Old 07-29-2009, 10:05 AM   #1
1978 31' Sovereign
Kansas City , Missouri
Generator for Mobile Coffee Shop
Hello! I work for a specialty coffee roaster in Kansas City, MO. We have a 1978 Sovereign. We are looking for a generator that is fairly quiet and has low fumes. We are needing something in the 10000 to 15000 watt range. We take it to special events and serve coffee from it. I've attached a picture if you are curious!
Name:	Airstreams First Event.jpg
aircoffee is offline   Reply With Quote
Old 07-29-2009, 11:07 AM   #2
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Good question.
I think most people here have or are in need of a generator w/ a range between 1000 - 3500 watts. So there might not be many people w/ experience w/ or an opinion of a generator w/ that much capacity.
Would love to see interior photos of your sovereign.
Good Luck, MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 07-29-2009, 12:26 PM   #3
2008 16' Safari
Destrehan , Louisiana
Check this one out:
Generac Power Systems - QuietSource Series 22 kW Generator
These are well built and quiet.
dlb435 is offline   Reply With Quote
Old 01-12-2010, 06:14 AM   #4
leeds , w yorks
wow thats alot of watts.
weloveraw is offline   Reply With Quote
Old 01-12-2010, 07:05 AM   #5
1971 29' Ambassador
Leonardtown , Maryland
Another source for quiet power, Cummins Onan
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 01-12-2010, 07:54 AM   #6
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Wow, that's the size nearing what is mounted onboard million-dollar coaches. At least 500-lbs for the main unit if diesel (prior to fuel tanks, plumbing, filters, pumps, exhaust & intake, etc). A big space/weight/balance problem.
Seems to me that, were I starting from scratch, that a PTO generator would be the way to go as to size & weight; where the TV engine is the generator power source.
Real Power - Features
There are plenty of us who would like a generator not only for the TT, but as an emergency/short-term power source for the house. We'll be interested in your approach and solution.
Old 01-12-2010, 08:10 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums
If you want low fumes, probably LP or Propane-powered would be the way to go. Unless you're a truck driver, diesel fumes and coffee are not a good mix. I'll look in my generator catalog when I get to work, and ask my boss to post my findings here for you.
Old 01-12-2010, 08:48 AM   #8
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I dont know of any genset that can put out the 10k to 15 k watts you desire. To get a genset that puts out that much and still can be hauled around I have not seen. About the 7500 is the largest I have seen thats portable.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 01-12-2010, 08:56 AM   #9
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
Cool trailer! My daughter used to order coffee from you for her coffee bar and restaurant. Still does, I think. I'm drinking a cup of Holiday Blend as I type this. Great coffee.
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
http://chaosinature.blogspot.com/
Isadora is offline   Reply With Quote
Old 01-12-2010, 09:04 AM   #10
CanoeStream's Avatar
St. Cloud , Minnesota
Cool to think of... like Artstream, our mobile artist. Use a small commercial truck to pull, with a genny inside. Then the obligatory coffee roaster will fill the AIR at rallies. Side business of using coffee fumes to replace nitrogen in tires. We'll have everyone doing those trailer tours by 9:00 instead of the customary 1:00PM.
5 meter Langford Nahanni
Old 01-12-2010, 09:16 AM   #11
The Polishing Guru
zinbar's Avatar
Riverside , California
The largest LP genset our suppliers have available is 6500 watts.
There is a diesel genset that is 12,500 watts. I wouldn't want to carry or run a pair of them, though. It would, of course, double the diesel fumes.
They get progressively larger the more wattage you have. Possibly a pair of gensets that would power specific items in the trailer would be better, and keep size and weight to something reasonable would better suit your needs.
Riverside, CA
zinbar is offline   Reply With Quote
Coffee anyone? balrgn Stella's Kitchen 187 12-19-2011 05:20 PM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
Coffee to go Turtle On The Road... 3 05-28-2004 11:00 PM
Repair Shop, renovation shop SE Area? Diesel Pusher Commercial Listings 2 11-07-2003 09:42 AM
