Old 06-30-2008, 05:21 AM   #1
Generator giving no power output?
I have a new Generac generator that was installed last year and worked fine. This year I can plug in the City service and all works fine but when I fire up the Gen Ac and other items don't work. I replaced the transfer switch thinking it was bad but same results. What else can I check? Thanks
911rs is offline   Reply With Quote
Old 06-30-2008, 06:37 AM   #2
1973 25' Tradewind
Romulus , New York
The reset?
jayray5 is offline   Reply With Quote
Old 06-30-2008, 08:00 AM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
On the Yamaha if it overloads it stops generating although the engine keeps running. You have to restart it and that resets the breaker. Maybe it's the same with yours? Do you have a lot of load turned on in the camper when you plug it into the generator?
Old 06-30-2008, 07:28 PM   #4
Thanks to both of you. I will check for a reset.
Old 09-11-2010, 10:20 AM   #5
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
I'm having the same problem with my Onan. Did it work?
BarnacleBill is offline   Reply With Quote
Wind Generator Power?? chandles Generators & Solar Power 35 06-30-2008 09:12 AM
Generator Power cable - '77 Argosy Mike S Generators & Solar Power 3 06-25-2008 05:43 AM
Matching Generator Wattage with Power Requirements Streamer1 Generators & Solar Power 7 08-10-2007 10:11 PM
RV Wind Power Generator rseagle Generators & Solar Power 9 05-09-2007 11:13 AM
Armstrong AC on generator power loechli Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-22-2004 05:00 PM
