Old 06-11-2007, 06:49 PM   #1
2005 22' International CCD
Woodland Park , Colorado
generator grounding
Hey all,
I plan to run my generator out of the bed of the truck instead of loading and unloading it. To ground it, can I just run a wire from the generator ground and attach to the bed or frame? Thanks in advance. jk
JK3500 is offline   Reply With Quote
Old 06-11-2007, 06:53 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I would not ground it to your truck. I would use a three prong cord and adapter and let it ground to your trailer. Ground it to your truck could set up a ground loop. Bad.
Michelle TAC MT-0
Sarah, Snowball
Old 06-11-2007, 06:55 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by JK3500
Hey all,
Not unless the truck has solid steel tires You really need to run a wire to a ground rod of some sort. We used to use a 3' piece of rebar driven in the ground with a pair of jumper cables hooked to it. FWIW at typical house ground rod is around 6'-8' long...
Aaron
WBCCI #XXXX AIR #2495
Old 06-11-2007, 07:19 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
If you're boondocking, a grounding rod pounded into....'the ground' is a very good idea. Use a moderate cable to attach it to your gen....like an 8 AWG cable. Be sure that the connections are TIGHT AND CLEAN.
A ground circuit is basically a safety valve and a return path for excess current if a nuetral fails, so your truck, being 'insulated fromt he ground by the tires' won't achieve this effect.
DO NOT GROUND IT TO YOUR TRUCK. It won't achieve the grounding effect that you desire.
Old 06-11-2007, 07:44 PM   #5
zamboni's Avatar
"DO NOT GROUND IT TO YOUR TRUCK. It won't achieve the grounding effect that you desire."...and if a fault occurs, it will shock you anytime you touch the truck or trailer (if attached to the truck). Might be a good burglar catching devise though! )
zamboni is offline   Reply With Quote
Old 06-12-2007, 12:23 AM   #6
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
uhh...
I'm not sure why the generator needs to be grounded? I just put the Honda on the ground and fire it up. Is it different in the truck? I don't think I've ever noted people grounding their generators, even when operated from the truck bed?
Marc
Old 06-12-2007, 01:03 AM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, a three wire connection at the generator to a three wire connection to the trailer should be all the ground you need.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-12-2007, 02:12 AM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
But you aren't grounding anything by doing that....think about it. If you plug into shore power there is a ground rod somewhere in the system. The Airstream itself is not grounded, the truck is not grounded. If you don't ground the generator it isn't grounded.
People run generators all the time without grounding them...
and they don't read the directions that come with them that say that it requires grounding. I have seen someone get a pretty good jolt when a tool had a bad ground wire on it, and the generator wasn't grounded. People have been killed when something has gone wrong and the generator wasn't grounded. I am not an electrician but I know that you have to be grounded to a ground rod for safety. Can you get away without a ground rod, yes but eventually, somewhere, somehow, someone is going to get killed by not using one.
Aaron
Old 06-12-2007, 03:59 AM   #9
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
So what should you do when you stop at a Flying J or Wal Mart? I don't think they would let you stay if you drove a steel rod in their parking lot.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 06-12-2007, 04:58 AM   #10
1979 30' Argosy
I did a bit of checking on this. A gen. only needs grounding if it is a Separately Derived System. If the generator is connected to a transfer switch that transfers the neutral. and the generator dose not have a grounded circuit conductor, then is is a separately derived system. A separately derived system requires a connection to a grounding electrodes or grounding rod. So I am sure that companys like Honda and Yamaha and the others build their generators with a grounded circuit conductors.
Marvin
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 06-12-2007, 05:55 AM   #11
lewster's Avatar
If you read the gen instructions, you will see a little note that says to GROUND THE GENERATOR. That's why there is a binding post on the front panel of the units marked 'GROUND'.
As I stated above, the electricity needs a pathway (for safety reasons) to return to ground if the neutral fails for any reason. Avoid it at your own risk.
Old 06-12-2007, 06:10 AM   #12
Got it. Ground it to the ground. Thanks all for the info. jk
Old 06-12-2007, 06:37 AM   #13
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You CAN ground it to your truck, then ground your truck to your trailer, then ground your trailer to ground, it is just unnecessarily complex to do.
Old 06-12-2007, 06:52 AM   #14
1979 30' Argosy
If the gen. shorts out won't it kick the breaker?
Marvin & Annie
Niki (fur baby)
WBCCI 10103
