Old 02-13-2010, 08:15 PM   #1
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
Generator: Just learning.
I bought a Honda 3000is generator today. Have been out of electricity for over 3 days becasuse of the snow knocked out our power in our home. So we lived in the Airstream for warmth. Furnace never stopped blowing. My batteries did well. They lasted about the whole time. Had to plug up my truck and remote start it for power in the latter stages just to make sure I wouldn't lose all power.<lights were getting dim>
So was on the way to the store to buy a generator and the neighbor called and said the power was back on. I went ahead and bought one anyway. I'm gonna use it to boondock, so it was a smart purchase in the long run, I think. It only has 24.7 amps. What will be my restrictions? Like no A/C and microwave<convection> at the same time. But otherwise I should be ok, right?
Thanks in advance for your input.
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 02-13-2010, 09:21 PM   #2
1992 29' Excella
Nashville , Tennessee
We have the same generator, and it will run everything in the trailer. Our trailer has a switch in the cabinet over the kitchen sink that will allow powering either the air conditioner or the microwave, but not both at the same time. This may tell you something.
That said, if I run the air conditioner, the eco-throttle must be off. Eco-throttle allows the engine RPM to remain low until there is electrical demand that requires a higher RPM. The problem is that the air conditioner compressor has a high enough inrush current, that the engine doesn't have enough time to increase the RPM before an overload occurs, and it trips off. The fix is to simply switch the eco-throttle off when running the AC. The idle speed will be increased, and it will be a little louder, but the generator has no problem running it.
If you are using the generator to power the converter/charger to top off the batteries, you can leave the eco-throttle on. You can just barely hear it in the trailer, with the windows closed.
I mostly use mine to keep the batteries up when boondocking. If I was to do it over, I'd opt for two 2000 watt units and the parallel kit. Not because we need 4000 watts, but because the 2000 is much smaller. The 3000is is too large to manhandle by myself.
I'm very happy with the performance and low noise level of the 3000is.
jimb757 is offline   Reply With Quote
Old 02-13-2010, 10:01 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
30A usually is mentioned as the required level to run the A/C -- an easy statement to make since 15A, 20A & 30A are common outlet sizes. Mention 30A to an electrician and they may naturally thin 240V ... NOT! The A/C is 120V.
But the most common figure I've heard is that the compressor will draw in the neighborhood of 22-23 volts. This post is a most excellent perspective -- http://www.airforums.com/forums/f37/...tml#post648436
So ... you are right. Just don't use the A/C and microwave at the same time.
5 meter Langford Nahanni
Old 02-13-2010, 10:05 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
You really meant 22-23 amps didn't you Bob?
Vaughan
Old 02-13-2010, 10:27 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
This has been the ony negative feature of the 3000i that anyone has mentioned.
Having 2 2000i's also gives you the option of only running one if you don't need the 4000w. And running two 2000's doesn't double the noise level, decible levels remain the same.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
ďItís a crooked piece of time that we live inÖ.Ē
John Prine
Old 02-13-2010, 11:58 PM   #6
Bo&Susan's Avatar
Daleville , Alabama
We are looking at the Honda 3000 Handi. Do you think 2 2000 would be wiser? Thanks Susan
Bo&Susan is offline   Reply With Quote
Old 02-14-2010, 12:30 AM   #7
_
YES
but really it depends on issues...
lots of threads on these issues here are the most useful to begin with...
http://www.airforums.com/forums/f448...0-a-13986.html
http://www.airforums.com/forums/f448...0is-57897.html
http://www.airforums.com/forums/f448...0-a-19725.html
http://www.airforums.com/forums/f448...000-50043.html
http://www.airforums.com/forums/f448...ors-39684.html
http://www.airforums.com/forums/f448...sed-33874.html
and last but not least...
http://www.airforums.com/forums/f448...tor-44248.html
good luck with your choice AT LEAST u r asking the question beFORE buying one...
