Old 09-01-2011, 04:20 PM   #1
pol
1995 30' Limited
1995 31' Land Yacht LE
Seattle , Washington
Question Generator exhaust smoke
After some run time my generator smokes - it appears to be plain old blue-grey exhaust smoke. Assuming it is the result of wear and tear in a 15 year old Land Yacht, are there shops that rebuild the motor? Cost?
pol is offline   Reply With Quote
Old 09-01-2011, 05:42 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Before doing that, try changing the oil, and using Mobil 1 in it. I did that with a couple of generators, and the smoke went away. This was oil smoke, not from a carburetor problem.
Old 09-02-2011, 10:09 AM   #3
pol
1995 30' Limited
I will try changing the oil.
Old 09-02-2011, 10:45 AM   #4
tpi
Trabuco Canyon , California
I'd also try to change the oil, and the spark plug (in case its fouled) and see what happens before you tear down the engine. If it specs a 15-40, or straight 30 or 40 oil, I'd try Mobil 1 15-50. If that cuts consumption to near nothing, next change I'd go with a xxW40 synthetic. You could be suffering from fuel dilution or stuck piston rings oil so a change is worth a try..
tpi is offline   Reply With Quote
Old 09-02-2011, 10:48 AM   #5
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
Hi There,
I use Mobil 1 in everything. I never tried Mobil 1 to stop smoke, but it may indeed burn cleaner than petroleum. It makes sense that it is a better "frying oil".
"Back in the day", when I had a smokey Porsche 356, that needed rings and valve guides, I used a 30# two-stroke motorcycle oil "Yamalube" which was formulated as "smokeless". It alleviated the embarrassment, and provided adequate lubrication. Eventually I tore the motor down and found no burned bearings or crankshaft damage.
Definitely try Mobil 1 or two-stroke oil. Maybe These days they make a synthetic two-stroke oil??
And.. schedule a "freshening" or full rebuild... BEFORE something "lets go".
Peace
ALUMINUMINUM is offline   Reply With Quote
Airstream sightings pinkflamingoes Our Community 7016 06-21-2018 03:40 PM
Abby gets some separation H Top Repairing/Replacing Floor &/or Frame 489 10-18-2016 09:01 PM
WBCCI New Constitution LI Pets WBCCI Forum 1165 03-28-2012 10:35 PM
Finding a short Stormy Weather Lights - Interior & Exterior 9 06-14-2011 07:49 AM
2011 Mid Winter Meeting wkerfoot WBCCI Forum 372 02-07-2011 02:07 PM
