Old 06-28-2009, 12:11 PM   #15
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have used our 2000's in the rain on several occasions. We also have a small youth tent for them, but have yet to use it. We have been putting the generators partially under the back of the Suburban with the control panel furthest under the car. We have not had any problems doing this.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 06-28-2009, 10:29 PM   #16
rustyrivet's Avatar
2005 22' Safari
Gresham , Oregon
This generator question is truly tough to figure out. A number of posts say the Yamaha 2400 will run the A/C unit without a problem and others say otherwise. Mine is only a 13500 AC unit and the book says you need 3500 amps to run it. I would like to run it with just one gen but had just about decided that I needed 2 Honda 2000i's to do the job. I guess I would like to know if the A/C unit will truly start with the 2400 Yamaha and, if so how well does that unit work with the propane set-up? some folks have said it runs well but needs to be primed before starting. Is that correct? All other things being equal (and they never are) propane appears to be the logical choice since other thing in the unit can also run on the propane. jc
rustyrivet is offline   Reply With Quote
Old 06-28-2009, 11:50 PM   #17
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hear say!
Originally Posted by rustyrivet View Post
This generator question is truly tough to figure out. A number of posts say the Yamaha 2400 will run the A/C unit without a problem and others say otherwise. Mine is only a 13500 AC unit and the book says you need 3500 Watts to run it. I would like to run it with just one gen but had just about decided that I needed 2 Honda 2000i's to do the job. I guess I would like to know if the A/C unit will truly start with the 2400 Yamaha and, if so how well does that unit work with the propane set-up? some folks have said it runs well but needs to be primed before starting. Is that correct? All other things being equal (and they never are) propane appears to be the logical choice since other thing in the unit can also run on the propane. jc
Hi, my Yamaha 2400, when plugged into my trailer's 30 AMP cord, will run my converter, my refrigerator, and my 11,000 BTU air conditioner. I have heard that this generator will run the 13,500 and the 15,000 BTU air conditioner, but you have to turn your refrigerator to propane mode. I cannot confirm this; It is hear say until someone with experience can confirm it.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-29-2009, 05:39 AM   #18
beaubill57's Avatar
1992 25' Excella
2002 25' Classic
Daphne , Alabama
Honda 3000
Has anyone looked at the new light weight Honda 3000. I believe they weight a little over 70lbs. Check out Camper World.
2002 Classic 25 "The Silver Sleeper"
beaubill57 is offline   Reply With Quote
Old 06-29-2009, 08:28 AM   #19
redeagle313's Avatar
NE , Indiana
First to comment on whether the Yamaha 2400 efis will run the 13,500 btu AC? Yes it will, it runs the AC on our 28' CCD. I have the tri-fuel option, and the generator runs sooooo smoooooth on propane.
Be aware (and beware) that to get to 3000 watts in a small package, the new Honda has a small fuel tank (less than four hours run time) and it has less sound insulation, so it is almost 8 db louder than the Yamaha.
Hi Yo Silver, Away II?
looking for our next AS
TAC IN-3
AIR 7185
redeagle313 is offline   Reply With Quote
Old 09-01-2009, 03:23 PM   #20
Livin' the dream...
FastMikie's Avatar
2009 17' Sport
Del Mar , California
Send a message via Skype™ to FastMikie
What am I missing? I just bought that EF2400IS with the tri-fuel option and IT WILL NOT START the 13,500 BTU AC unit on my Sport 17. The Airstream service rep just told me that Carrier (who makes the AirV unit) says the unit draws 28 - 29 amps to get the compressor going (3335 watts) and only 12.8 amps (1472 watts) to keep it running.
What model AC unit are you starting with this generator?
I have heard of a "soft-start" modification that might drop the startup amps way down. Any info on that?
Thanks for any help...
FastMikie is offline   Reply With Quote
Old 09-02-2009, 08:39 PM   #21
rustyrivet's Avatar
2005 22' Safari
Gresham , Oregon
Sounds like there are still a lot of questions about the ability of the 2400IS starting and running a 13500BTU A/C. Some say yes, emphatically and others say no, it won't do it. Generally, if I'm going to err, I will err on the conservative side and get a little more power than is needed, so I sounds like I still need two Honda 2000's to be safe. jc
2005 22 ft Safari LS
2009 Toyota Tundra
Hensley Hitch
Lifeline AGM's
Old 09-02-2009, 09:12 PM   #22
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Here is a link to the specs for a 13.5K Carrier.
http://www.airv.carrier.com/Files/Ai...e/62-11187.pdf
Richard
Generator Newbie Questions. ROBERTSUNRUS Generators & Solar Power 24 01-19-2010 01:21 PM
Another Generator/AC Question craftsman Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-22-2008 03:16 PM
Generator Question? ssolid 1970-79 Tradewind 3 11-06-2004 04:48 AM
Generator question Princess Generators & Solar Power 14 03-03-2004 10:14 PM
another Generator question George Airstream Motorhome Forums 3 08-14-2003 05:17 AM
