Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 04-11-2007, 06:47 PM   #29
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Originally Posted by overlander63
No, there is a practical reason. If you use regular Coke, you may have to deal with gooey syrup after it dries, Diet Coke doesn't seem to have that problem. Also, I drink diet drinks exclusively, so that's what I have on hand.
AHHHHHHHHHHH!
I knew you would have a substantive answer .
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 05-09-2007, 11:48 AM   #30
wacnstac
Profile:  1979 31' Excella 500
Detroit Area , Michigan
Images: 41
It turns out it wasn't the battery after all, but rather a lame 5A fuse Honda but in between the battery and the starter. Must have blown when I tried a battery start in cold weather this winter.
wacnstac is offline   Reply With Quote
Old 05-09-2007, 04:41 PM   #31
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Terry, I spent a few years in a GM shop but have never heard of this. What is the effect? Does it bubble like baking soda? Or...??
Dave
Fyrzowt is offline   Reply With Quote
Old 05-09-2007, 06:31 PM   #32
bhayden
bhayden's Avatar
Profile:  1978 24' Argosy 24
Woodinville , Washington
Unless motorcyle batteries have gotten substantially worse over the last couple of decades you should get at least three years out of one used for a generator. I suspect the trickle charger killed it. Unless it's a fairly sophisisticated "intellegent" charger it will keep charging the whole time it's connected. These "wall wart" chargers are designed to keep a battery topped up when it's sitting for an extended period with a small drain; like in a car that's got a clock or other electronics that continues to draw a small current. A charger that's designed to only prevent self discharge will be identified as a float charge. Those actually turn on and off as well as vary the voltage based on what they read from the battery(s).
I think the best thing for the battery (and the generator) is to leave it in place and run the unit long enough to bring it up to operating temperature every month or two. That's the way virtually all emergency standby generators are set up.
bhayden is offline   Reply With Quote
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
