Old 05-30-2016, 04:26 PM   #1
Davadar's Avatar
2005 19' Safari
2010 30' Flying Cloud
Langton , Ontario
Generator issue? Need help.
We recently sold our Yamaha ef3000 only because of its weight and size. We bought two Yamaha ef2000's and the sidewinder parallel cord. Each of the new generators has been used separately with no problems. This past weekend I hooked them up in parallel to use the air conditioning. The GFCI circuit breaker tripped and could not be reset. Has anyone else experienced this issue? What could the problem be? Thanks in advance for the help.
Davadar is offline   Reply With Quote
Old 05-30-2016, 05:33 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
What GFCI breaker tripped?
I will assume you followed the directions in the manual for connecting and placing a load on the generators.
If you disconnect the generator will the GFCI reset?
Could be a bad circuit breaker.
Old 05-30-2016, 07:34 PM   #3
Davadar's Avatar
2005 19' Safari
Langton , Ontario
The GFCI in the washroom outlet trips and cuts out power to the rest of them. The refrigerator also switches from ac to gas. When I switch back to just the one generator I can reset the GFCI. The owners manual for the generators says for twin tech operation check manual supplied with cord. There was none so I checked online. I'm connecting the ground and plugging in the banana plugs to each generator then starting each generator.
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
House batteries/generator issue BrianKrueger Sprinter and B-van Forum 46 09-13-2015 11:04 PM
2016 Interstae Grande Tour Generator Issue DI27 Mechanics Corner - Engines, Transmission & More... 0 07-20-2015 04:59 AM
Generator gas hose issue-warning gmillerok1 Sprinter and B-van Forum 0 10-23-2014 10:34 AM
Dangerous Onan generator issue linda7915 Land Yacht/Legacy Motorhomes 5 12-05-2013 08:19 AM
