Old 07-04-2014, 10:02 AM   #15
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Uh, what you are describing is done sometimes to power items on the same circuit in emergency situations but it is not a good practice. You can burn up wiring depending on the generator- if over 15 amps output--too much. It would have to be 2000 watt or less. You also have to turn off all circuits but the one that is on that outlet as the feedback would try to power everything on every circuit- messy.
Another mistake made on generators is thinking that you get more power if you use a two outlet adapter to single output. These adapters were taken off the market not long ago as people were blowing house circuits and ruining things. This is dangerous. Smaller generators may only have a two standard output receptacle. (120V dual wall outlet style). Use one and only one outlet to hook up as they may not be in phase. The generator will give all of its available power to that one outlet based on load.
Everyone already covered most everything. Always use the trailer power cord to plug it to the main power coupling on the trailer using the adapter at the generator end or wall socket/power source. I have one of those circuit protection devices that I use. It has a current draw meter on it. My AC pulls 12A at initial start then goes down to where the meter alternates between 9-10 Amps if you watch it long enough. (Dometic Penguin 11K BTU unit). I always have a 50/30, 30/20(120V) adapter set for my 30AMP model and this optional piece. I keep it attached to the trailer power cord at all times with the lock cap. It protects against just about everything- messed up ground, too low a voltage for the draw, surge, etc. It runs a series of tests before completing the circuit. I find it takes all the guesswork and wonderment out of electric and protects the trailer too:
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-24-2017, 05:53 AM   #16
Virginia Beach , Virginia
My question is very similar in that I have a 28 ft FC with 50 amp service. Do I plug-in the generator into the same plug that I put shore power? I do not have a front plug like the 25 and 27 foot models have.
petermday is offline   Reply With Quote
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Outside water hookup question. 68 Suburban Fresh Water Systems 6 10-05-2013 02:25 PM
No grey tank, no sewer hookup Safari Tim Our Community 8 07-11-2003 07:36 PM
Is this the city water hookup? Stefrobrts 1966-68 Caravel 7 05-06-2003 10:13 AM
Hose for gray water to sewer hookup?? eikel1we Waste Systems, Tanks & Totes 12 03-11-2003 01:49 PM
