Old 02-26-2015, 07:20 PM   #1
2014 27' FB International
Macon , Georgia
Generator In Truck Bed Problem
I would like to go with a Yamaha 4500kw generator and carry it in my pickup truck bed. The problem I have is I want to put it under a tonneau cover but it is about 6 inches taller than the bed sides. Any suggestions how I could make this work so the generator would be protected from rain and theft?
Roadtech is offline   Reply With Quote
Old 02-26-2015, 07:48 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
You can't make it work. The generator can't be made 6 inches shorter, and the tonneau cover can't be made 6 inches taller. You would be better served by a pickup bed cap the same height as the pickup cab.
Cats and ultraleather Airstream upholstery don't mix!
Old 02-26-2015, 08:05 PM   #3
Macon , Georgia
Come on now, let's think out of the box!
Old 02-26-2015, 08:08 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
What kind of tonneau cover? Ours is a soft cover with bows and it is several inches taller in the middle. If you have one of the hard fiberglass ones I suppose you could mount a hood scoop on it.
Aaron
WBCCI #XXXX AIR #2495
Old 02-26-2015, 08:25 PM   #5
Airstreamer in Training
ZBoater's Avatar
2014 30' Flying Cloud
Now I LOLed at this...
2014 Airstream Flying Cloud 30' Recliner: Base weight 6422, GVWR 8800
2013 Cadillac Escalade Tow Vehicle: 6.2L, 403hp, 417 ft-lb., 4x2, 3.42 axle ratio, Max Payload 1573, Max Towing 8300.
ZBoater is offline   Reply With Quote
Old 02-26-2015, 08:44 PM   #6
z , North Carolina
Do you NEED that big of a generator?
FishinHatteras is offline   Reply With Quote
Old 02-26-2015, 08:47 PM   #7
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Go to a metal fabricating shop and have them build you an aluminum enclosure. It could be rounded and look like a mini Airstream. Seriously, a good shop shoud be able to make a cabinet similar to what welding or service trucks have. It might be costly, but it will look good and protect the gen set.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 02-26-2015, 08:56 PM   #8
Macon , Georgia
Now, that's interesting...
Old 02-26-2015, 09:29 PM   #9
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Is there anywhere in the bed that the floor sheet metal could be cut out the size of the generator's foot print. if there is an area with enough clearance, you could fabricate an aluminum box with a lip around the edge to sit in the hole and support the generator at a lower level.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 02-26-2015, 10:00 PM   #10
Stream'n's Avatar
2014 27' Flying Cloud
Lexington , Oklahoma
Here's a thought. Scrap the tonneau cover and either chain or bolt the generator to the bed, then build a box to fit over the gen or, use a vinyl cover to protect from rain. If you have a standard size trk bed your not going to have a lot of room left anyway. You could cover or bag anything else that goes in the bed to keep it out of the rain.
Stream'n is offline   Reply With Quote
Old 02-26-2015, 10:17 PM   #11
Stream'n's Avatar
Here's another thought. Get an electromatic shrinking machine , shrink it while traveling, then enlarge when you're ready to use. I don't know where to buy them but I know they make them because I saw one in "Honey I Shrunk the Kids." 😃
Where's Red when we need him, LOL
-Wes-
Old 02-26-2015, 10:32 PM   #12
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Perhaps a pair of Honda 2000's would do the job and fit without mods.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 02-27-2015, 12:30 AM   #13
2011 23' International
clovis , California
what protagonist said!
jgerardi is offline   Reply With Quote
Old 02-27-2015, 01:16 AM   #14
How about a vertical spacer connected to the top rails of the bed and gate? Then you could attach your cover to the spacer just like you would normally attach the cover to your bed top.
You could weld together pieces of steel to build a "cage" and cover the open spots with aluminum panels that are riveted to the steel? Won't that look sexy with your trailer?
If you aren't worried about the aesthetics maybe you could just bolt 8" x 8" pressure treated lumber to the top four sides of the bed. Then mount the cover directly to the wooden frame?
Good luck!
2Fast4U is offline   Reply With Quote
Old 02-27-2015, 01:36 AM   #15
Glenritas's Avatar
1969 25' Tradewind
Or this ...
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
Old 02-27-2015, 06:18 AM   #16
r carl's Avatar
Lin , Ne
Cut a hole in the box.
Old 02-27-2015, 06:35 AM   #17
paiceman's Avatar
Upper St Clair, PA , PA-Summer/FL-Winter
Either as stated go with a cap, OR I simply keep the soft cover back and run the generator when I need it rain or shine. I cover it when it's not in use in the bed with a cover purchased for such purpose. It is locked into the bed of the truck, still can be stolen, but then a vinyl cover is only eye deterrent anyway. Had mine for four years, only use occasionally and when not in the bed of the truck, it's in the garage.
SAFE TRAVELS
Bud
Starting to Look (AGAIN) Number 5 Hopefully
USAF Training Instructor (TI) - 68-72
Old 02-27-2015, 06:57 AM   #18
stream lady's Avatar
1975 Argosy 20
new iberia , Louisiana
Generator
We have a Yamaha 4000 with the Tonneau cover on a Ford 250 and all works fine.
stream lady is offline   Reply With Quote
Old 02-27-2015, 12:24 PM   #19
2010 22' Sport
Boise , Idaho
Okay, time to get a new train of thought going. How about tipping the generator against the wall of the bed not so much that fuel comes out but enough so that it fits under the cover. Lash her in tight and hit the road!
baldwin6601 is offline   Reply With Quote
Old 02-27-2015, 01:45 PM   #20
2000 30' Excella
2014 30' Classic
Princeton , Iowa
I have 2 Honda 2000 that hitch in tandem, I really like them. Easy to load, can be used in or out of the truck and for chores around the house. I use a mid to heavy chain to keep them mine.
By the way they are very quiet.
larryglarson is offline   Reply With Quote
Generator - gas can size; run from truck bed; general guidance Soul Food II Electrical - Systems, Generators, Batteries & Solar 16 05-30-2014 10:40 AM
Generator in tow truck bed-wiring the trailer safariuser Batteries, Univolts, Converters & Inverters 6 02-06-2013 12:00 PM
Spray-in truck bed liner for shower tank? dsakaki Sinks, Showers & Toilets 9 02-14-2009 07:05 AM
Truck bed covers? Could use some help! maxandgeorgia Off Topic Forum 17 05-26-2004 11:45 AM
