari SE
Lockport , Louisiana
Generator Prep Kit
I would like to add a 30 amp plug to the front of our AS. I have seen it available as an option on newer trailers. I'm looking for any information that would help me accomplish this.
Dean & Dawn
2007 Safari SE LS
2011 F-150 5.0L
Dean&Dawn is offline   Reply With Quote
Old 01-11-2012, 10:01 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I'm considering the same thing; Let's see what shows up.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-11-2012, 10:13 PM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Good Luck
You need a transfer switch for starters.
Second getting a 10 GA wire from the rear to the front is not easy. As an option it goes in the wall before the inner shell is installed.
You would have to run it underneath.
Michelle TAC MT-0
Sarah, Snowball
Old 01-12-2012, 07:15 AM   #4
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Someone added an extensive solar system and giant inverter to our trailer (probably the original owners), and they ran 120 volt lines to the inverter (and back to the box) inside the trailer. I'm not sure where they go through the bedroom, but they're behind the sink in the bathroom, behind the fridge, then under the tables in the front. They're barely noticeable actually - you have to look to see them.
This thread gives me an idea...since that wire is already there it would NOT be hard at all to do this to ours. And I could fix the inverter wiring to boot, if they make three-way transfer switches...
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 01-12-2012, 08:06 AM   #5
Dean&Dawn's Avatar
2007 23' Safari SE
Transfer Switch
Thanks for the Info
30A Transfer Switch
Progressive Dynamics - Progressive Dynamics 30 Amp Generator Transfer Switch - Generator Accessories - Camping World
Old 01-17-2012, 06:08 AM   #6
Leavingtherut.com
TavnAsh's Avatar
2005 30' Safari
Key Largo , Florida
Actually a very easy job. I can post pictures, but all I did was wire in a marine 30A transfer switch, drill a hole through the floor behind the electrical panel, route outdoor 30A cable to the transfer switch and attach the cable to the belly with stainless straps and screws (near where it is riveted for structural stregnth). At the hitch I left enough free cable to make it to the back of the truck then used male and female marine locking 30A connections to plug it into a generator cable I made in the same fashion. When not in use, cable sits over hitch just like the 7 way does. The entire project cost me about $175 and 2 hours. I also overbuilt it for safety. Let me know if u have any questions.
Finding our normal, one day at a time.
http://www.leavingtherut.com
TavnAsh is offline   Reply With Quote
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
Lift Kit palmtreegirl Jacks, Stabilizers, Lifting and Leveling 4 10-12-2012 07:21 PM
Airstream owners Welcome kit Chillpoints General Repair Forum 6 12-07-2011 01:58 PM
Window and Door Gasket Kit? 1976 Sovereign gronlampa Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 08-17-2011 06:22 AM
AquaJet ES water pump rebuild kit? Wingeezer Water Heaters, Filters & Pumps 3 06-03-2011 01:15 PM
