Originally Posted by unsui
I plan to spend much of the winter traveling south in a Flying Cloud 30 with dual air conditioners and 50 amp service. ...Towing with a Toyota Tundra....Any opinions appreciated
My question would be is how are you going to haul it?????
The maximum payload for a Toyota Tundra is 1555 lbs (as per Edmunds).
The tongue weight on the 30' Flying Cloud (with a decent hitch and 60 lbs of fuel) is probably approaching 1200 lbs - extrapolating from the 28' specs and not adding any additional variable weight.
That leaves 355 lbs in the Toyota for fuel, passengers, generators, or other gear.
Tow vehicle total loading does not appear to be within manufacturers specification envelope at all - a trip to the scales would be in order.