the "3k handi" is a new model/last year and VERY nicely packaged with wheelz and handle...
but i'd still opt for 2x2000 in most situations...
and the newest 2000 model (companion) no longer needs the 'parallel kit' to be 2x connected.
a simple 2 wire set is ALL that's needed (about 30 $) and there's a 30 amp plug ON the genset...
nice!
cheers
2air'
Old 02-14-2010, 12:45 AM   #8
Bo&Susan's Avatar
Daleville , Alabama
Thanks! that really helps, Bo and I will look over them all tomorrow. Susan
Old 02-14-2010, 07:00 AM   #9
Whirlaway's Avatar
2008 27' Classic FB
Anytown , Massachusetts
I went with a second 2000 companion
I had the 2000 originally and went back and forth for a whole season what to do?
I finally decided on the second 2000 companion, due to the additional power when coupled, as well as the weight consideration.
In reality the weight issue was a big factor for me since at 70+ pounds for the 3000 Handi it's still a big package to more in and out of the vehicle alone.
Life Is Not A Dress Rehersal
It's okay to have too much fun
WBCCI #8701* TAC MA-1 * NEU UNIT
Gracie...A Liver & White GSP
Get busy livin', or get busy dyin'." - The Shawshank Redemption
Whirlaway is offline   Reply With Quote
Old 02-22-2010, 10:22 AM   #10
2008 27' Safari FB SE
Champaign , Illinois
We have a 3000is and, yes it is too heavy to lift more than once during a trip. Is it okay to leave it in the very back of our GMC Yukon XL with the rear gate window open while using it? The height of the 3000is exhaust is above the rear gate of the SUV so the exhaust goes out the window when open. Of course we don't intend to use the generator when in, or driving the SUV, just while camping. Thanks for your help... Dennis
dfpotten is offline   Reply With Quote
Old 02-22-2010, 01:13 PM   #11
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
I'd be leary of getting a residual exhust smell in the vehicle.
Maybe a tarp behind the generator to block any chance of fumes getting in?
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 02-22-2010, 02:05 PM   #12
Refurbished 89 Excella
DKDarrow's Avatar
Sugar Valley , Georgia
dfpotten.........For years, have been using the 3k Honda both in and out of the TV. We have a camper shell and when in camp for an overnighter we just open up the back and fire it up. NO PROBLEMS......In your case though, golly just depends on how much you value your interior. What do you do on rainy muggy days when you need the power for the AC in the trailer but hesitate to close that window to protect the interior?......If there for a few days we, my wife and I, tote that heavy mother where it needs to go and get on with life. To much sometimes is made out of just doing it.....GET IT DONE........Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
DKDarrow is offline   Reply With Quote
Old 02-22-2010, 03:23 PM   #13
Thumbs up
Our rainy day solution...
Three person tent from CW..
Handy place to store extra stuff too...
PFC
"Tahawus"
RLC
John Prine
Old 02-22-2010, 05:51 PM   #14
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Generator
We use the Honda 3000 and have it chained in the back of our pick up TV. We leave it there for most of the traveling season as it is very heavy. When we use it we just fold back the cover of the bed about 1/4 way. It powers all of our 65 Safari including the AC. We love the electric start which accounts for a bunch of it's weight. I like that it will run my AC even while direct charging a deep cycle battery. We don't use a microwave so that is not an issue for us. If our TV was not a pickup then I would consider two 2000 Hondas.....Tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Learning to Cook Finally Sarah3 Stella's Kitchen 2 02-06-2010 05:04 AM
Learning How To Tow SRW Towing, Tow Vehicles & Hitches 1 04-24-2009 05:56 PM
Newbie - still learning 74"Twinkie" Member Introductions 13 07-08-2007 09:49 PM
New and Learning david b jone Sinks, Showers & Toilets 3 04-16-2007 10:00 AM
Learning how MO/Ron Member Introductions 2 04-25-2006 08:30 PM
