Old 06-12-2007, 07:00 AM   #15
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
Originally Posted by lewster
If you read the gen instructions, you will see a little note that says to GROUND THE GENERATOR. That's why there is a binding post on the front panel of the units marked 'GROUND'.
As I stated above, the electricity needs a pathway (for safety reasons) to return to ground if the neutral fails for any reason. Avoid it at your own risk.
what about the onan gen built in to the tt and moho.they don't say to put in a grounding rod.so much confusion on this subject.
just want to camp happy
bobchevy89 is offline   Reply With Quote
Old 06-12-2007, 07:09 AM   #16
lewster's Avatar
Naples, FL , Hood River, OR
All Mohos that use generators have an internally connected ground; the system is closed. My '98 Monaco had a Onan 7500 watt diesel gen that was grounded to the system thru the transfer switch, so the mechanical and electrical grounds (neutral) were always connected in a closed loop.
I suppose that you 'could' do the same for an external gen for your trailer, that is.....connect it to the trailer ground and then rely on the ground contact of the front tongue jack and the stabilizers to provide the earth contact. It would work, perhaps not as efficiently as a direct grounding rod.
Old 06-12-2007, 10:13 AM   #17
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
The 3 prong grounded cord does bring the generator and the trailer to the same plane. This is the best way to have it. If you want to ground something ground the trailer. Just make sure your tow harness (brakes, lights, etc) is disconnected.
Michelle TAC MT-0
Sarah, Snowball
Old 06-13-2007, 12:04 AM   #18
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by wahoonc
But you aren't grounding anything by doing that....think about it. If you plug into shore power there is a ground rod somewhere in the system. The Airstream itself is not grounded, the truck is not grounded. If you don't ground the generator it isn't grounded.
and they don't read the directions that come with them that say that it requires grounding. I have seen someone get a pretty good jolt when a tool had a bad ground wire on it, and the generator wasn't grounded. People have been killed when something has gone wrong and the generator wasn't grounded. I am not an electrician but I know that you have to be grounded to a ground rod for safety. Can you get away without a ground rod, yes but eventually, somewhere, somehow, someone is going to get killed by not using one.
Aaron
Hi, once again, with a three wire set-up on the generator and a three wire hook-up on your trailer, you don't need another ground connection. Note: read post #17 from Michelle. And lastly, you answered your own question by saying, "I have seen someone get a pretty good jolt when a tool had a bad ground wire on it, and the generator wasn't grounded." You could have a ten foot copper ground rod attatched to your generator, but if the defective tool has the bad ground in it, you will still get shocked.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-13-2007, 05:10 AM   #19
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
You can say what you want and do what you want, as for me, I am not going to carry around a 6ft. spike and drive it in the ground every time I use the gen.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 06-13-2007, 06:29 AM   #20
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I went back and read the manual on my Honda Generator, then pulled up the newest version of the manual online. Apparently lawyers have gotten involved. My original manual calls out for the generator to be grounded to a "suitable ground" The newest version of the manual says to contact a qualified electrician or refer to current codes. I still contend that you are opening your self up to a shock if there is no lead to a ground rod. FWIW I don't use a 6' ground rod for temporary power service I use a 2-3'.
Aaron
WBCCI #XXXX AIR #2495
Old 06-13-2007, 07:24 AM   #21
Images: 59
There isn't a fixed rule for ground rods. If you are in dry sand, a 6 ft copper rod isn't long enough. In clay, you might be ok with 3 ft.
The only time your jack stand baseplate will work is on saturated turf after a good rain shower.
Old 06-13-2007, 09:23 AM   #22
Keymar , Maryland
If you are wearing shoes when you step into and out of the trailer everything is floating. You are fine. You can ground it, and if you do, do so at the generator. The trailer should be ground to the trailer. The three prong plug will be fine.
Michelle TAC MT-0
Sarah, Snowball
Old 06-14-2007, 10:04 AM   #23
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
FWIW, the (2005) owner's manual that came with my manufactured-in-2006 Yamaha EF2400iS states, "make sure to ground (earth) the generator" in both the safety information and the pre-operation checks sections.
This manual also provides guidance on the ground lead sizing (0.12mm/ampere), amonst the eight mentions of "ground" throughout the 38-page document.
I should think there must be something to this notion of grounding the generator...
Examining the wiring schematic, the ground terminal is a straight chassis connection.
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 06-19-2007, 03:59 PM   #24
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Grounded
Use that gen ground post: Pound a large metal spike in the ground and be on the safe-side!!!!
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
